[ATL] How to make an ecore from XSD and its XML? [message #538017] |
Fri, 04 June 2010 14:08 |
Alexey Messages: 61 Registered: January 2010 |
Member |
Hello!
For my ATL-Transformation I have as Metamodel and as its Model
two files - xsd and xml respectively.
Now, if I import them into my ATL-Project, Eclipse gives errors and doesn't provide the "tree-view".
Thus, I need to make two ecore-files from xsd and xml. Are there any converters for that? How is it possible to convert xsd and xml to an ecore?
Thanks a lot,
Alexey
[Updated on: Fri, 04 June 2010 14:21] Report message to a moderator
Re: [ATL] How to make an ecore from XSD and its XML? [message #538314 is a reply to message #538057] |
Mon, 07 June 2010 10:22 |
Member |
Hi, Ed!
Thank you for your patience and for your help!
I try to explain this matter with xml 2 ecore.
The situation is - that I have a ready input for my future ATL-transformation in form of two files - an XSD and a conform XML. Both are very big and they are ALREADY CREATED, xml too.
So it's not like : "Get ecore from xsd and make your own models", but its more like "Get XSD as MM and its XML as M and work with that on ATL".
I have a PREPARED XML-file, which I have to integrate in Eclipse.
Thats why I ask - what should I do with the Model itself (the XML-file), when Im ready with XSD-2-Ecore transformation?
I hope, I explained the matter more accuratelly.
Thank you in advance,
Alexey
[Updated on: Mon, 07 June 2010 10:48] Report message to a moderator
FUDForum. Page generated in 0.03419 seconds
