Re: b3.rmap: 2 Problems and question about b3.releng: is b3 already selfhosting ? [message #533057 is a reply to message #533025] |
Wed, 12 May 2010 06:48   |
Hi Bernhard,
b3 is currently built with Buckminster. It assumes that you have a property 'build.type' set.
Try building using:
build.type=I
HTH,
Thomas Hallgren
On 05/12/2010 12:47 AM, Bernhard Merkle wrote:
> question: how is b3 itself built ? with b3 (selfhosting) or with
> buckminsters. ? I read
> http://wiki.eclipse.org/Eclipse_b3/contributing/Setting_Up_D evelopment_Environment
> but could not find the answer there.
> Background of the question is the org.eclipse.b3.releng project which
> contains a buckminter project.
> But there the b3.rmap file has two problems:
> 1. it can not be opened in the ecore editor.
> error msg is: Unresolved reference 'buckminster'
> 2. if i run the resolver on the b3.cquery file i get
> ERROR [0002] : No suitable provider for component
> org.eclipse.rcp:eclipse.feature was found in resourceMap
> file:/W:/B3_Source/org.eclipse.b3.releng/b3.rmap
> org.eclipse.rcp:eclipse.feature was found in searchPath platform
> org.eclipse.rcp:eclipse.feature was found in searchPath modeling
> ERROR [0002] : Rejecting provider
> p2({0}/modeling/emf/updates/milestones[http://download.eclipse.org/modeling/emf/updates/milestones]):
> No component match was found
> simultanious.release
> Errors and Warnings
> E [0002] : No suitable provider for component
> E [0002] : Rejecting provider
> TAG-ID 0002 = Query for org.eclipse.b3.releng:buckminster, path:
> org.eclipse.b3.releng:buckminster$0.1.0.qualifier
> thanks,
> Berni.
Re: b3.rmap: 2 Problems and question about b3.releng: is b3 already selfhosting ? [message #606978 is a reply to message #533025] |
Hi Bernhard,
Try building using:
build.type=I
HTH,
Thomas Hallgren
> Errors and Warnings
> thanks,
> Berni.
FUDForum. Page generated in 0.02809 seconds
