Home » Modeling » M2T (model-to-text transformation) » [XPAND] Dynamic Instance(XMI Alternative)
icon5.gif  [XPAND] Dynamic Instance [message #534881] Thu, 20 May 2010 10:40 Go to next message
I'm using xpand for code generation and xmi for model representation, I wanted to know if there is any other graphical representation just like the UML models.
Thanks.
Re: [XPAND] Dynamic Instance [message #534885 is a reply to message #534881] Thu, 20 May 2010 10:48 Go to previous messageGo to next message
what do you mean with representation? And Editor?
I guess your model is EMF (Ecore) based.
You can let EMF Generate a (Graphical) Tree Editor. Or you can build a graphical editor for EMF based model using GMF or (hopefully soon) Graphiti or build something yourself.
Christian
Re: [XPAND] Dynamic Instance [message #534886 is a reply to message #534881] Thu, 20 May 2010 10:51 Go to previous messageGo to next message
Have a look at emfmodelvisualizer
http://code.google.com/p/emfmodelvisualizer/
The project uses http://www.graphviz.org/ to generate visualisations of your models.
Darius
Re: [XPAND] Dynamic Instance [message #534889 is a reply to message #534885] Thu, 20 May 2010 10:55 Go to previous messageGo to next message
Yes , my metamodel is EMF based (Ecore) and i really don't need any editors, i just need a graphical representation for my model, not a textual representation (XML) with XMI. I mean i want to use Dynamic EMF but not with XMI .
I hope i made my idea clear.
Re: [XPAND] Dynamic Instance [message #534894 is a reply to message #534889] Thu, 20 May 2010 11:04 Go to previous messageGo to next message
Therefore you can use as Darius suggested http://code.google.com/p/emfmodelvisualizer/. But you have to create your model in memory (i guess that is what you mean with dynamic emf) OR as xmi anyway.
[Updated on: Thu, 20 May 2010 11:05] by Moderator
Re: [XPAND] Dynamic Instance [message #534898 is a reply to message #534894] Thu, 20 May 2010 11:09 Go to previous message
Ok , i will take a look at this project.
Thanks a lot for your help.
Previous Topic:[XPAND] Use multiple meta-models inside the same template
Next Topic:[Acceleo] Running a installed acceleo bundle from a Java main method
Current Time: Thu Nov 06 03:36:35 EST 2025
Powered by FUDForum. Page generated in 0.05026 seconds
