Re: Web Project Composed of various svn resources [message #535554 is a reply to message #535331] |
Mon, 24 May 2010 12:46 |
On 5/22/2010 7:02 AM, Dmitri Sidelnikov wrote:
> Hi all.
> Out web project has completely different layout in SVN than Eclipse
> suppose. So I can not just checkout project from SVN. I need to compose
> Eclipse Dynamic Web Project of various SVN resources (web content
> folders, java code folders, web static resource folders etc.)
> Is it possible?
> Best regards,
> Dmitri
You should be able to create a new Dynamic Web Project and change to
getting the source from wherever you have checked it out from Subversion.
When you use that wizard to create the proejct, you'll want to rename
WebContent to be whatever your existing code uses.
Your Java code should be in paths dominated by 'src' but if not, you can
right-click on the project after creation and add the folders you do
have as Source Folders.
Hope this helps,
Russ Bateman
Re: Web Project Composed of various svn resources [message #536648 is a reply to message #535331] |
Sat, 29 May 2010 09:41 |
Dmitri Sidelnikov Messages: 3 Registered: July 2009 |
Russell, thanks for your reply.
I can change WebContent name, but I can not find how to change the place where the WebContent sources getting from. Should I use import from file system and overwrite WebContent?
Also I can add java sources to project, and that sources are from SVN (.svn directories are present), but Project Team capabilities are turned off (except "Share..." and "Apply patch"). It seems that project does not "know" that I use SVN for some resources in project.
This is completely unusable. I used to work with IntelliJ IDEA and IDEA lets developer compose project structure from file system sources freely. In IDEA Project description files (.iml etc.) and resources (java files, web content etc.) are completely separated. Now a have to use Eclipse and this killing me.
The main point is that we does not store project special(service) files (.iml, .project, .classpath) in SVN, just resources (jars, java code, web resources).
Can anybody help with this? Is it possible or not?
Dmitri
FUDForum. Page generated in 0.04229 seconds
