Home » Eclipse Projects » EclipseLink » HistoryPolicy: INSERT Error with missing fields(HistoryPolicy: INSERT Error with missing fields)
HistoryPolicy: INSERT Error with missing fields [message #537460] |
Wed, 02 June 2010 14:16 |
Wolfgang Messages: 7 Registered: June 2010 |
in my project with several entities HistoryPolicy works for all but one Entity. While dugging I noticed two calls to the history table - the first that is correct is:
Quote: | ""INSERT IGNORE INTO organization_hist (id, phone, status, change_time, zipcode, city, country, address, name, tenant, parent, editor, dtype, row_start) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)""
the second that fails is:
Quote: | Internal Exception: java.sql.SQLException: Field 'id' doesn't have a default value
Error Code: 1364
Call: INSERT IGNORE INTO organization_hist (zipcode, country, city, change_time, tenant, address, name, row_start) VALUES (?, ?, ?, ?, ?, ?, ?, ?)
bind => [76669, DEU, Bad Schönborn, 2010-06-02 16:00:50.812, 4510, Max-Reger-Ring 34, tuakoava, 2010-06-02 16:00:58.109]
I have no clue as to why the second call occurs and why it has a reduced number of fields - any clues? If it helps I can post the corresponding entities, but it's a bit of code.
regards, Wolfgang
Re: HistoryPolicy: INSERT Error with missing fields [message #538108 is a reply to message #537460] |
Sat, 05 June 2010 05:33 |
Hi James,
thx for your support - here some more details. Stack trace:
Quote: |
------------- Standard Output ---------------
[EL Info]: 2010-06-05 07:23:11.359--ServerSession(10059989)--EclipseLink, version: Eclipse Persistence Services - 2.0.0.v20091127-r5931
[EL Info]: 2010-06-05 07:23:12.093--ServerSession(10059989)--file:/N:/NetBeansProj ects/Biz2BankPersistency/src/_TisDatabase login successful
[EL Warning]: 2010-06-05 07:23:12.281--UnitOfWork(6867819)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1364
bind => [76669, DEU, Bad Schönborn, 2010-06-05 07:23:12.25, 1504, Max-Reger-Ring 34, skkqvnfy, 2010-06-05 07:23:12.265]
Query: InsertObjectQuery(com.tis.biz2bank.server.db.entities.Organi zationalEntity[id=1504])
Testcase: BasicJpatest(com.tis.biz2bank.server.db.entities.BasicTest): Caused an ERROR
Error Code: 1364
javax.persistence.RollbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1364
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImpl.commitInternal(EntityTransactionImpl.java:102)
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImpl.commit(EntityTransactionImpl.java:63)
at com.tis.biz2bank.server.db.entities.BasicTest.BasicJpatest(B asicTest.java:50)
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.0.0.v20091127-r5931): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1364
at org.eclipse.persistence.exceptions.DatabaseException.sqlExce ption(DatabaseException.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeDirectNoSelect(DatabaseAccessor.java:800)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeNoSelect(DatabaseAccessor.java:866)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.basicExecuteCall(DatabaseAccessor.java:586)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeCall(DatabaseAccessor.java:529)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteCall(AbstractSession.java:914)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:205)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.insertObject(DatasourceCallQueryMechanism.java:321 )
at org.eclipse.persistence.internal.queries.StatementQueryMecha nism.insertObject(StatementQueryMechanism.java:162)
at org.eclipse.persistence.history.HistoryPolicy.logicalInsert( HistoryPolicy.java:752)
at org.eclipse.persistence.history.HistoryPolicy.postInsert(His toryPolicy.java:711)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.insertObjectForWrite(DatabaseQueryMechanism.java:473)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCom mit(InsertObjectQuery.java:80)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCom mitWithChangeSet(InsertObjectQuery.java:90)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechan ism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:28 6)
at org.eclipse.persistence.queries.WriteObjectQuery.executeData baseQuery(WriteObjectQuery.java:58)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:675)
at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitO fWork(DatabaseQuery.java:589)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery. java:109)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.execu teInUnitOfWork(ObjectLevelModifyQuery.java:86)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2863)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1225)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1207)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1167)
at org.eclipse.persistence.internal.sessions.CommitManager.comm itNewObjectsForClassWithChangeSet(CommitManager.java:197)
at org.eclipse.persistence.internal.sessions.CommitManager.comm itAllObjectsWithChangeSet(CommitManager.java:103)
at org.eclipse.persistence.internal.sessions.AbstractSession.wr iteAllObjectsWithChangeSet(AbstractSession.java:3260)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabase(UnitOfWorkImpl.java:1405)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:547)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1510)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java: 200)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.com mitAndResume(UnitOfWorkImpl.java:1131)
at org.eclipse.persistence.internal.jpa.transaction.EntityTrans actionImpl.commitInternal(EntityTransactionImpl.java:84)
Caused by: java.sql.SQLException: Field 'id' doesn't have a default value
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:105 5)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:956 )
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3558)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3490)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1959)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2109)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:26 48)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedSta tement.java:2077)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:2362)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:2280)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedState ment.java:2265)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAcce ssor.executeDirectNoSelect(DatabaseAccessor.java:791)
and here is the hierarchy of involved entities (without getter/setter methods):
Quote: |
@MappedSuperclass
public abstract class Biz2BankEntity {
@Id
@Basic(optional = false)
@Column(name = "id", nullable = false)
private Long id;
@Column(name = "change_time", nullable = false)
@Temporal(TemporalType.TIMESTAMP)
private Date changeTime;
@JoinColumn(name = "editor", referencedColumnName = "id", nullable = false)
@ManyToOne(optional = false)
private PersonEntity editor;
@JoinColumn(name = "tenant", referencedColumnName = "id", nullable = false)
private OrganizationEntity tenant;
Quote: |
@Entity
@EntityListeners({UpdateTimeStamp.class})
@Inheritance(strategy = InheritanceType.SINGLE_TABLE)
@DiscriminatorColumn(name = "dtype")
@DiscriminatorValue(value = "XXX")
@Table(name = "organization")
public abstract class OrganizationEntity extends Biz2BankEntity implements Serializable {
private static final long serialVersionUID = 1L;
@Column(name = "phone")
private String phone;
@Column(name = "zipcode")
private String zipcode;
@Column(name = "city")
private String city;
@Column(name = "country")
@Enumerated(EnumType.STRING)
private CountryEnum country;
@Column(name = "address")
private String address;
@Column(name = "name")
private String name;
@Column(name = "status")
private OrgStatusEnum status;
@JoinColumn(name = "parent", referencedColumnName = "id")
@ManyToOne
private OrganizationEntity parent;
@OneToMany(mappedBy = "legalEntity")
private Collection<PersonEntity> personLegalEntities;
@OneToMany(mappedBy = "roleTarget")
private Collection<PersonRoleOrganizationEntity> personRoleEntities;
private Collection<BankAccountRequestEntity> bankAccountRequestEntities;
private Collection<BankAccountEntity> bankAccountEntities;
@OneToMany(mappedBy = "parent")
private Collection<OrganizationEntity> childrenEntities;
@OneToMany( mappedBy = "tenant")
private Collection<PersonEntity> personTenantEntities;
private Collection<BankEntity> bankEntities;
the class I am trying to persist is a CompanyEntity:
Quote: |
@Entity
@DiscriminatorValue(value = "COM")
public class CompanyEntity extends OrganizationEntity implements Serializable {
any clues in the given Information?
regards, Wolfgang
Re: HistoryPolicy: INSERT Error with missing fields [message #538476 is a reply to message #537460] |
Mon, 07 June 2010 17:09 |
The issue is that EclipseLink is detecting a cycle in the foreign key references of the object. To resolve cyclic constraint dependencies EclipseLink requires to perform a "shallow" insert of the object to avoid violating foreign key constraints.
It looks like this may have issues with EclipseLink history support.
Please log a bug for this and vote for it.
In this case the shallow insert does not seem to be required, as the cycle is only with itself. Please log a bug for this as well.
To avoid the issue, first flush or commit without the reference. Then add the reference in an update.
James : Wiki : Book : Blog : Twitter
Current Time: Fri Apr 26 22:24:24 GMT 2024
Powered by FUDForum. Page generated in 0.03435 seconds
