Home » Archived » Buckminster » PDE JUnit Test with buckminster headless for eclipse 3.5(Is there a way to run PDE JUnit test whith buckminster headless 1.1 for eclipse 3.5)
Re: PDE JUnit Test with buckminster headless for eclipse 3.5 [message #537557 is a reply to message #537543] |
Wed, 02 June 2010 21:12 |
Hi Charles,
Using a 3.5 target platform with Buckminster 3.6 builder is a valid scenario. Would that help you?
- thomas
On 06/02/2010 09:50 PM, Achim Demelt wrote:
> Charles,
> Unfortunately, no. JDT and PDE underwent some major refactoring early in the
> 3.6 cycle that was necessary to implement headless launching of JUnit tests.
> There is no way to make this work based on Eclipse 3.5.
> Achim
> Charles Bonneau wrote:
>> Hi !
>> We are developing plug-ins and we want to use Buckminster (with Hudson) to
>> automate the building tasks. For now, we used PDE JUnit test launch
>> configuration to test our plug-ins. Is there a way to launch these PDE
>> JUnit tests in buckminster headless 1.1 (version for eclipse 3.5) ?
>> Thank you.
>> Charles
Re: PDE JUnit Test with buckminster headless for eclipse 3.5 [message #537927 is a reply to message #537557] |
Fri, 04 June 2010 08:07 |
Carsten Reckord Messages: 139 Registered: July 2009 |
Hi Thomas, hi Charles,
Just note that in eclipse 3.6 there seem to have been some changes in the Java compiler and bundle dependencies that will make it barf on
some code that compiled fine with 3.5 [*]. So while building a 3.5 target platform with 3.6 is fine, it's probably not so great to use a
Buckminster 3.6 builder on your build server while still developing with 3.5 (but with helios waiting in the wings why would you... ;)
Carsten
*) We noted some problems with Generics, where the 3.6 compiler was a bit more picky - also more correct ;P - than 3.5. And some bundle
dependencies that strangely enough worked implicitly in 3.5 needed to be declared explicitly in 3.6 (Class could not be found but is
indirectly referenced) - again, correctly so I believe...
On 02.06.2010 23:12, Thomas Hallgren wrote:
> Hi Charles,
> - thomas
>> Charles,
>> Achim
>>> Hi !
>>> Thank you.
>>> Charles
Re: PDE JUnit Test with buckminster headless for eclipse 3.5 [message #537962 is a reply to message #537927] |
Fri, 04 June 2010 10:43 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
Do you have project specific settings for these things?
(If not - it is a really good idea as you are otherwise exposed to the
default configuration of the IDE - the errors and warnings, which Java
compliance level to use etc. are not part of the target platform.).
- henrik
> the Java compiler and bundle dependencies that will make it barf on some
> Cheers,
> Carsten
> declared explicitly in 3.6 (Class could not be found but is indirectly
>> Hi Charles,
>> - thomas
>>> Charles,
>>> in the
>>> tests.
>>> Achim
>>>> Hi !
>>>> Hudson) to
>>>> Thank you.
>>>> Charles
Re: PDE JUnit Test with buckminster headless for eclipse 3.5 [message #537995 is a reply to message #537927] |
Fri, 04 June 2010 12:44 |
This blog explains the compiler changes in detail and is perhaps useful reading.
http://lt-rider.blogspot.com/2010/05/jdt-manifest-classpath- classpath.html
- thomas
> Cheers,
> Carsten
>> Hi Charles,
>> - thomas
>>> Charles,
>>> in the
>>> tests.
>>> Achim
>>>> Hi !
>>>> Hudson) to
>>>> Thank you.
>>>> Charles
Re: PDE JUnit Test with buckminster headless for eclipse 3.5 [message #538098 is a reply to message #537995] |
Sat, 05 June 2010 01:05 |
Thanks Thomas, I had not seen that.
Good to know.
- henrik
> reading.
> - thomas
>> Cheers,
>> Carsten
>>> Hi Charles,
>>> - thomas
>>>> Charles,
>>>> in the
>>>> tests.
>>>> Achim
>>>>> Hi !
>>>>> Hudson) to
>>>>> Thank you.
>>>>> Charles
Current Time: Sat Apr 27 04:27:49 GMT 2024
Powered by FUDForum. Page generated in 0.03420 seconds
