Home » Modeling » Papyrus » Papyrus 1.12: Does UML OCL validation on models really work?(When stereotypes defined in profile)
Papyrus 1.12: Does UML OCL validation on models really work? [message #533023] |
Tue, 11 May 2010 22:19 |
Shaman_Mahmoudi Messages: 16 Registered: February 2010 |
I have downloaded and installed Papyrus 1.12. I am following the OCL constraint tutorial, and I can not validate my stereotypes against OCL constraints I have defined. It says validation successful even when that is not the case. Does not matter in what context the classifier is, be it M1 or M2. It's as if the validation is not performed at all. What happened? Why is it not working? Plan to update 1.12 to a working one? Or do we need to wait for version 2 of the tool?
By the way, how did you solve the issue of which classifier (stereotype vs stereotype meta-class) to use in the context when validating against OCL constraints?
Thanks in advance.
[Updated on: Tue, 11 May 2010 22:21] Report message to a moderator
Re: Papyrus 1.12: Does OCL validation on models really work? [message #533106 is a reply to message #533023] |
Wed, 12 May 2010 09:28 |
Hi Shaman,
there is a confusion. What you downloaded is Papyrus UML, an open source
solution based on Eclipse but not hosted by the Eclipse foundation.
You can submit bugs directly on the website:
http://www.papyrusuml.org/scripts/home/publigen/content/temp lates/show.asp?P=120&L=EN&ITEMID=35
This forum is dedicated to Eclipse MDT Papyrus component, which can be
considered as the new generation of Papyrus UML and integrates with
other initiatives coming from TOPCASED UML and Moskitt.
The first public release is expected for July 14th? Before you can find
information about how to download the code from SVN here :
http://wiki.eclipse.org/Papyrus_Developer_Guide
Hope things are clear now
regards
raphaël
Shaman_Mahmoudi a écrit :
> constraints I have defined. It says validation succesful even when that
> happened? Why it not workiing? Plan to updat 1.12 to a working one? Or
> OCL constraints?
> Thanks in advance.
Re: Papyrus 1.12: Does OCL validation on models really work? [message #533117 is a reply to message #533106] |
Wed, 12 May 2010 10:02 |
Hi Rafael,
Thanks a lot for the information! Now everything makes sense! That other project looked abandoned considering documents did not align with what the product offered and no word about progress.
I believe I am more interested in the Papyrus MDT component, and I have taken a look at the source code, in particular OCL validation. If it is ok, I want to ask a question regarding it.
I have read and tried that piece od code, and there is one issue that is confusing me. In order to validate against an OCL constraint, you need to set the classifier context and then do the validation. In the code, the validation is allways done on M1 level it seems. If the OCL constraint as a method (example self.allOwnedElements()) or attribute defined in the UML meta model, then the context is on M2. With the current code, you'll get an exception if you try to do validate against such a constraint. An easy but maybe not elegant solution is to first try to create the invariant on M1 level, if fails, try in M2 level. How are you solving this issue? i.e. how to know in what context the constraint is defined in.
Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #542615 is a reply to message #533117] |
Fri, 25 June 2010 12:46 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Shaman
I'm not familiar with Papyrus; I first downloaded it an hour ago. But I
am very interested in smoothing off the rough edges that make use of OCL
much harder than it should be.
It would be very helpful to see how you are trying to use Papyrus and to
have a newbie-oriented description of the problems you are encountering.
Ed Willink (MDT/OCL committer)
On 12/05/2010 11:02, Shaman_Mahmoudi wrote:
> Hi Rafael,
> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #543002 is a reply to message #542615] |
Mon, 28 June 2010 07:51 |
Yann Tanguy Messages: 80 Registered: July 2009 |
Member |
Papyrus model explorer relies on Modisco.
Here are few tips to start using Modisco Java or OCL queries in Papyrus :
1. Make sure Papyrus Model Explorer is opened (window/show
view/other/"Papyrus Model Explorer")
2. Create a new Modisco projet (using Modisco wizard)
3. Create a new QuerySet in this project (using Modisco wizard)
- Add some queries (Java or OCL) in the QuerySet
4. From Papyrus Model Explorer, select and element (context for the
query), right-click and select "Execut Query"
regards
Yann
Ed Willink a écrit :
> Hi Shaman
> Regards
>> Hi Rafael,
>> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #543212 is a reply to message #543002] |
Mon, 28 June 2010 17:29 |
Hi Yann
I managed to follow the instructions as far as Execute Query. I cannot
see any results anywhere and have no idea what the "Table" might be
where they are.
There is considerable commonality between the Query Execution View and
the OCL Console (available when MDT/OCL Examples are installed - follow
the OCLinEcore tutorial in the Helios OCL Documentation). The former
looks prettier and has modelled persistence, but the latter is more
functional. It would be good to merge these under the guise of a
coherent environment for sphinx. MDT/OCL now provides an Xtext editor
for expressions that might evolve (once used) to support query editing.
There is also less obvious commonality in the area of Model Explorer
where too many projects are doing rather similar things inconsistently.
I gave up trying to raise an EMFT Registry project to provide these
functionalities in a self-standing +1 project; one attempt at common
functionality therefore exists as the OCL Example Model Registry, which
might provide a more shareable home for a communal facility.
Ed Willink
> regards
> Yann
>> Hi Shaman
>> I am very interested in smoothing off the rough edges that make use of
>> OCL much harder than it should be.
>> Regards
>>> Hi Rafael,
>>> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #543729 is a reply to message #543212] |
Wed, 30 June 2010 12:17 |
Member |
Well after selecting you query and clicking "Execute Query" button, the
query result should appear in a tabular editor.
Strange that no result in shown in your case. Did you try to execute the
query directly with Modisco editor (right-click on your .uml file and
"Open with / Modisco Model Browser" ?
I agree with you, it would probably be a good thing that you get in
contact with the Modisco team to see how you may contribute interesting
OCL feature from your project in modisco or share the OCL feature you
mention with them.
best regards,
Yann
> Hi Yann
> where they are.
> Regards
> Ed Willink
>> regards
>> Yann
>>> Hi Shaman
>>> Regards
>>>> Hi Rafael,
>>>> other
>>>> that is
>>>> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #602148 is a reply to message #542615] |
Member |
regards
Yann
> Hi Shaman
> Regards
>> Hi Rafael,
>> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #602186 is a reply to message #543002] |
Hi Yann
where they are.
Ed Willink
> regards
> Yann
>> Hi Shaman
>> Regards
>>> Hi Rafael,
>>> Thanks in advance!
Re: Papyrus 1.12: Does OCL validation on models really work? [message #602214 is a reply to message #543212] |
Member |
mention with them.
best regards,
Yann
> Hi Yann
> where they are.
> Regards
> Ed Willink
>> regards
>> Yann
>>> Hi Shaman
>>> Regards
>>>> Hi Rafael,
>>>> other
>>>> that is
>>>> Thanks in advance!
Current Time: Fri Apr 26 02:49:01 GMT 2024
Powered by FUDForum. Page generated in 0.04086 seconds
