Re: CheckBoxTableViewer [message #538331 is a reply to message #538293] |
Mon, 07 June 2010 07:52  |
On 07/06/10 3:00 PM, Amit wrote:
> Hi there,
> I am trying to implement a CheckBoxTreeViewer and facing this problem.
> On expand of a CheckBoxTreeViewer node, getChildren() method of provided
> ITreeContentProvider is called only for the first time.After that if you
> again collapse and expand that node, this method is not getting called
> again.
> I am making some changes to a node so that its chaildren are different
> now but on expand it is still showing the same children which are no
> more valid.
> What should I do so that viewer again make the use of provided
> ITreeContentProvider to get the children nodes of that tree node ?
> Any ideas?
Try calling refresh() with that node
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
FUDForum. Page generated in 0.05022 seconds
