Re: Buckminster+Hudson: Broken Encoding [message #533919 is a reply to message #533895] |
Mon, 17 May 2010 13:26 |
Hi Andreas,
Perhaps this is related to the default encoding used in your workspace?
If so, I suggest you set up a template workspace with the correct
default encoding and then use that as the base when you populate the
workspace to be built by Hudson.
- thomas
On 05/17/2010 02:23 PM, Andreas Schilling wrote:
> hi everybody!
> I guess our issue is easy to fix, but we're totally stuck.
> we set up a build for our Eclipse RCP application with buckminster and
> hudson and everything works fine except that the encoding is broken (our
> application is in german and we use umlauts).
> what do we need to do to get a correctly encoded application?
> SCM is StarTeam btw. (maybe something goes wrong during checkout?)
> it seems that it's some configuration issue with the compiler because
> stuff that is defined in the plugin.xml (e.g. menu contributions) has
> correct umlauts while everything that's in the source hasn't.
> also noteworthy might be, that we have a JNLP build. although it works
> if we do a buckminster JNLP build from within the IDE. so we believe
> it's some issue with the combination hudson+buckminster.
> regards,
> Andreas
FUDForum. Page generated in 0.03681 seconds
