Home » Archived » BIRT » Disable generating rptdocument in WebViewerExample
Disable generating rptdocument in WebViewerExample [message #536823] Mon, 31 May 2010 03:52 Go to next message
i am using the WebViewerExample in BIRT 2.5.2.
Is it possible to disable generating the rptdocument file in there?
I got for each generated report a file like " WebViewerExample\documents\BIRTDOC62864D09812C9924ED10568E3B A13034\20100531_093449_546\WebViewerExample\test.rptdocument " when i call the report by " http://localhost:8080/WebViewerExample/frameset?__report=tes t.rptdesign&sample=my+parameter".
The problem is, i have a lot of different reports, and every report seems to be hold in memory. So when i use the WebViewerExample for many days, the memory rise up until Windows swaps (Tomcat6.exe uses up tp 361MB in memory on a machine with 512MB RAM).
I have a lot of different reports, because i modify the SqlQuery from each report, before running them. And for each batch i am running, i generate a report like MyReport_BatchNumber123.rptdesign. That works better for me, because the sql queries got influences from another application.
Now i got for each report, MyReport_BatchNumber123, MyReport_BatchNumber124 and so on a rptdocument file in WebViewerExample/documents and the memory rises up until swaps.
If you have any questions, please ask me.
//Edit: Sorry, i have to correct myself. Each run on the test.rptdesign ( from WebViewerExample ) do generate a rptdocument file. So when i call " http://localhost:8080/WebViewerExample/output?__report=test. rptdesign&sample=my+parameter" for example an press F5 i have many directories like "20100531_101512_390" and so on. How could i disable this?
//Edit2: Here is my small example to test memory rising
<html>
<head>
<script type="text/javascript" src="jquery-1.4.2.min.js"></script>
<script type="text/javascript">
reloadPage = function()
	window.location.reload();
$(document).ready(
		function ()
			window.setTimeout("reloadPage()", 1000);
</script>
</head>
<body>
<iframe id="_report" name="_report" src="http://localhost:8080/WebViewerExample/output?__report=test.rptdesign&sample=my+parameter" height="480" width="640"></iframe>
</body>
</html>
I am running that test since ~30 minutes and the memory has rised from 141MB to 162MB. And the documents folder contains about 1.000 folders.
Tom
[Updated on: Mon, 31 May 2010 05:19] by Moderator
Re: Disable generating rptdocument in WebViewerExample [message #537195 is a reply to message #536823] Tue, 01 June 2010 10:57 Go to previous message
You can use /run instead of /frameset, but if you want pagination in the
HTML output it has to create the rptdocument. You can always specify
the rptdocument to create by adding the __document=pathtodocument if you
want to re-use one.
Jason
On 5/31/2010 3:52 AM, Tom wrote:
> Hello,
> call the report by
> application.
> Best regards,
> Tom
Previous Topic:how regroup same elements in same category on chart
Next Topic:Installing Birt viewer Resolved with birt 2.6.0
Current Time: Mon Sep 22 05:59:17 EDT 2025
Powered by FUDForum. Page generated in 0.19444 seconds
