Home » Modeling » TMF (Xtext) » Terminal Rules token definitions are unreachable
Terminal Rules token definitions are unreachable [message #537038] |
Tue, 01 June 2010 02:55  |
I am using Xtext 1.0.0 RC1 and I am working on the definition of some terminal rules inside the grammar file.
Using a terminal rule like the following, no problem.
terminal COMPONENTTYPE:
'aaaa'|'bbbb'
If I declare a terminal rule like the following one:
terminal INPUTOUTPUT:
'input'|'output'
This is the warning message that appears:
937 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for .../tdsl.Tdsl with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, FormatterFragment, LabelProviderFragment, TransformerFragment, OutlineNodeAdapterFactoryFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment
warning(208): ../tdsl/parser/antlr/internal/InternalTdsl.g:2370:1: The following token definitions are unreachable: RULE_INPUTOUTPUT
14091 [main] INFO or.validation.JavaValidatorFragment - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
warning(208): ../tdsl/ui/contentassist/antlr/internal/InternalTdsl.g:8289:1: The following token definitions are unreachable: RULE_INPUTOUTPUT
16419 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
is there any explanation to this behavior?
Re: Terminal Rules token definitions are unreachable [message #537067 is a reply to message #537038] |
Tue, 01 June 2010 04:47   |
Hi Mattia,
do you use the keyword 'input' or 'output' anywhere in your grammar
besides the terminal rule?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 01.06.10 08:55, schrieb Mattia Fazzini:
> 'aaaa'|'bbbb'
> 'input'|'output'
> warning(208):
> ../tdsl/ui/contentassist/antlr/internal/InternalTdsl.g:8289: 1: The
Re: Terminal Rules token definitions are unreachable [message #537328 is a reply to message #537089] |
Tue, 01 June 2010 21:27  |
Thank you for the information, I agree. But on the practical point of view, the DSL does not work. So, this is why I was a bit perplexed about it. However is not a problem.
Maybe a check message inside the editor should be really helpful. But I now this behavior does not depends from Xtext but from ANTLR.
Anyway thank you again.
Mattia.
Current Time: Fri Jul 04 13:48:09 EDT 2025
Powered by FUDForum. Page generated in 0.15624 seconds
