Exported RCP tutorial crashes when run [message #539420] |
Thu, 10 June 2010 16:28 |
Nick Griffiths Messages: 3 Registered: June 2010 |
I've just started learning how to create RCP applications and have come across a problem whilst following the tutorial. I can create a simple "Hello RCP" application with a product file and run it from within Eclipse (using the "Launch an Eclipse application" link) with no problem. However, when I export the application using the "Eclipse Product export wizard" and run it, it crashes. The following steps recreate my problem:
- Install Eclipse Helios RC3 for RCP and RAP Developers (win32).
- Start Tutorial "Create a Rich Client Platform (RCP) application".
- Follow steps in "Create a plug-in" tutorial (except the section "Modify the plug-in source", which instructs the user to write code to change the window title).
- Follow steps in "Define a plug-in based product".
- Follow steps in "Export an RCP product".
- When the executable output is run, a command window opens, prints a stack trace and closes automatically. The log file from my "..\rcpapp_plugin-based\configuration" directory is at the bottom of this post.
I have followed the RCP tutorial using Eclipse Galileo and I can export and run the RCP tutorial application with no problems.
Can anyone help me work out what the problem is?
!SESSION 2010-06-10 17:01:00.389 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=${target.os}, ARCH=${target.arch}, WS=${target.ws}, NL=${target.nl}
Command-line arguments: -os ${target.os} -ws ${target.ws} -arch ${target.arch} -consoleLog
!ENTRY org.eclipse.osgi 4 0 2010-06-10 17:01:01.468
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (27).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:156)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:751)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger (BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:106)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(Unknown Source)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1197)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:904)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:151)
... 67 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
... 73 more
Root exception:
... 73 more
!ENTRY org.eclipse.osgi 4 0 2010-06-10 17:01:01.624
!MESSAGE An error occurred while automatically activating bundle com.example.rcpapp (1).
!STACK 0
org.osgi.framework.BundleException: The activator com.example.rcpapp.Activator for bundle com.example.rcpapp is invalid
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
... 33 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (27).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:121)
... 52 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
... 61 more
... 67 more
... 73 more
Root exception:
... 52 more
... 61 more
... 67 more
... 73 more
!ENTRY org.eclipse.osgi 2 0 2010-06-10 17:01:01.811
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-06-10 17:01:01.811
!MESSAGE Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503 [17] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86 2 0 2010-06-10 17:01:01.811
!MESSAGE Platform filter did not match: (& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))
!MESSAGE Bundle org.eclipse.swt.win32.win32.x86_3.6.0.v3650 [25] was not resolved.
!SUBENTRY 2 org.eclipse.swt.win32.win32.x86 2 0 2010-06-10 17:01:01.811
!ENTRY org.eclipse.osgi 4 0 2010-06-10 17:01:01.827
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.example.rcpapp was unable to load class com.example.rcpapp.Application.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.example.rcpapp (1).
... 15 more
Caused by: org.osgi.framework.BundleException: The activator com.example.rcpapp.Activator for bundle com.example.rcpapp is invalid
... 27 more
... 33 more
... 52 more
... 61 more
... 67 more
... 73 more
Re: Exported RCP tutorial crashes when run [message #539685 is a reply to message #539420] |
Fri, 11 June 2010 20:34 |
You might have better luck in an RCP newsgroup.
> the window title).
> this post.
> !STACK 0
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> tarter.java:369)
> tarter.java:179)
> ... 67 more
> leLoader.java:422)
> leLoader.java:410)
> ... 73 more
> Root exception:
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> tarter.java:369)
> tarter.java:179)
> leLoader.java:422)
> leLoader.java:410)
> ... 73 more
> !STACK 0
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> tarter.java:369)
> tarter.java:179)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ... 33 more
> leLoader.java:422)
> leLoader.java:410)
> ... 52 more
> ion.java:417)
> ... 61 more
> ... 67 more
> leLoader.java:422)
> leLoader.java:410)
> ... 73 more
> Root exception:
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ion.java:417)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> tarter.java:369)
> tarter.java:179)
> leLoader.java:422)
> leLoader.java:410)
> ... 52 more
> ion.java:417)
> ... 61 more
> ... 67 more
> leLoader.java:422)
> leLoader.java:410)
> ... 73 more
> !MESSAGE Bundle
> not resolved.
> 17:01:01.811
> resolved.
> !STACK 1
> tarter.java:369)
> tarter.java:179)
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ... 15 more
> ion.java:417)
> ... 27 more
> leLoader.java:422)
> leLoader.java:410)
> leLoader.java:338)
> ... 33 more
> leLoader.java:422)
> leLoader.java:410)
> ... 52 more
> ion.java:417)
> ... 61 more
> ... 67 more
> leLoader.java:422)
> leLoader.java:410)
> ... 73 more
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Exported RCP tutorial crashes when run [message #541537 is a reply to message #541516] |
Mon, 21 June 2010 13:24 |
Hello Nick,
I think you'll have more success on a solution if you ask your question
in a newsgroup for RCP development.
Here you are in a newsgroup about "PDT - PHP Development Tools"!
Good luck & best regards
Am 21.06.2010 14:58, schrieb Nick Griffiths:
> Prakash thanks for the reply.
> I used the eclipse export wizard to auto-generate values etc for the app.
> I'm running windows xp - 32 bit - all the values in (osgi.ws=win32)
> (osgi.os=win32) (osgi.arch=x86) sound ok to me.
> I've also tried doing the equivalent tutorial on a Linux box with the
> same results (java.lang.ClassNotFoundException: org.eclipse.swt.SWTError).
> Any other suggestions?
> cheers Nick
FUDForum. Page generated in 0.04583 seconds
