Home » Eclipse Projects » Eclipse 4 » XWT fails to load x:Class class
XWT fails to load x:Class class [message #535287] |
Fri, 21 May 2010 21:30 |
Swavek Messages: 20 Registered: March 2010 |
I created a small plugin project which has a simple Composite with two buttons. I created a SelectionEvent handler for one of the buttons. Without this handler the Composite appears to load fine, but as soon as I add the event handler in .xwt it fails to load. Turns out if fails to load the class containing the event handler which is specified in x:Class.
Is this a known limitation or a bug?
Here is the XWT file
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:networkeditor.config.ui"
xmlns:j="clr-namespace:java.lang" x:Class="networkeditor.config.ui.MyConfigDialog"
x:DataContext="networkeditor.config.ui.MyConfigData">
<Composite.layout>
<GridLayout numColumns="2" />
</Composite.layout>
<Button x:style="SWT.PUSH" text="Push Me" SelectionEvent="performSelectionEvent"></Button>
<Button x:style="SWT.PUSH" text="Don't push me"></Button>
</Composite>
Here is the Java class.
package networkeditor.config.ui;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
public class MyConfigDialog extends Composite {
public MyConfigDialog(Composite parent, int style) {
super(parent, style);
// TODO Auto-generated constructor stub
protected void performSelectionEvent (Event event) {
MessageDialog.openInformation(getShell(), "Title", "you pushed me");
And here is the data context class.
public class MyConfigData {
Here is how I invoke it.
public static void main (String [] args) {
try {
URL file = MyConfigData.class.getResource("/networkeditor/config/ui/MyConfigDialog.xwt ");
XWT.open(file);
} catch (Exception e) {
e.printStackTrace();
BTW, When I press the Preview button in the XWT file editor (in XWT perspective) the event handler is invoked correctly. So there is something that I am not doing correctly.
I tried passing parent composite so that ILoadingContext is set differently.
I exported the package containing these classes via MANIFEST.MF.
I changed Eclipse-BuddyPolicy: global (although it shouldn't help in theory)
I checked the Eclipse-BuddyPolicy in org.eclipse.e4.xwt and it is not set so I don't know how the xwt plugin loads these classes. I am using ver 0.9.1 from 2010 04 06.
XWT simply can't load the MyConfigDialog class.
Any help will be appreciated.
Swavek
[Updated on: Tue, 25 May 2010 19:34] Report message to a moderator
Re: XWT fails to load x:Class class [message #535820 is a reply to message #535287] |
Tue, 25 May 2010 19:42 |
After looking into how the new XWT designer performs class loading, I tried to load to specify the classloader that XWT should be using. Now it works when I run within Eclipse. I used an alternative load method which takes the parent component, input stream and url to load.
Composite configPanelsContainer = new Composite(container, SWT.NONE);
StackLayout stackLayout = new StackLayout();
configPanelsContainer.setLayout(stackLayout);
String configURLString = "/networkeditor/config/ui/MyConfigDialog.xwt";
URL configPanelURL = getClass().getClassLoader().getResource(configURLString);
InputStream inputStream = getClass().getClassLoader().getResourceAsStream(configURLStr ing);
// load it
configPanel = XWT.load(configPanelsContainer, inputStream, configPanelURL, getDataContext());
However when I try to run my app after exporting from Eclipse environment the loading of the xwt file doesn't work . I get this exception:
!ENTRY com.infogix.dptoolcatalog 4 1 2010-05-25 14:31:36.552
!MESSAGE my error
!STACK 0
java.io.FileNotFoundException: /networkeditor/config/ui\MyConfigDialog.xwt
at org.eclipse.osgi.framework.internal.protocol.bundleresource. Handler.findBundleEntry(Handler.java:51)
at org.eclipse.osgi.framework.internal.core.BundleResourceHandl er.openConnection(BundleResourceHandler.java:175)
at java.net.URL.openConnection(Unknown Source)
at java.net.URL.openStream(Unknown Source)
at org.eclipse.e4.xwt.internal.xml.DocumentRoot.openStream(Docu mentRoot.java:137)
at org.eclipse.e4.xwt.internal.xml.ElementManager.load(ElementM anager.java:252)
at org.eclipse.e4.xwt.internal.core.Core.load(Core.java:643)
at org.eclipse.e4.xwt.XWTLoader.loadWithOptions(XWTLoader.java: 863)
at org.eclipse.e4.xwt.XWTLoader.load(XWTLoader.java:729)
at org.eclipse.e4.xwt.XWT.load(XWT.java:425)
at com.infogix.dptoolcatalog.export.configui.NodePropertiesDial og.getConfigPanelsMap(NodePropertiesDialog.java:289)
at com.infogix.dptoolcatalog.export.configui.NodePropertiesDial og.createDialogArea(NodePropertiesDialog.java:218)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 760)
[Updated on: Tue, 25 May 2010 19:44] Report message to a moderator
Re: XWT fails to load x:Class class [message #536906 is a reply to message #536896] |
Mon, 31 May 2010 13:03 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi Yves,
I wouldn't call it an OSGi-Issue but an OSGi-Requirement :-)
Out of curiosity would it be possible instead of setting the class
loader to provide an OSGified load-Method.
XWT.load(Bundle bundle,String resource) this could make all relative
resources (Images, Classes, ...) relative to this bundle?
Tom
Am 31.05.10 14:45, schrieb Yves YANG:
>> Is setting of class loader still necessary for the XWT.load to succeed in
>> loading x:Class? None of the examples are showing that this is necessary
>> but I had to add a code like this to get the event handler class loaded.
>> This class and the .xwt file are in the same package in the same plugin,
>> but XWT has trouble loading it.
> If your application is in plugin, the setting of class loader is always
> necessary. It is not a problem of the implementation of XWT. It is a common
> issue of OSGi.
> Best regards
> Yves YANG
> "Swavek" <slorenc@infogix.com> wrote in message
> news:htk1g7$aau$1@build.eclipse.org...
>> Yves,
>> I just downloaded the latest e4 M6 and verified that this problem goes
>> away. Thank you. I was almost ready to give up on XWT.
>> // override the class loader for the x:Class classes located within this
>> plugin or else they will not be loaded
>> DefaultLoadingContext loadingContext = new DefaultLoadingContext ();
>> loadingContext.setClassLoader(getClass().getClassLoader());
>> XWTLoaderManager.getActive().setLoadingContext(loadingContex t);
>> . then call XWT.load
>> Thanks,
>> Swavek
Re: XWT fails to load x:Class class [message #537017 is a reply to message #536906] |
Mon, 31 May 2010 23:28 |
Yves YANG Messages: 688 Registered: July 2009 |
Hi Tom,
You are absolutely right. Thanks for correcting me.
I think it should have the same result. The class loader can load resources
as well. We do use the classloader to load images, XWT files.
yves
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:hu0c3a$53n$1@build.eclipse.org...
> Hi Yves,
> Tom
>>> in
>>> necessary
>> common
>> issue of OSGi.
>> Best regards
>> Yves YANG
>>> Yves,
>>> in
>>> necessary
>>> Thanks,
>>> Swavek
Re: XWT fails to load x:Class class [message #576845 is a reply to message #536896] |
Hi Yves,
Tom
> issue of OSGi.
> Best regards
> Yves YANG
>> Yves,
>> Thanks,
>> Swavek
Re: XWT fails to load x:Class class [message #576874 is a reply to message #536906] |
Hi Tom,
yves
> Hi Yves,
> Tom
>>> in
>>> necessary
>> common
>> issue of OSGi.
>> Best regards
>> Yves YANG
>>> Yves,
>>> in
>>> necessary
>>> Thanks,
>>> Swavek
Current Time: Wed May 08 18:45:41 GMT 2024
Powered by FUDForum. Page generated in 0.03799 seconds
