| [QVTo] Mapping 1 to many objects results in output object appearing as siblings [message #538010] | Fri, 04 June 2010 09:44  |  |
| Eclipse User  |  |  |  |  | Hello again everybody,
 When trying to transform one input object to many (e.g. two) output objects i came along the following problem:
 The output-objects are all placed as siblings to the first generated object.
 For mappings of a single object to a set of output-object Pieter mentioned this problem already here: http:// www.eclipse.org/forums/index.php?t=msg&goto=517460&# msg_517460
 I also tried the work-around wich Pieter used, but the rsults are still the same.
 Here are more details:
//Entry-point
mapping AUTOSARGenIA::ARPackage::arpackage2module() : Module {
	declarations += self.elements[SenderReceiverInterface]->forEach(SRInterface) {generateMessagePortTypes(SRInterface)->asOrderedSet()};
// the one2many transformation:
query generateMessagePortTypes(in interface:AUTOSARSwcPorti::SenderReceiverInterface) : Set(MessagePortType){
	var resultPorts:Set(MessagePortType);
	resultPorts += interface.map senderReceiverInterface2messagePortType(true);
	resultPorts += interface.map senderReceiverInterface2messagePortType(false);
	return resultPorts;
mapping AUTOSARSwcPorti::SenderReceiverInterface::senderReceiverInterface2messagePortType(in isProvided:Boolean) : MessagePortType{
	var direction:String;
	if (isProvided)
		then direction := "OUT"
		else direction := "IN"
		endif;
	name := self.shortName+direction;
	comSpec := self.dataElements.map dataElementProtoType2messageAndStreamComSpec()->asOrderedSet();
 in the resulting model all MessagePortTypes occure as siblings on top-level instead of beeing children to their parent module. Same problem occured, as Pieter already mentioned, when directly using a mapping with signature:
 mapping AUTOSARSwcPorti::SenderReceiverInterface::senderReceiverInterface2messagePortTypes : Set(MessagePortType)
 and also, when generating the MessagePorttypes directly inside the Query:
	resultPorts += object MessagePortType{name:=interface.shortName+"IN"};
	resultPorts += object MessagePortType{name:=interface.shortName+"OUT"};
	return resultPorts;
| Re: [QVTo] Mapping 1 to many objects results in output object appearing as siblings [message #538025 is a reply to message #538010] | Fri, 04 June 2010 10:18   |  |
| Eclipse User  |  |  |  |  | Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
 Hello C. Kopf,
 > //Entry-point
 >     declarations +=
 If you create new objects and don't contain them anywhere in other
 objects, they end up as top-level (root) objects in the output. So,
 somehow your objects are not contained. Maybe change the above to this:
 declarations += generateMessagePortTypes(SRInterface)->asOrderedSet()
 I not sure this helps, but you can try it...
 Dennis
 > object.
 >  http://www.eclipse.org/forums/index.php?t=msg&goto=51746 0&#msg_517460
 > the same.
 > //Entry-point
 >     declarations +=
 >     return resultPorts;
 > mapping
 >  AUTOSARSwcPorti::SenderReceiverInterface::senderReceiverInte rface2messagePortType(in
 >     if (isProvided)
 >         endif;
 > mapping
 >  AUTOSARSwcPorti::SenderReceiverInterface::senderReceiverInte rface2messagePortTypes
 >     return resultPorts;
FUDForum. Page generated in 0.23724 seconds
