Home » Eclipse Projects » Nebula » gantt in RCP
Re: gantt in RCP [message #535455 is a reply to message #535433] |
Sun, 23 May 2010 17:53 |
Mauro Condarelli Messages: 428 Registered: September 2009 |
I just dropped the org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar
file in my project and added it to properties -> Java Build Path ->
Libraries -> Add JARs...
What do You exactly mean by "Did you forget to update your launch config?"?
I also tried to install it "properly" in eclipse, but without an update
site it will refuse to acknowledge the plugin.
Any suggestion?
TiA
Mauro
P.S.:
AAAARRRRGGGHHHHH!
I did something real wrong!
My app refuses to start at all with the following error:
!SESSION 2010-05-23 19:47:15.672
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -product Writer.product
Command-line arguments: -product Writer.product -data
C:\Users\mauro\workspace/../runtime-Writer.product(1) -dev
file:C:/Users/mauro/workspace/.metadata/.plugins/org.eclipse .pde.core/Writer.product
(1)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-05-23 19:47:16.783
!MESSAGE Product Writer.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2010-05-23 19:47:16.811
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
at
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Obviously Writer.product IS there.
I will re-fetch LatKnownGood from SVN
Any idea what went wrong?
Mauro
On 23/05/2010 15.09, Tom Schindl wrote:
> How did you included the Gant chart into your RCP? Did you forget to
> Beside that the thing you downloaded is already a OSGi-Bundle so no need
> to OSGify it any more - simply drop it into your Target-Platform and you
> can use it.
> Tom
> Am 23.05.10 14:49, schrieb Mauro Condarelli:
>> Hi,
>> I am most likely missing the obvious (shame on me).
>> I would like to use the gantt widget in my RCP app.
>> Unfortunately it seems my app is not able to find the classes.
>> I get the error:
>> !MESSAGE Missing required bundle gantt_1.0.0.
>> The bundle "gantt_1.0.0" was built downloading the NIGHTLY builds from
>> http://www.hexapixel.com/files/nightly/ and then File-> New ->
>> Project...-> Plug-in Development -> Plug-in from existing JAR archives.
>> I actually tried several things, but the result is always the same:
>> I can successfully run standalone test programs, but I cannot run my RCP
>> app.
>> I am (obviously!) ready to give any info deemed useful.
>> Pretty please someone point me in the right direction!.
>> Regards and Thanks in Advance
>> Mauro
Re: gantt in RCP [message #535512 is a reply to message #535455] |
Mon, 24 May 2010 08:06 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Am 23.05.10 19:53, schrieb Mauro Condarelli:
This is obviously wrong! If you have to add JARs to a OSGI-Bundle you
need to do this using the MANIFEST.MF (Runtime > Classpath section).
You need to update your .product-File and recreate your Launch Config or
update your existing one (Run > Run Configuration)
Did you tried to launch with -clean afterwards? Beside that installing
stuff into your IDE simply because your RCP needs it is a bad thing
IMHO. You should learn about setting up a Target which is quite easy.
1. Create a Folder on your system (e.g. C:/eclipse-target/v1.0/)
2. Put your org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar in
there
3. Window > Properties > Plug-in Development > Add ...
4. Select "Current Target: Copy ..." and Next
5. Click Add ..., Select Directory and Next
6. Browse and select C:/eclipse-target/v1.0/
7. Finish
Now you can add ganttchart-2.0 as a dependency on your MANIFEST.MF,
update your .product, recreate your launch config
> Any suggestion?
> TiA
> Mauro
> P.S.:
> AAAARRRRGGGHHHHH!
> !STACK 1
> at
> at
> at
> at
> at
> at
My wild guess is that the Bundle with the Writer.product is not able to
get started. You should validate your "Launch Configuration" and see if
every thing is resolved.
> Regards
> Mauro
>> Hi,
>> can use it.
>> Tom
>>> Hi,
>>> I get the error:
>>> archives.
>>> app.
>>> Mauro
Re: gantt in RCP [message #535523 is a reply to message #535512] |
Mon, 24 May 2010 09:10 |
Thanks Tom
It works now.
just to be sure I understand You (and the way eclipse is supposed to work):
You mean I should *NOT* install in the IDE additional components I need
in my RCP; I should create Target configuration(s) instead, right?
I need a spell checker in my app and I installed it in the IDE, but that
interferes badly with the default Java speller. I assume I can uninstall
it and move the associated .jar files to Target. Is this correct?
On the same wavelength: I found two spellcheckers for eclipse:
hunspell4eclipse and eSpell3; both do not seem to fully work for me (in
different ways). What is the "advised" spell-checker for non-English
languages? (I'm Italian).
Regards and Many Thanks
Mauro
On 24/05/2010 10.06, Tom Schindl wrote:
> need to do this using the MANIFEST.MF (Runtime> Classpath section).
> update your existing one (Run> Run Configuration)
> there
> 3. Window> Properties> Plug-in Development> Add ...
> 7. Finish
>> Any suggestion?
>> TiA
>> Mauro
>> P.S.:
>> AAAARRRRGGGHHHHH!
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Regards
>> Mauro
>>> Hi,
>>> can use it.
>>> Tom
>>>> Hi,
>>>> I get the error:
>>>> archives.
>>>> app.
>>>> Mauro
Re: gantt in RCP [message #535541 is a reply to message #535523] |
Mon, 24 May 2010 11:16 |
On 24/05/2010 11.10, Mauro Condarelli wrote:
> Thanks Tom
> It works now.
Sorry.
Not true.
org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar is not recognized
as a plugin.
I had to File -> new -> Project Plug-in from Existing JAR Archives; Then
ExportWizard to produce my own gantt_1.0.0.jar
Only at this point I have been able to add the new Target with some
sensible content.
What am I missing?
Mauro
> Mauro
>> Hi,
>>> config?"?
>> there
>> 7. Finish
>>> Any suggestion?
>>> TiA
>>> Mauro
>>> P.S.:
>>> AAAARRRRGGGHHHHH!
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Regards
>>> Mauro
>>>> Hi,
>>>> need
>>>> you
>>>> can use it.
>>>> Tom
>>>>> Hi,
>>>>> I get the error:
>>>>> archives.
>>>>> my RCP
>>>>> app.
>>>>> Mauro
Re: gantt in RCP [message #599645 is a reply to message #535433] |
Any suggestion?
TiA
Mauro
P.S.:
AAAARRRRGGGHHHHH!
!STACK 1
at
at
at
at
at
at
Mauro
> can use it.
> Tom
>> Hi,
>> I get the error:
>> app.
>> Mauro
Re: gantt in RCP [message #599651 is a reply to message #535455] |
there
7. Finish
> Any suggestion?
> TiA
> Mauro
> P.S.:
> AAAARRRRGGGHHHHH!
> !STACK 1
> at
> at
> at
> at
> at
> at
> Regards
> Mauro
>> Hi,
>> can use it.
>> Tom
>>> Hi,
>>> I get the error:
>>> archives.
>>> app.
>>> Mauro
Re: gantt in RCP [message #599658 is a reply to message #535512] |
Thanks Tom
It works now.
Mauro
> there
> 7. Finish
>> Any suggestion?
>> TiA
>> Mauro
>> P.S.:
>> AAAARRRRGGGHHHHH!
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> Regards
>> Mauro
>>> Hi,
>>> can use it.
>>> Tom
>>>> Hi,
>>>> I get the error:
>>>> archives.
>>>> app.
>>>> Mauro
Re: gantt in RCP [message #599676 is a reply to message #535523] |
> Thanks Tom
> It works now.
Sorry.
Not true.
as a plugin.
sensible content.
What am I missing?
Mauro
> Mauro
>> Hi,
>>> config?"?
>> there
>> 7. Finish
>>> Any suggestion?
>>> TiA
>>> Mauro
>>> P.S.:
>>> AAAARRRRGGGHHHHH!
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Regards
>>> Mauro
>>>> Hi,
>>>> need
>>>> you
>>>> can use it.
>>>> Tom
>>>>> Hi,
>>>>> I get the error:
>>>>> archives.
>>>>> my RCP
>>>>> app.
>>>>> Mauro
Current Time: Fri Apr 26 06:00:41 GMT 2024
Powered by FUDForum. Page generated in 0.04407 seconds
