Home » Modeling » GMF (Graphical Modeling Framework) » Copy and Paste - Geronimo!!
Copy and Paste - Geronimo!! [message #538094] Fri, 04 June 2010 18:23 Go to next message
For those of you who are unfamiliar, Geronimo was one of the last great Native America Leaders / Warriors of the 19th century. For some reason Americans commonly call out his name when they jump out of an airplane or face some other great danger, but I digress...
Why is GMF Copy and Paste so difficult?
I've looked over a variety of notes, bugs, and some on-line articles. A basic copy and paste is operational on 3.4 when ONLY using GMF in a single file mode (i.e. model and diagram are both in same file). However, it also seems to work for me with WITHOUT resorting to enabling UUIDs.
I am about to create custom handlers, etc... to achieve copy and paste operation base on the information I have assimilated.
However, I would greatly appreciate if a core member could answer a few questions:
* Why are UUIDs needed? I understand what they are especially in an EMF context, but why is this discussed so much for this issue?
* Why does a simple example NOT seem to need them (i.e., UUIDs)?
* Why does copy-and-paste work ONLY on the single-file case and not the multi-file case situation? Will it be prohibitively difficult for me to get it to operate for the multi-file case situation?
* What broke and why from Eclipse release 3.4 to 3.5 or GMF Release 2.2.0 to 2.2.2?
* Are the support of compartments going to be challenging too?
* If I achieve a reasonable implementation, can I contribute it back to release 3.6 sr2?
* Will Graphiti replace GMF?
Thanks in Advance,
Geronimo
Re: Copy and Paste - Geronimo!! [message #538338 is a reply to message #538094] Mon, 07 June 2010 08:07 Go to previous messageGo to next message
Hi Geronimo,
Comments below.
May be because copy-paste is an easy to use functionality but is difficult to implement
in a generic AND extensible way for graphical modelers.
> UUIDs.
First there is two ways for implementing copy-paste in your GMF based application :
- org.eclipse.gmf.runtime.emf.clipboard.core.clipboardSupport
To customize the current copy-paste default behavior. You have to use UUID in you domain model resource factory.
- org.eclipse.gmf.runtime.common.ui.services.action.globalActi onHandlerProviders
To override completely copy-paste default behavior.
> questions:
On a functional view UUIDs are used to identify eObject instances without referencing them by a feature (for instance their name) or an index. UUIDs
have one quality, they will not change between copy and paste operation, while index or name could.
On a technical view, the clipboard content is saved in a String. So GMF used a special resource and write its content to a String. This resource use UUID.
If you are single file (i.e. model and diagram are both in same file) the resource used is a GMFResource one which use UUID.
So if you are multi-file case, you simply need in theory to use UUIDs in your domain model resource.
> 2.2.0 to 2.2.2?
I could not answer. If you think there is a regression, open a bug with a reproducible test case.
Of course correction it will be faster, if you provide a patch and associated test.
http://wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_to_make_co py.2Fpaste_work_on_compartments.3F
> to release 3.6 sr2?
All bugfixes are welcome.
GMF runtime is a runtime for modelers over GEF and Graphiti is another. They do not have the same API and not the same committers, you are free
to use the one you prefer :).
> Thanks in Advance,
> Geronimo
Mariot
Re: Copy and Paste - Geronimo!! [message #541183 is a reply to message #538338] Fri, 18 June 2010 10:59 Go to previous messageGo to next message
I am running into a copy and paste problem from eclipse gmf 3.5.1 to 3.5.1 (gmf 2.1 to gmf 2.2).
This is a serious problem for us and i am not sure how to fix it. Basically, copy and paste stopped working.
I am not sure what broke or how to fix it, so any ideas are appreicated. IF any information is needed let me know!
Re: Copy and Paste - Geronimo!! [message #541195 is a reply to message #541183] Fri, 18 June 2010 11:30 Go to previous messageGo to next message
Do you contribute a clipboard support factory with lowest priority ?
In this case have a look to https://bugs.eclipse.org/bugs/show_bug.cgi?id=317035
Workaround for that bug is to increment contribution priority.
Otherwise please provide more information.
Re: Copy and Paste - Geronimo!! [message #541196 is a reply to message #541195] Fri, 18 June 2010 11:51 Go to previous messageGo to next message
Mariot,
Thanks for the quick reply! I probably do not do this. I am new to GMF and fixing some code someone left behind. If you have any details on how to change the priority, that would really help.
-Rob
Edit: Nevermind, it is detailed in the bug, sorry! I will try the workaround in a moment.
[Updated on: Fri, 18 June 2010 11:55] by Moderator
Re: Copy and Paste - Geronimo!! [message #541199 is a reply to message #541196] Fri, 18 June 2010 12:06 Go to previous message
Mariot,
This indeed fixes the problem. Thank you so much!
-Rob
Previous Topic:Live validation
Next Topic:Which method is called when the cursor passes over a figure?
Current Time: Mon Nov 03 08:04:17 EST 2025
Powered by FUDForum. Page generated in 0.04106 seconds
