Revert fails, artifact file not found [message #534347] |
Tue, 18 May 2010 18:40 |
Ben Vitale Messages: 247 Registered: July 2009 |
When I try to revert my branded IDE product to a previous version, it fails as shown below. The bundle it's complaining about exists under "plugins" just like it did before. Any ideas on this one?
This is on 3.5.0.
Error
Tue May 18 13:39:12 EDT 2010
An error occurred while installing the items
Error
The artifact file for osgi.bundle,com.company.plugin,2.0.0.200912111449 was not found.
eclipse.buildId=unknown
java.version=1.6.0_13
Command-line arguments: -os win32 -ws win32 -arch x86
Error
session context was:(profile=profile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Install, operand=null --> [R]com.company.plugin 2.0.0.200912111449, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.ac tions.InstallBundleAction).
Re: Revert fails, artifact file not found [message #534607 is a reply to message #534347] |
Wed, 19 May 2010 15:57 |
This is solved. Here's what I discovered.
When the product was originally built, and a director install performed on the build machine, that produced the initial profile snapshots, which each had the "installFolder" property set to <directory on build server>.
If I moved the build to my PC and ran it from some other directory, then immediately updated to a new version, then tried to revert, it would fail as described. The problem was it was trying to revert to a profile with an installFolder on some other machine.
If I ran the product, then exited it, *then* updated it and tried to revert it, that succeeded.
It appears that a new profile snapshot is taken on shutdown after initial startup, and it records the proper installFolder. Reverting to that snapshot works fine.
Since my clients will have at least launched/exited the product once before upgrading, if they need to revert, the problem scenario should not occur in the field.
Whew...
FUDForum. Page generated in 0.04406 seconds
