Re: Plug-in like a project-wizard [message #537660 is a reply to message #537054] |
Thu, 03 June 2010 09:48 |
José Messages: 31 Registered: March 2010 |
Member |
I haven't found perspectivefactory on the help, but maybe it has to be with the next I'm going to say
<plugin>
<extension
id="wizard"
name="try"
point="org.eclipse.ui.newWizards">
<category
name="tryWizard"
id="wizard.category1">
</category>
<wizard
name="Your try APP"
icon="icons/wizard.gif"
category="wizard.category1"
class="com.argos.framework.TryWizard"
id="wizard.wizard1">
<description>
Make your APP
</description>
</wizard>
</extension>
</plugin>
I have the next code in the plugin.xml file. Like I have read on the help that you give me, I think I should add something like this:
<perspective
id="org.eclipse.ui.resourcePerspective"
name="Resource"
class="org.eclipse.ui.internal.ResourcePerspective"
icon="icons/MyIcon.gif">
</perspective>
inside the extension section, am I right?. I have seen in this example, resoursePerspective is access by the menu Window. What would it be for appear in the File/new/project?
Thank you so much, and I'm sorry for asking how to do the shortcut, I had misunderstanded you.
[Updated on: Thu, 03 June 2010 09:53] Report message to a moderator
FUDForum. Page generated in 0.03883 seconds
