Home » Archived » B3 » Maven2 Repositories
Maven2 Repositories [message #537153] Tue, 01 June 2010 09:25 Go to next message
has anyone tried to load a maven2 Repository with success. b3 aggregator
is loading, but never finished, even a local m2 repo.
Kind regards
Marko Espig
Re: Maven2 Repositories [message #537162 is a reply to message #537153] Tue, 01 June 2010 10:02 Go to previous messageGo to next message
How big is your repo? Could you provide a sample?
A load of a large repository is supposed to run for a reasonable time.
Filip
Marko Espig wrote:
> Kind regards
> Marko Espig
Re: Maven2 Repositories [message #540733 is a reply to message #537162] Thu, 17 June 2010 03:57 Go to previous messageGo to next message
--------------010009050708030604060208
Hi Filip,
After no success with our company repo, I tried a local repository with
about 200 MB and also tried to limit artifacts to about 18 MB. I just
added the m2 repository to an b3aggr configuration.
Thanks an kind regards
Marko
Am 01.06.2010 16:02, schrieb Filip Hrbek:
> Filip
> Marko Espig wrote:
>> Kind regards
>> Marko Espig
Content-Type: text/xml;
name="mavenRepo.b3aggr"
Content-Disposition: attachment;
filename="mavenRepo.b3aggr"
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:aggregator="http://www.eclipse.org/b3/2010/aggregator/1.0.0">
<contributions>
<repositories location="D:\development\mavenrepo_light" nature="maven2"/>
</contributions>
</aggregator:Aggregator>
--------------010009050708030604060208--
Re: Maven2 Repositories [message #540840 is a reply to message #540733] Thu, 17 June 2010 09:04 Go to previous messageGo to next message
Did that test work or fail?
- henrik
On 6/17/10 9:57 AM, Marko Espig wrote:
> Hi Filip,
> Marko
>> Filip
>> Marko Espig wrote:
>>> Hi,
>>> Kind regards
>>> Marko Espig
Re: Maven2 Repositories [message #542587 is a reply to message #540840] Fri, 25 June 2010 07:45 Go to previous messageGo to next message
I'm also having problems working with a maven repo.
The repository appears to load, but no 'Installable Units' are listed in the editor.
In the .metadata/.log, there is message for each maven artifact:
!ENTRY org.eclipse.b3.util ......
!MESSAGE org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'latest' not found. (http://ourmavenhost/groupid/artifactid/maven-metadata.xml, 7,13)
p2 side of things is working fine...
Using helios, b3 0.1.0r01053
There doesn't seem to be as much detail in the documentation for maven repos, any help is appreciated.
Kevin
Re: Maven2 Repositories [message #542625 is a reply to message #542587] Fri, 25 June 2010 09:23 Go to previous messageGo to next message
Hi Kevin,
maven integration in the b3 aggregator has not been much tested yet so any feedback is very important for us! Thank you for your report.
The problem is obviously in the maven-metadata.xml syntax. When I wrote the code I could not find any official XML schema for maven-metadata files. So I took an "unofficial" one (don't remember exactly who wrote it originally) and converted into an EMF model. This model does not contain the "latest" tag/attribute definition but your file does. That's it. My model contains "release" attribute instead. If you are sure that your files is correct I can add it to the model as an optional feature. Ideally, if you know where to find 100% correct schema for this file, send me a link :-)
Could you at least provide an example of your maven-metadata.xml file so that I could test the modification?
Filip
Kevin wrote:
> the editor.
> 'latest' not found.
> Kevin
Re: Maven2 Repositories [message #542678 is a reply to message #542625] Fri, 25 June 2010 11:28 Go to previous messageGo to next message
Hi Filip,
I had to dig to find an example but here's a good one, under the maven project ironically~:
http://repo2.maven.org/maven2/org/apache/maven/maven-core/ma ven-metadata.xml
I think the repository manager, we use archiva, is adding it to our local mirror's metadata.
Closest I could find to a 'schema' is this:
http://docs.codehaus.org/display/MAVEN/Repository+Metadata
(referenced from http://jira.codehaus.org/browse/MNG-3125)
Kevin
Re: Maven2 Repositories [message #544720 is a reply to message #540840] Mon, 05 July 2010 06:59 Go to previous messageGo to next message
It doesn't produce errors, but there are no IU's.
Marko Espig
Am 17.06.2010 15:04, schrieb Henrik Lindberg:
> - henrik
>> Hi Filip,
>> Marko
>>> Filip
>>> Marko Espig wrote:
>>>> Hi,
>>>> aggregator
>>>> Kind regards
>>>> Marko Espig
Re: Maven2 Repositories [message #548844 is a reply to message #542678] Fri, 23 July 2010 05:27 Go to previous messageGo to next message
I added support for the 'latest' feature. I also entered a new issue for merging local and downloaded metadata files (https://bugs.eclipse.org/bugs/show_bug.cgi?id=320702).
Unfortunately Eclipse hudson build does not work right now so I can't build the update site with the fix. I'll do it as soon as hudson works again.
Filip
Kevin wrote:
> Hi Filip, I had to dig to find an example but here's a good one, under the maven project ironically~:
> Kevin
Re: Maven2 Repositories [message #552860 is a reply to message #548844] Fri, 13 August 2010 16:20 Go to previous messageGo to next message
Hi Filip,
vacation is over now...
Good news about the fix, I don't see a new build here http://download.eclipse.org/modeling/emft/b3/archivedsites-3 .6/, is the build still not working?
Kevin
Re: Maven2 Repositories [message #552925 is a reply to message #552860] Sat, 14 August 2010 11:04 Go to previous messageGo to next message
Hi Kevin,
I hope you enjoyed your vacation ;-)
Please, try the new update site at http://downloads.eclipse.org/modeling/emft/b3/updates-3.7mil estones (for IDE integration) or http://downloads.eclipse.org/modeling/emft/b3/headless-3.7mi lestones (for command line). All latest builds are still compatible with the Helios release.
Let me know if it works for you or if you need more help.
Filip
Dne 13.8.2010 22:20, Kevin napsal(a):
> Hi Filip,
> Kevin
Re: Maven2 Repositories [message #608291 is a reply to message #537153] Tue, 01 June 2010 10:02 Go to previous messageGo to next message
Filip
Marko Espig wrote:
> Kind regards
> Marko Espig
Re: Maven2 Repositories [message #608555 is a reply to message #537162] Thu, 17 June 2010 03:57 Go to previous messageGo to next message
Hi Filip,
Marko
> Filip
> Marko Espig wrote:
>> Kind regards
>> Marko Espig
<contributions>
</contributions>
Re: Maven2 Repositories [message #608560 is a reply to message #540733] Thu, 17 June 2010 09:04 Go to previous messageGo to next message
- henrik
> Hi Filip,
> Marko
>> Filip
>> Marko Espig wrote:
>>> Hi,
>>> Kind regards
>>> Marko Espig
Re: Maven2 Repositories [message #611384 is a reply to message #540840] Fri, 25 June 2010 07:45 Go to previous messageGo to next message
Kevin
Re: Maven2 Repositories [message #611386 is a reply to message #542587] Fri, 25 June 2010 09:23 Go to previous messageGo to next message
Hi Kevin,
Filip
Kevin wrote:
> the editor.
> 'latest' not found.
> Kevin
Re: Maven2 Repositories [message #611388 is a reply to message #542625] Fri, 25 June 2010 11:28 Go to previous messageGo to next message
Hi Filip,
Kevin
Re: Maven2 Repositories [message #611572 is a reply to message #540840] Mon, 05 July 2010 06:59 Go to previous messageGo to next message
Marko Espig
> - henrik
>> Hi Filip,
>> Marko
>>> Filip
>>> Marko Espig wrote:
>>>> Hi,
>>>> aggregator
>>>> Kind regards
>>>> Marko Espig
Re: Maven2 Repositories [message #611605 is a reply to message #542678] Fri, 23 July 2010 05:27 Go to previous messageGo to next message
Filip
> Kevin
Re: Maven2 Repositories [message #611613 is a reply to message #548844] Fri, 13 August 2010 16:20 Go to previous messageGo to next message
Hi Filip,
Kevin
Re: Maven2 Repositories [message #611615 is a reply to message #611613] Sat, 14 August 2010 11:04 Go to previous messageGo to next message
Hi Kevin,
Filip
> Hi Filip,
> Kevin
Re: Maven2 Repositories [message #896409 is a reply to message #611615] Wed, 18 July 2012 06:19 Go to previous message
Hello everyone,
despite the age of this thread I'd like to announce, that I'm getting the same problems with maven2-repositories. I've deployed my plugins/features to a nexus oss repository manager and do not see any installable units in the editor. When I use 'install' and map the local repository, everythin seems fine.
My installation details:
0.2.0.v20120330-1440 org.eclipse.b3.aggregator.editor.feature.feature.group
0.2.0.v20110818-1257 org.eclipse.b3.p2.maven.indexer.feature.feature.group
Has anyone an idea?
Previous Topic:Aggregated repository - allow updates of mapped features
Next Topic:Can't get "Validation Repositories" working
Current Time: Wed Nov 05 14:38:35 EST 2025
Powered by FUDForum. Page generated in 0.06539 seconds
