MenuBar [message #536012] |
Wed, 26 May 2010 12:04  |
I have a menu bar and can't work around 2 problems:
1. shell.pack() seems to ignore the width of the menu bar. Is that correct and is there a way around that?
2. If I accidentally double-click on one of the items in the menu bar, the program hangs. Is there a way to get a double-click ignored?
Re: MenuBar [message #536068 is a reply to message #536048] |
Wed, 26 May 2010 16:48   |
I think the problem I'm having is that I'm dynamically creating the menu using menuShown, and there isn't enough time to do it between the double-clicks. In the main below, the top level item Top2 dynamically creates 500 items. If you run the code, you'll see bizarre behavior when you double-click Top2.
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.MenuAdapter;
import org.eclipse.swt.events.MenuEvent;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.swt.widgets.Shell;
public class DoubleClick {
public static void main(final String[] args) {
final Shell shell = new Shell(Display.getDefault());
final SelectionListener topSl = new SelectionListener() {
public void widgetDefaultSelected(final SelectionEvent arg0) {
public void widgetSelected(final SelectionEvent arg0) {
System.out.println("Selected: Top " + arg0.getSource());
final SelectionListener lowSl = new SelectionListener() {
System.out.println("Selected: Sub " + arg0.getSource());
final Menu menuBar = new Menu(shell, SWT.BAR);
for (int i = 0; i < 3; i++) {
final int finalI = i;
final MenuItem topItem = new MenuItem(menuBar, SWT.CASCADE);
topItem.setText("Top" + i);
topItem.addSelectionListener(topSl);
if (i == 0) {
} else if (i == 1) {
final Menu topDropDown = new Menu(shell, SWT.DROP_DOWN);
topItem.setMenu(topDropDown);
final MenuItem subItem = new MenuItem(topDropDown, SWT.CASCADE);
subItem.setText("subItem0");
subItem.addSelectionListener(lowSl);
} else if (i == 2) {
topDropDown.addMenuListener(new MenuAdapter() {
public void menuShown(final MenuEvent e) {
/** Get rid of existing menu items */
final MenuItem[] items = topDropDown.getItems();
for (final MenuItem item : items) {
item.dispose();
/** Create the new ones. */
for (int k = 0; k < 500; ++k) {
final int finalK = k;
subItem.setText("subItem" + finalI + ": " + finalK);
shell.setMenuBar(menuBar);
shell.setSize(new Point(300, 60));
// shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!Display.getDefault().readAndDispatch())
Display.getDefault().sleep();
public static void ludgarMain(final String[] args) {
final SelectionListener l = new SelectionListener() {
System.out.println("Selected: " + arg0.getSource());
final Menu menu = new Menu(shell, SWT.BAR);
final MenuItem topItem = new MenuItem(menu, SWT.CASCADE);
topItem.setText("Item" + i);
topItem.addSelectionListener(l);
if (i % 2 == 0) {
subItem.setText("subItem");
subItem.addSelectionListener(l);
shell.setMenuBar(menu);
shell.pack();
shell.open();
Antw: Re: Re: MenuBar [message #536406 is a reply to message #536265] |
Fri, 28 May 2010 00:52  |
Originally posted by: Ludger.Heisterkamp.gds.eu
Hello Thomas,
the behavoir you are describing now is not bizarre to me:
The first click starts generating the menu, the second click event is
processed when generating has finished and clicks on the generated new menu.
This is not only related to a doubleclick, even two single clicks during the
menu generating time cause the same behavior.
In your first post, you were writing "If I accidentally double-click on one
of the items in the menu bar, the program hangs." This sounds like a strange
behaviour, but is not reproducible for me.
The only way around your doubleclick problem would be, that the submenu
generating process has been finished before you click on the main menu item,
e.g. in a background process. This depends on your application logic.
Ludger Heisterkamp
> I'm running on Windows XP. My machine is 2.79GHz. Perhaps you should
> change the 500 to 5000 in the code.
> The bizarre behavior that I'm seeing is:
> The submenu items have a different listener than the top menu items;
> both are system.out's, but they print different things. When I
> double-click the "heavy menu," the submenu's listener gets called (after
> a pause).
> I appreciate your looking at this. Thanks
FUDForum. Page generated in 0.03503 seconds
