Home » Modeling » Modeling (top-level project) » null as Resource in ResourceSet
Re: null as Resource in ResourceSet [message #534242 is a reply to message #534225] |
Tue, 18 May 2010 12:51   |
Ed Merks Messages: 32440 Registered: July 2009 |
--------------030704030604070802040101
Sascha,
Comments below.
Sascha Theves wrote:
> Hi Ed,
> thanks for the quick answer! We think that it is caused by a concurrency
> problem too. But we can not imagine where the problem exactly comes from.
> Could you show me some insights of the EMF code where the concurrency
> problem could occur? I think in our case it is somehow caused when we read
> our model in parallel. Some of our containment references are objects that
> are persisted in its own resource. Iterating over these containment
> references causes EMF to resolve proxies. When that happens new resources
> must be added to the resource set. But that is done internally by EMF and
> not in our code. That would mean we can not read our model at the same time
> in two different threads. Am I right?
Yes, resolving proxies on multiple threads at the same time will cause
issues. This is one of the things the transaction framework helps with,
i.e., you must create a read transaction. Or you might just specialize
your ResourceSetImpl to add a synchronize to getResource to serialize
access.
> Thanks for your help!
> Cheers
> Sascha
> "Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag
> news:hstrsu$cdp$1@build.eclipse.org...
>> Sascha,
>> ResourceSets aren't thread safe so that's a likely source of the problem
>> you describe. I've seen, for example, many problems reported from WTP
>> about null in the list of adapters and those were definitely caused by
>> adding an adapter on two threads at the same time.
>>> Hi all,
>>> we have an EMF model that is persisted in many resources on filesystem.
>>> All these resources are contained in one ResourceSet as EMF resource. The
>>> strange thing is that we get sometimes null-Entries in the resource list
>>> of the resource set. The problem is that we do not really know where the
>>> null entry comes from. We have seen that EMF perfroms Null-Checks before
>>> inserting a resource in the resource set, so it should not be possible to
>>> have null entries in the resource set. Has anybody an idea where these
>>> null entries are coming from? Or does anybody know how to insert a null
>>> resource in the resource set with bypassing the null checks from EMF?
>>> Cheers
>>> Sascha
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Sascha,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hsu04g$pdn$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
</blockquote>
with, i.e., you must create a read transaction. Or you might just
specialize your ResourceSetImpl to add a synchronize to getResource to
serialize access.<br>
<pre wrap="">
Cheers
Sascha
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> schrieb im Newsbeitrag
<a class="moz-txt-link-freetext" href="news:hstrsu$cdp$1@build.eclipse.org">news:hstrsu$cdp$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Sascha,
</pre>
<pre wrap="">Hi all,
Cheers
Sascha
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030704030604070802040101--
Ed Merks
Re: null as Resource in ResourceSet [message #534575 is a reply to message #534242] |
Wed, 19 May 2010 14:52   |
Originally posted by: tim.baumgartner.innovations.de
Hi Ed,
I wrote a test case for this (see below). It passes for Resources, but it
really fails if I change it to adapters, just like you told.
Tim
public class NullResourceTest extends TestCase
private ResourceSet set;
private class ResourceThread extends Thread
private Resource resource;
public ResourceThread()
resource = new XMIResourceImpl();
public void run()
if (set.getResources().contains(resource))
set.getResources().remove(resource);
else
set.getResources().add(resource);
protected void setUp() throws Exception
set = new ResourceSetImpl();
public void test() throws Exception
for (int i = 0; i < 10; i++)
new ResourceThread().start();
long time = System.currentTimeMillis();
while (System.currentTimeMillis() < time + 10000)
if (set.getResources().contains(null))
fail("Null in ResourceSet");
news:hsu2g3$muh$1@build.eclipse.org...
Sascha,
Comments below.
Hi Ed,
i.e., you must create a read transaction. Or you might just specialize your
ResourceSetImpl to add a synchronize to getResource to serialize access.
Cheers
Sascha
Sascha,
Hi all,
Cheers
Sascha
Re: null as Resource in ResourceSet [message #534579 is a reply to message #534575] |
Wed, 19 May 2010 15:14  |
Tim,
I don't see any further questions here. Just to be clear: don't expect
anything in EMF to change to provide thread safety. Thread safety needs
to be achieved by a sound threading policy in the application as a
whole, not by judicious sprinklings of synchronized calls; that approach
just interferes with the high-level policy and leads to unavoidable
deadlocks.
Tim Baumgartner wrote:
> Hi Ed,
> Regards
> Tim
> @Override
> public void run()
> else
> @Override
> Sascha,
> Comments below.
> Hi Ed,
> Cheers
> Sascha
> Sascha,
> Hi all,
> Cheers
> Sascha
Ed Merks
Re: null as Resource in ResourceSet [message #619627 is a reply to message #534140] |
Tue, 18 May 2010 10:58  |
Sascha,
> Hi all,
> we have an EMF model that is persisted in many resources on filesystem. All
> strange thing is that we get sometimes null-Entries in the resource list of
> the resource set. The problem is that we do not really know where the null
> have null entries in the resource set. Has anybody an idea where these null
> entries are coming from? Or does anybody know how to insert a null resource
> Cheers
> Sascha
Ed Merks
Re: null as Resource in ResourceSet [message #619629 is a reply to message #534225] |
Sascha,
Comments below.
> Hi Ed,
access.
> Cheers
> Sascha
>> Sascha,
>>> Hi all,
>>> Cheers
>>> Sascha
<html>
<head>
</head>
Sascha,<br>
<br>
Comments below.<br>
<br>
<pre wrap="">Hi Ed,
</pre>
</blockquote>
<pre wrap="">
Cheers
Sascha
</pre>
</pre>
Cheers
Sascha
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Ed Merks
Re: null as Resource in ResourceSet [message #619630 is a reply to message #534242] |
Hi Ed,
Tim
public void run()
else
Sascha,
Comments below.
Hi Ed,
Cheers
Sascha
Sascha,
Hi all,
Cheers
Sascha
Re: null as Resource in ResourceSet [message #619631 is a reply to message #534575] |
Tim,
deadlocks.
> Hi Ed,
> Regards
> Tim
> @Override
> public void run()
> else
> @Override
> Sascha,
> Comments below.
> Hi Ed,
> Cheers
> Sascha
> Sascha,
> Hi all,
> Cheers
> Sascha
Ed Merks
Current Time: Sun Aug 14 22:13:05 GMT 2022
Powered by FUDForum. Page generated in 0.02021 seconds
