Home » Newcomers » Newcomers » Disable all auto formating for java(Disable all auto formating for java)
Disable all auto formating for java [message #536499] Fri, 28 May 2010 09:59 Go to next message
How do I disable 'ALL' auto/smart formating for the java editor.
I can type faster and with more efficiency then the editor trying to read my mind.
Re: Disable all auto formating for java [message #536748 is a reply to message #536499] Sun, 30 May 2010 13:05 Go to previous messageGo to next message
Uncheck Edit > Smart Insert Mode. (you have to do this for every editor)
> read my mind.
are you sure? ;-)
Deepak
Re: Disable all auto formating for java [message #537176 is a reply to message #536748] Tue, 01 June 2010 10:47 Go to previous messageGo to next message
Already tried and it doesn't solve the problem.
> are you sure? ;-)
After 20 + years if I can't type faster I shouldn't be a programer.
Re: Disable all auto formating for java [message #538502 is a reply to message #537176] Mon, 07 June 2010 14:50 Go to previous messageGo to next message
>> are you sure? ;-)
Hah, I couldn't disagree more. Programming well has nothing to do with
how fast or how little you can type. It has to do with how well you can
structure solutions to requirements and problems.
But to be more helpful... can you specify exactly what things the editor
is doing that you'd like to turn off? There might be other options that
need to be disabled in the preferences.
Eric
Re: Disable all auto formating for java [message #538513 is a reply to message #538502] Mon, 07 June 2010 15:46 Go to previous messageGo to next message
if statements and the like auto indenting after hitting enter.
Any auto indenting.
Auto adding ')' after intelliSence selection.
Comments auto indenting and adding *'s after hitting enter.
IE
/* <ENTER>
does
Re: Disable all auto formating for java [message #734095 is a reply to message #538513] Thu, 06 October 2011 12:19 Go to previous messageGo to next message
@"No Real Name": I sympathize. It's obvious that a LOT of work went into this feature, and I don't mean to minimize it's value to the masses. However, not ALL programmers desire this functionality.
The point is that it's a feature that's being shoved down everybody's throats, much the same way Microsoft does things. In addition, it's obviously pretty simple to turn on and off on a per-file basis, so why would a global option be so difficult?
For these reasons, I don't understand the resistance to make it optional and have the ability to globally disable it. "WONTFIX" - Really?
Re: Disable all auto formating for java [message #734109 is a reply to message #538513] Thu, 06 October 2011 13:37 Go to previous messageGo to next message
[This followup was posted to eclipse.newcomer and a copy was sent to the
cited author.]
In article <hujia5$hac$1@build.eclipse.org>, tmp@lock4.com says...
> Any auto indenting.
> IE
> /* <ENTER>
> does
No auto indenting??? Really??? I agree with eliminating the trailing
")" after intelli-sense inserting; it's wrong far more than it's right,
but the auto indenting is a huge time-saver, IMO.
Re: Disable all auto formating for java [message #734125 is a reply to message #734109] Thu, 06 October 2011 15:28 Go to previous messageGo to next message
> cited author.]
> In article<hujia5$hac$1@build.eclipse.org>, tmp@lock4.com says...
>> Any auto indenting.
>> IE
>> /*<ENTER>
>> does
By the way, David. Is it possible to eliminate that trailing paren? How
is this done? Thanks.
Re: Disable all auto formating for java [message #734204 is a reply to message #734125] Thu, 06 October 2011 22:46 Go to previous message
You can configure the 'Smart typing' features at 'Preferences > Java
Editor > Typing' preference page.
Previous Topic:Eclipse to replicate oxygen XML functionality
Next Topic:Eclipse Indigo: debug on remote Tomcat server
Current Time: Fri Sep 12 11:07:57 EDT 2025
Powered by FUDForum. Page generated in 0.07400 seconds
