Problems with custom config.ini [message #533450] |
Thu, 13 May 2010 22:36 |
Ken Messages: 36 Registered: July 2009 |
Member |
I have a feature product and in the product configuration tab I set it to
"Use an existing config.ini" instead of "Generate a default config.ini
file". The file I'm using is the same as what you get when exporting, but
when I run the exported product, I get the exception below. I've noticed
that the configuration folder generated has less stuff; it's missing
org.eclipse.core.runtime, org.eclipse.equinox.app, and
org.eclipse.simpleconfigurator. Even if I add those manually, it still does
not work. Something seems to also be missing from my plugin, b/c it only
works if I copy that over as well.
Any one know what is going on here? Is there any way to just update the
config.ini without having the rest of the output different and therefore not
work?
!SESSION 2010-05-13
18:35:37.458 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-05-13 18:35:37.998
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started (see
config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
- Ken
Re: Problems with custom config.ini [message #533456 is a reply to message #533450] |
Fri, 14 May 2010 02:47 |
Member |
It seemd to only happen with feature based products. Following this solved
the problem:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 259.html at
least within Eclipse product export.
- Ken
"Ken Prole" <kennyp@avi.com> wrote in message
news:hshusk$ebp$1@build.eclipse.org...
> not work?
> !SESSION 2010-05-13
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> (see config.ini).
> at
> at
> at
> - Ken
FUDForum. Page generated in 0.02160 seconds
