Home » Eclipse Projects » Standard Widget Toolkit (SWT) » OleControlSite: conntect to an existing instance
OleControlSite: conntect to an existing instance [message #534716] Thu, 20 May 2010 02:14 Go to next message
Originally posted by: Ludger.Heisterkamp.technotrans.de
I am automating MS Word with an OleControlSite, which works prettty well:
new OleControlSite(frame, SWT.NONE, "Word.Application");
This code always opens a new Word instance. Is it possible to connect
to an existing instance of Word, if there is one?
Kind regards,
Ludger Heisterkamp
Re: OleControlSite: conntect to an existing instance [message #534797 is a reply to message #534716] Thu, 20 May 2010 07:34 Go to previous messageGo to next message
I dont think so...
but i think you can open the word document which you want in the oleclient...
Antw: Re: OleControlSite: conntect to an existing instance [message #535877 is a reply to message #534797] Wed, 26 May 2010 03:22 Go to previous message
Yes, that is right. This is the way I'm working right now.
But Word sometimes has problems accessing the normal.dot
when multiple instances are running at the same time.
To avoid these problems it would be nice to have the
possibility to access an existing instance.
In VB it possible via the GetObject method:
Dim wdapp As Object
Set wdapp = GetObject(, "Word.Application")
But there seems to be no equivalent method in SWT...
LH
>>> vijay<vijay.rajonline@gmail.com> schrieb am Donnerstag, 20. Mai 2010 um
13:34 in Nachricht <ht36o0$sbo$1@build.eclipse.org>:
> Quote:
> I dont think so...
> oleclient...
Previous Topic:Auto-complete functionality
Next Topic:Monitoring Tool with SWT
Current Time: Tue Sep 02 07:03:40 EDT 2025
Powered by FUDForum. Page generated in 0.05624 seconds
