Home » Eclipse Projects » Nebula » gantt in RCP
| gantt in RCP [message #535429] |
Sun, 23 May 2010 08:49  |
I am most likely missing the obvious (shame on me).
I would like to use the gantt widget in my RCP app.
Unfortunately it seems my app is not able to find the classes.
I get the error:
!MESSAGE Missing required bundle gantt_1.0.0.
The bundle "gantt_1.0.0" was built downloading the NIGHTLY builds from
http://www.hexapixel.com/files/nightly/ and then File-> New ->
Project...-> Plug-in Development -> Plug-in from existing JAR archives.
I actually tried several things, but the result is always the same:
I can successfully run standalone test programs, but I cannot run my RCP
app.
I am (obviously!) ready to give any info deemed useful.
Pretty please someone point me in the right direction!.
Regards and Thanks in Advance
Mauro
| Re: gantt in RCP [message #535455 is a reply to message #535433] |
Sun, 23 May 2010 13:53   |
I just dropped the org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar
file in my project and added it to properties -> Java Build Path ->
Libraries -> Add JARs...
What do You exactly mean by "Did you forget to update your launch config?"?
I also tried to install it "properly" in eclipse, but without an update
site it will refuse to acknowledge the plugin.
Any suggestion?
TiA
Mauro
P.S.:
AAAARRRRGGGHHHHH!
I did something real wrong!
My app refuses to start at all with the following error:
!SESSION 2010-05-23 19:47:15.672
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -product Writer.product
Command-line arguments: -product Writer.product -data
C:\Users\mauro\workspace/../runtime-Writer.product(1) -dev
file:C:/Users/mauro/workspace/.metadata/.plugins/org.eclipse .pde.core/Writer.product
(1)/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-05-23 19:47:16.783
!MESSAGE Product Writer.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2010-05-23 19:47:16.811
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Obviously Writer.product IS there.
I will re-fetch LatKnownGood from SVN
Any idea what went wrong?
Mauro
On 23/05/2010 15.09, Tom Schindl wrote:
> How did you included the Gant chart into your RCP? Did you forget to
> Beside that the thing you downloaded is already a OSGi-Bundle so no need
> to OSGify it any more - simply drop it into your Target-Platform and you
> can use it.
> Tom
> Am 23.05.10 14:49, schrieb Mauro Condarelli:
>> I get the error:
>> app.
>> Mauro
| Re: gantt in RCP [message #535512 is a reply to message #535455] |
Mon, 24 May 2010 04:06   |
Am 23.05.10 19:53, schrieb Mauro Condarelli:
This is obviously wrong! If you have to add JARs to a OSGI-Bundle you
need to do this using the MANIFEST.MF (Runtime > Classpath section).
You need to update your .product-File and recreate your Launch Config or
update your existing one (Run > Run Configuration)
Did you tried to launch with -clean afterwards? Beside that installing
stuff into your IDE simply because your RCP needs it is a bad thing
IMHO. You should learn about setting up a Target which is quite easy.
1. Create a Folder on your system (e.g. C:/eclipse-target/v1.0/)
2. Put your org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar in
there
3. Window > Properties > Plug-in Development > Add ...
4. Select "Current Target: Copy ..." and Next
5. Click Add ..., Select Directory and Next
6. Browse and select C:/eclipse-target/v1.0/
7. Finish
Now you can add ganttchart-2.0 as a dependency on your MANIFEST.MF,
update your .product, recreate your launch config
> Any suggestion?
> TiA
> Mauro
> P.S.:
> AAAARRRRGGGHHHHH!
> !STACK 1
> at
> at
> at
> at
> at
> at
My wild guess is that the Bundle with the Writer.product is not able to
get started. You should validate your "Launch Configuration" and see if
every thing is resolved.
> Regards
> Mauro
>> can use it.
>> Tom
>>> Hi,
>>> I get the error:
>>> archives.
>>> app.
>>> Mauro
| Re: gantt in RCP [message #535523 is a reply to message #535512] |
Mon, 24 May 2010 05:10   |
Thanks Tom
It works now.
just to be sure I understand You (and the way eclipse is supposed to work):
You mean I should *NOT* install in the IDE additional components I need
in my RCP; I should create Target configuration(s) instead, right?
I need a spell checker in my app and I installed it in the IDE, but that
interferes badly with the default Java speller. I assume I can uninstall
it and move the associated .jar files to Target. Is this correct?
On the same wavelength: I found two spellcheckers for eclipse:
hunspell4eclipse and eSpell3; both do not seem to fully work for me (in
different ways). What is the "advised" spell-checker for non-English
languages? (I'm Italian).
Regards and Many Thanks
Mauro
On 24/05/2010 10.06, Tom Schindl wrote:
> need to do this using the MANIFEST.MF (Runtime> Classpath section).
> update your existing one (Run> Run Configuration)
> there
> 3. Window> Properties> Plug-in Development> Add ...
> 7. Finish
>> Any suggestion?
>> TiA
>> Mauro
>> P.S.:
>> AAAARRRRGGGHHHHH!
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Regards
>> Mauro
>>> Hi,
>>> can use it.
>>> Tom
>>>> Hi,
>>>> I get the error:
>>>> archives.
>>>> app.
>>>> Mauro
| Re: gantt in RCP [message #535541 is a reply to message #535523] |
Mon, 24 May 2010 07:16  |
On 24/05/2010 11.10, Mauro Condarelli wrote:
> Thanks Tom
> It works now.
Sorry.
Not true.
org.eclipse.nebula.widgets.ganttchart-2.0-NIGHTLY.jar is not recognized
as a plugin.
I had to File -> new -> Project Plug-in from Existing JAR Archives; Then
ExportWizard to produce my own gantt_1.0.0.jar
Only at this point I have been able to add the new Target with some
sensible content.
What am I missing?
Mauro
> Mauro
>>> config?"?
>> there
>> 7. Finish
>>> Any suggestion?
>>> TiA
>>> Mauro
>>> P.S.:
>>> AAAARRRRGGGHHHHH!
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Regards
>>> Mauro
>>>> Hi,
>>>> need
>>>> you
>>>> can use it.
>>>> Tom
>>>>> Hi,
>>>>> I get the error:
>>>>> archives.
>>>>> my RCP
>>>>> app.
>>>>> Mauro
| Re: gantt in RCP [message #599636 is a reply to message #535429] |
Sun, 23 May 2010 09:09  |
can use it.
Tom
> I get the error:
> app.
> Mauro
| Re: gantt in RCP [message #599645 is a reply to message #535433] |
Any suggestion?
TiA
Mauro
P.S.:
AAAARRRRGGGHHHHH!
!STACK 1
Mauro
> can use it.
> Tom
>> I get the error:
>> app.
>> Mauro
| Re: gantt in RCP [message #599651 is a reply to message #535455] |
there
7. Finish
> Any suggestion?
> TiA
> Mauro
> P.S.:
> AAAARRRRGGGHHHHH!
> !STACK 1
> at
> at
> at
> at
> at
> at
> Regards
> Mauro
>> can use it.
>> Tom
>>> Hi,
>>> I get the error:
>>> archives.
>>> app.
>>> Mauro
| Re: gantt in RCP [message #599658 is a reply to message #535512] |
Thanks Tom
It works now.
Mauro
> there
> 7. Finish
>> Any suggestion?
>> TiA
>> Mauro
>> P.S.:
>> AAAARRRRGGGHHHHH!
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> Regards
>> Mauro
>>> Hi,
>>> can use it.
>>> Tom
>>>> Hi,
>>>> I get the error:
>>>> archives.
>>>> app.
>>>> Mauro
| Re: gantt in RCP [message #599667 is a reply to message #535523] |
Mon, 24 May 2010 05:38  |
Am 24.05.10 11:10, schrieb Mauro Condarelli:
> Thanks Tom
> It works now.
Yes this is the way to go. Beside the thing you mention below it allows
you to develop multiple different applications who need different
targets (e.g. you need to maintain a RCP written on 3.2 and one on 3.4, ...)
Yes.
I think you should ask this question on the newcomer or the
platform-newsgroup
Tom
| Re: gantt in RCP [message #599676 is a reply to message #535523] |
> Thanks Tom
> It works now.
Sorry.
Not true.
as a plugin.
sensible content.
What am I missing?
Mauro
> Mauro
>>> config?"?
>> there
>> 7. Finish
>>> Any suggestion?
>>> TiA
>>> Mauro
>>> P.S.:
>>> AAAARRRRGGGHHHHH!
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Regards
>>> Mauro
>>>> Hi,
>>>> need
>>>> you
>>>> can use it.
>>>> Tom
>>>>> Hi,
>>>>> I get the error:
>>>>> archives.
>>>>> my RCP
>>>>> app.
>>>>> Mauro
Current Time: Sun Nov 09 20:17:32 EST 2025
Powered by FUDForum. Page generated in 0.22371 seconds
