Re: Changing property values in property view [message #537958 is a reply to message #537926] |
Fri, 04 June 2010 09:30 |
Geejay Messages: 160 Registered: February 2010 |
Answer from an old post that I found, sorry for the dupe:
The properties view listens for selection changed events from the workbench
page's selection service, and notifies the current property page of the
change. The default property page updates in response (as should other
implementations).
The view or editor needs to publish its selection provider via
getSite().setSelectionProvider(ISelectionProvider), and issue events to
selection listeners appropriately.
If the view or editor is implemented using a viewer, you can just set that
as the selection provider.
If properties of the selected element are changing without the selection
changing, you may need to issue a fake selection event to get the properties
view to update.
Nick
From within the
Phil Williams wrote:
I have a RCP app that uses the properties view. The properties that are
shown can be modified within editors. What event should be fired to let the
PropertySheet know that it has to update or do I have to get a handle to it
and do it myself?
Phil
"geejay" <gjmcknight@schlagundrahm.ch> wrote in message
news:huabk2$vg9$1@build.eclipse.org...
> Hello all,
> I am trying to change the values I have set via a IPropertySource in the
> properties view.
> I have set the properties initially, but I don't understand yet whether
> the properties view actually listens for changes in my property
> descriptors, or how I can actually update the values in the properties
> view.
> Any tips?
> Thanks heaps
> Greg
Re: Changing property values in property view [message #537966 is a reply to message #537958] |
Fri, 04 June 2010 10:59 |
Actually, this still doesn't help me enough.
I cant seem to find how to fire an event that the PropertySheet listens to.
Any tips?
news:huah36$s18$1@build.eclipse.org...
> workbench page's selection service, and notifies the current property page
> of the change. The default property page updates in response (as should
> other implementations).
> properties view to update.
> Nick
> From within the
> the PropertySheet know that it has to update or do I have to get a handle
> to it and do it myself?
> Phil
>> Hello all,
>> properties view.
>> view.
>> Any tips?
>> Thanks heaps
>> Greg
Re: Changing property values in property view [message #539288 is a reply to message #537966] |
Thu, 10 June 2010 09:33 |
The main problem is that the API hides all the pages (PropertySheetPage) and
therefore viewers (PropertySheetViewer) within the properties view.
Good news is, you can tell the properties view to use a page of your desire.
So I supply the page that it would normally use by default
(PropertySheetPage), except when I supply it, I keep a reference to it
(obviously), and then you can call propertySheetPageRef.refresh() to update
the model (thankfully this method is public).
public Object getAdapter(Class adapter) {
if (adapter == IPropertySource.class) {
return resultProvider;
} else if (adapter == IPropertySheetPage.class) {
return propertySheetPage;
return null;
news:huamag$jj3$1@build.eclipse.org...
> to.
> Any tips?
>> page of the change. The default property page updates in response (as
>> should other implementations).
>> that as the selection provider.
>> Nick
>> From within the
>> are shown can be modified within editors. What event should be fired to
>> let the PropertySheet know that it has to update or do I have to get a
>> handle to it and do it myself?
>> Thanks,
>> Phil
>>> Hello all,
>>> properties view.
>>> view.
>>> Any tips?
>>> Thanks heaps
>>> Greg
FUDForum. Page generated in 0.04220 seconds
