[E4] Preference annotation and the e4 dependency injection architecture [message #538597] |
Tue, 08 June 2010 07:55 |
I have two very different questions :
1- despite several attempts, I didn't succeed in making the @Preference annotation work and I can't find a complete example to understand how to use it, and the wiki is not helping (http://wiki.eclipse.org/E4/EAS/Preferences). I know how you are supposed to use it thanks to this example : http://tomsondev.bestsolution.at/2010/05/17/a-week-at-e4-sha re-me-please/
But I didn't succeed in storing a value in the preference store and then getting it back thanks to the annotation even if I'm convinced that it's very easy and I'm just missing something. So do you have a simple example for storing a data in the preference store and then getting it back with @Preference ?
2- I have a question on the behavior of your dependency injection architecture. I have created a class, representing a view, similar to this :
public class Test {
@Inject
public Test(Composite parent) { /* do nothing */ }
@Inject
public void doSomething(@Optional @Named("selection") IFile file) { /* do nothing */}
When my class is loaded both the constructor and the method are called due to the @Inject annotation. Latter while using my application if I select an IFile my "doSomething" method is called, it works as expected.
So I was wondering, how the dependency injection system knows that it has to call my method.
I know that, for the event system, the event broker is using the event admin system from Equinox, and I know thanks to the" OSGI and Equinox" book (page 257) that OSGI register the listener of an event in its service registry, thanks to this message ( http://www.eclipse.org/forums/index.php?t=msg&th=167787& amp;start=0&) I know that it can happen only with the @Inject annotation on the method that need to be called.
So my theory is that when my object is created, the dependency injection engine sees the @Inject annotation and "tells" OSGI to register my method as "a service that need to be called when the selection changes". And when the selection changes, the platform tells OSGI "if you have a service that need to be called, do it". Am I right ? Is that the same for @Execute or @CanExecute ? If not, how does the dependency injection engine know how to call my method ?
Re: [E4] Preference annotation and the e4 dependency injection architecture [message #538660 is a reply to message #538597] |
Tue, 08 June 2010 11:04 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Am 08.06.10 09:55, schrieb Stephane Begaudeau:
If it is not working as advertised this is a bug and needs to be fixed.
I'll try to add it to one of my demos to see whether it works or not.
> this :
> public class Test {
> @Inject
> @Inject
> do nothing */}
No the DI-Container remembers in a locale context (IEclipseContext) -
you can compare it to a Hierarchical-HashMap - which values it has
injected into your instance and whenever this value changes it reinjects
the value.
@Execute and @CanExecute are a bit different because that's not really
injection what's happening there.
The command-framework does something similar. When the instance is
created it looks for @CanExecute and calls it with parameters in the
context and remember which values it used because they could lead to an
activation state change - now whenever one of the keys (the fully
qualified classname, the value in @Named()) changes it recalls this method.
The execute-method is only triggered by the Command-Framework wants to
execute the command and then determines the values that need to be
passed in.
Tom
FUDForum. Page generated in 0.04310 seconds
