Home » Archived » M2M (model-to-model transformation) » Unique Matched Rule !
Unique Matched Rule ! [message #538223] Sun, 06 June 2010 13:44 Go to next message
I want to produce a single one element from 2 source elements, I could use "unique lazy rule", but the problem is, there is no place to call it ... so its "un-applicable" ....
For example consider the example of Families to Persons !
rule Member2Male {froms : Families!Member (not s.isFemale())
     to t : Persons!Male (
                  fullName <-s.firstName + ' '+ s.familyName
This rule transforms a Member into a Male, but I want to to transform 2 Members (they have the same name, same properties ...) into 1 same Male ? Now how to do that ??
Your help is much appreciated !
[Updated on: Sun, 06 June 2010 18:55] by Moderator
Re: Unique Matched Rule ! [message #538595 is a reply to message #538223] Tue, 08 June 2010 03:53 Go to previous messageGo to next message
You can have in the from section of the rules multiple elements :
from s : Families!Member, t : Families!Member (s.name = t.name)
Re: Unique Matched Rule ! [message #538767 is a reply to message #538223] Tue, 08 June 2010 11:18 Go to previous messageGo to next message
Sylvain, Thanks for your reply, but that does not solve the problep, actually that way it creates 4 target elements instead of just 2 !
Any other idead is very welcome !
Re: Unique Matched Rule ! [message #538782 is a reply to message #538223] Tue, 08 June 2010 11:23 Go to previous messageGo to next message
Using the OCL allInstances in place of match rule, you be able to call
the unique lazy rule ????
> rule Member2Male {froms : Families!Member (not s.isFemale())tot :
> Persons!Male (fullName <-s.firstName + ' '+ s.familyName)
> Members into 1 same Male ? Now how to do that ??
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: Unique Matched Rule ! [message #538796 is a reply to message #538767] Tue, 08 June 2010 12:13 Go to previous messageGo to next message
zoro wrote on Tue, 08 June 2010 11:18
That's because you can invert s and t.
Let's say you have two Member A and B.
Then this rule will match s = A, t = B but also, s = B, t = A.
So if you use this solution you have to elaborate a complex filter so that you can't invert both elements if you don't want to.
Re: Unique Matched Rule ! [message #538814 is a reply to message #538796] Tue, 08 June 2010 13:22 Go to previous messageGo to next message
@Sylvain: That will only lead to more and more complex filter as you said, and frankly, I don't have a clue how to write that filter, so if you have any other solution, I'll be greatful ...
@Vincent: I don't understant your idead, can you give me an example !
Thanks to all of you Smile
[Updated on: Tue, 08 June 2010 13:23] by Moderator
Re: Unique Matched Rule ! [message #538951 is a reply to message #538223] Wed, 09 June 2010 03:46 Go to previous messageGo to next message
You have to take in consideration that a unique called rule only consider the first argument for the unicity.
If you call the same rule with A, B and then B, A it will still execute the rule 2 times (except if this bug has been corrected).
Re: Unique Matched Rule ! [message #539063 is a reply to message #538223] Wed, 09 June 2010 10:21 Go to previous message
No, this bug hasn't been corrected ! so I'm looking for a workaround (hopefully it exists !) ...
Previous Topic:[QVTo] 1-to-* transformation does only result in one deeper transformationtree
Next Topic:how to construct the defining feature in a slot (instance)
Current Time: Thu Jul 17 22:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.30902 seconds
