Home » Archived » BIRT » Joint Data Set in Library(When upgrading from 2.3.2 to 2.5.2 my Joint Data Set in Library stopped working)
Joint Data Set in Library [message #533443] Thu, 13 May 2010 18:27 Go to next message
I am in the process of upgrading our system from BIRT 2.3.2 to 2.5.2. I have 2 Data Sets defined in the report library and then a Joint Data Set defined which joins these 2 Data Sets. The individual Data Sets work fine in 2 other reports. But, the report that uses the Joint Data Set is now failing with a complaint that it can't find the 1st of the 2 Data Sets.
If I copy the Joint Data Set definition from the library into the report, rather than referencing the one in the library, the report starts to work fine.
Any ideas as to what changed in this regard between 2.3.2 and 2.5.2, and more importantly what can I do to rectify the problem?
Re: Joint Data Set in Library [message #533564 is a reply to message #533443] Fri, 14 May 2010 10:52 Go to previous messageGo to next message
Bill,
Can you open a bug for this? Also can you try making any change to the
library and saving it as 2.5.2?
Jason
Re: Joint Data Set in Library [message #533571 is a reply to message #533564] Fri, 14 May 2010 11:11 Go to previous messageGo to next message
Yes. that was my first thought. I have upgraded the library to 2.5.2 format.
I'll open a bug report.
Re: Joint Data Set in Library [message #533608 is a reply to message #533443] Fri, 14 May 2010 13:25 Go to previous message
The reference to the bug report is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=312946
Previous Topic:Set a role in db/use existing db-connection
Next Topic:Installing BIRT for Maximo
Current Time: Sun Sep 21 00:18:39 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
