Re: Keyboard shortcuts for common navigator [message #539088 is a reply to message #538992] |
Wed, 09 June 2010 15:30 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
Geejay wrote on Wed, 09 June 2010 02:40 | Hi All
First of all thanks for all the help so far.
I am using the common navigator, and have enabled the pattern
org.eclipse.ui.navigator.resources.* in my viewerActionBinding.
The context menu appears with all the default actions (for example cut,
copy, paste, delete).
How do I get the keyboard shortcuts to work ?
Greg
These are part of the normal retargetable action definitions as far as I know, it's not really anything to do with the common navigator (which makes my useless in this case). If this is not enough help for you, then Paul will probably be along and say something insightful and helpful soon (if he does not, ask your question with something like "actions" in the title (and not common navigator).
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
FUDForum. Page generated in 0.03051 seconds
