Home » Archived » MOFScript » get external path of output
get external path of output [message #537058] Tue, 01 June 2010 04:19 Go to next message
If no path is given when defining file statement, can I get the externally defined root directory property in the transformation code? How? Thanks for any reply!
M
Re: get external path of output [message #541550 is a reply to message #537058] Mon, 21 June 2010 10:05 Go to previous message
There is no statement to do that in the language, but you can do this by
making an external java class, and call this one from MOFScript using the
java keyword.
The value is stored on the file properties of your transformation
(right-clicking the transformation will show the stored value) so you will
need to take a look at the MOFScript API.
G
Previous Topic:get external path of output
Next Topic:Subpackages URI problem
Current Time: Sat Nov 08 01:33:03 EST 2025
Powered by FUDForum. Page generated in 0.02818 seconds
