Home » Language IDEs » C / C++ IDE (CDT) » Embedded Debugging with Eclipse and Abatron BDI2000
Embedded Debugging with Eclipse and Abatron BDI2000 [message #536023] Wed, 26 May 2010 12:34
Hi All
I've got a MIPS target with an Abatron BDI2000. I've been using
sde-insight as a debugger, but would like to use Eclipe instead. I've
got the Galileo C/C++ IDE installed and thought I'd be able to use it
as is, but I haven't managed to find a debug configuration that works
having tried the standard launcher, the DSF local thingy and the
remote one.
Is there any way to get this to work or do I need to use the Zylin
plugin or something like that?
Thanks for your help.
John
Previous Topic:Building the source code of CDT 6.0
Next Topic:Help with setup
Current Time: Thu Nov 06 10:58:46 EST 2025
Powered by FUDForum. Page generated in 0.02816 seconds
