Turn off auto commit of new files [message #532970] |
Tue, 11 May 2010 13:40  |
If I create a new file and then do a commit, it is now listed in the "commit" window. How do I turn this off? I only want resources listed there that are under version control. If I want to add the new resource to version control I can do a Team->Add to Version control.
This is really annoying and only started happening when I upgraded to Eclipse 3.5.
For example. I make changes to my code. I build my project via ant which creates a jar file. Now I want to commit the changes. The changed files are listed in the commit window, but so is the .jar that is build. How do I configure this so the .jar isn't listed in the commit window? I know I can just svn:ignore it, but that is a pain to do when I have many generated files and directories that are not under version control, but now appear every time I want to do a commit.
Re: Turn off auto commit of new files [message #532989 is a reply to message #532970] |
Tue, 11 May 2010 14:40  |
Tue, 11 May 2010 13:40:40 -0400, /jbppsu@gmail.com/:
> Eclipse 3.5.
I think it has always been like that. For this there's a preference
setting "Check the new resources in the commit dialog":
http://www.eclipse.org/subversive/documentation/preferences/ pref_svn.php
I have it unchecked. New resources get listed in the commit dialog
but are unchecked by default and so are not committed automatically.
You may consider placing all build generated stuff under a single
directory you have once ignored with svn:ignore.
Stanimir
FUDForum. Page generated in 0.03252 seconds
