Re: Help with mapping a inherited relationship as a @OneToOne [message #534943 is a reply to message #534902] |
Thu, 20 May 2010 18:10 |
Karen Butzke Messages: 220 Registered: July 2009 |
Yes, the default for @MapsId is the field defined with @Id or @EmbeddedId.
Dali is part of the Eclipse Java EE IDE, if you have created a JPA Project in Eclipse you are using Dali. I'm curious if you have used the most recent version of Entity generation. It was redone in Dali 2.2 which was included in the Eclipse 3.5 release, also available in the upcoming 3.6 release. It allows you to customize your relationships, entity names, attribute names, set up generators, etc. It also saves the wizard state if you want to regenerate.
We'd appreciate any feedback over on the Dali forum or in bugzilla, especially since you've worked in multiple IDEs.
Karen
FUDForum. Page generated in 0.05291 seconds
