| Using GMF and dynamic EMF with EEnumLiteral [message #536480] |
Fri, 28 May 2010 08:50  |
Hello everyone !
I would like to add more flexibility to my Ecore model by using dynamic EMF capability. One of my Ecore classes is called Decision and has a decisionType attribute of type DecisionType which is an EEnum with no literals.
I add literals to the EEnum by program when my GMF-based graphical editor starts up. When I select a Decision instance graphical object in the editor, a combo-box in the Properties view lets me select a value for the decisionType attribute; but instead of getting foo, bar, ding as combo-box displayed values, I get foo=0, bar=1 and ding=2. This would be acceptable, although not very nice, but the main issue is that whatever the selected value is, the decisionType property is never set. Could you please tell me what I am missing ?
Thanks a lot in advance for your time !
Georges
| Re: Using GMF and dynamic EMF with EEnumLiteral [message #536492 is a reply to message #536480] |
Fri, 28 May 2010 09:06   |
Georges,
Comments below.
Georges wrote:
> Hello everyone !
> with no literals.
> editor starts up.
A generated model should not be dynamically modified. This just isn't
supported. Are you really saying you have a generated empty Java
enumeration?
> Georges
| Re: Using GMF and dynamic EMF with EEnumLiteral [message #536568 is a reply to message #536515] |
Fri, 28 May 2010 12:31   |
Georges,
Comments below.
Georges wrote:
> Hello Ed,
> Yes, my generated Java enumeration was initially empty. I have
> slightly modified it by adding a default "None" literal which value is 0.
> After getting your reply, I have read again the Dynamic EMF chapter of
> the EMF book and found this : "Even when using dynamic EMF, once we
> begin instantiating the model, it is no longer safe to change it."
> Should I create a dynamic class or enum that extends a generated one
Enums aren't extensible.
> , and add additional features there, like suggested in the book ?
A dynamic package with an extending class with a feature of some dynamic
enum also from that package would make sense.
> Best regards,
> Georges
| Re: Using GMF and dynamic EMF with EEnumLiteral [message #537019 is a reply to message #536934] |
Mon, 31 May 2010 19:23  |
Georges,
GMF's Tooling is heavily focused on generating what's needed. I'm not
even sure it works with dynamic models. E.g., I don't think there is a
GMF reflective editor. Someone more familiar will need to comment.
Georges wrote:
> Hello Ed,
> I am still trying to implement dynamically a part of my EMF model so
> that I can set dynamic attributes values through combo-boxes in the
> Properties view of my graphical editor.
> I dynamically extend the Decision class with a DynamicDecision one and
> I add a decisionType attribute to the derived class. The type of the
> decisionType attribute is DecisionType which is a dynamic EEnum.
> If Decision had no attribute, I couldn't map anything from GMF to
> Decision. So, I suppose I should add an attribute to the Decision
> class. Am I wrong ? If an attribute is necessary, what type should
> this attribute be set to since we do not know the type of the
> attribute which will be dynamically added to the derived class ?
> Could you (or someone else, since this is mainly a GMF-related
> question) clarify the Dynamic-EMF / GMF relationship, please ?
> Georges
FUDForum. Page generated in 0.07078 seconds
