Home » Modeling » Epsilon » [EuGENia] Problem customizing the GMF editor
Re: [EuGENia] Problem customizing the GMF editor [message #532523 is a reply to message #532522] |
Mon, 10 May 2010 11:04 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Syed,
I can't seem to be able to reproduce this. Could you please zip you
project and send it to me at dskolovos gmail com?
Dimitris
Syed Imran wrote:
> Hi Dimitris,
> Yes exactly you are right, I had not Synchronize GMF gen model.
> But now another problem, whenever I tried to synchronize the GMF gen model,
> I get an error message "Method 'getAnnotationValue' not found".
> Any idea, I am using almost the same .emf model as given in article except I
> have added (foo='bar') in @gmf.diagram annotation. Regards Syed Imran
> "Dimitris Kolovos" <dskolovos@gmail.com> wrote in message
> news:hs8mf1$h8i$1@build.eclipse.org...
>> Hi Syed,
>> Have you by any chance missed the following step?
>>> Right click the generated .gmfgen model and select
>> Eugenia->Synchronize GMF gen model
>> Cheers,
>> Dimitris
>> Syed Imran wrote:
>>> Hi,
>>> I have been following the article "Customizing a GMF editor generated by
>>> EuGENia" and trying to set @gmf.compartment(layout="list".. .
>>> In classdiagram.gmfgraph the ClazzAttributeCompartmentFigure has a child
>>> set to Stack.layout. But seems like it is not working and I still see in
>>> GMF editor the attributes layout not as list as proposed by the article.
>>> I am wondering how to solve this problem so that the attributes values
>>> will be shown as list.
>>> Regards
>>> Syed
>> Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
>> Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [EuGENia] Problem customizing the GMF editor [message #532524 is a reply to message #532523] |
Mon, 10 May 2010 11:07 |
Syed Imran Messages: 25 Registered: October 2009 Location: Ireland |
Sure, I do so.
Syed.
news:hs8p98$nik$1@build.eclipse.org...
> Hi Syed,
> Cheers,
> Dimitris
> Syed Imran wrote:
>> Hi Dimitris,
>> model, I get an error message "Method 'getAnnotationValue' not found".
>> except I have added (foo='bar') in @gmf.diagram annotation. Regards Syed
>> Imran
>>> Hi Syed,
>>> Cheers,
>>> Dimitris
>>> Syed Imran wrote:
>>>> Hi,
>>>> by EuGENia" and trying to set @gmf.compartment(layout="list".. .
>>>> child set to Stack.layout. But seems like it is not working and I still
>>>> see in GMF editor the attributes layout not as list as proposed by the
>>>> article. I am wondering how to solve this problem so that the
>>>> attributes values will be shown as list.
>>>> Regards
>>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #532529 is a reply to message #532524] |
Mon, 10 May 2010 11:47 |
Hi Syed,
The column (:) separates the name and the type of the attribute (e.g.
name : String). To add a 2nd attribute you need to use the Attribute
creation tool in the palette.
Dimitris
Syed Imran wrote:
> Sure, I do so.
> Syed.
>> Hi Syed,
>> Cheers,
>> Dimitris
>> Syed Imran wrote:
>>> Hi Dimitris,
>>> Imran
>>>> Hi Syed,
>>>> Cheers,
>>>> Dimitris
>>>> Syed Imran wrote:
>>>>> Hi,
>>>>> Regards
>>>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #532542 is a reply to message #532529] |
Mon, 10 May 2010 12:30 |
Yes, Dimitris
you are absolutly right. I realize it now.
kind regards,
Syed Imran
news:hs8rpi$7te$1@build.eclipse.org...
> Hi Syed,
> The column (:) separates the name and the type of the attribute (e.g. name
> : String). To add a 2nd attribute you need to use the Attribute creation
> Cheers,
> Dimitris
> Syed Imran wrote:
>> Sure, I do so.
>> Syed.
>>> Hi Syed,
>>> Cheers,
>>> Dimitris
>>> Syed Imran wrote:
>>>> Hi Dimitris,
>>>> Syed Imran
>>>>> Hi Syed,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Syed Imran wrote:
>>>>>> Hi,
>>>>>> still see in GMF editor the attributes layout not as list as proposed
>>>>>> by the article. I am wondering how to solve this problem so that the
>>>>>> Regards
>>>>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #589047 is a reply to message #532522] |
Hi Syed,
Dimitris
Syed Imran wrote:
> Hi Dimitris,
>> Hi Syed,
>> Cheers,
>> Dimitris
>> Syed Imran wrote:
>>> Hi,
>>> Regards
>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #589056 is a reply to message #532523] |
Sure, I do so.
Syed.
> Hi Syed,
> Cheers,
> Dimitris
> Syed Imran wrote:
>> Hi Dimitris,
>> Imran
>>> Hi Syed,
>>> Cheers,
>>> Dimitris
>>> Syed Imran wrote:
>>>> Hi,
>>>> Regards
>>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #589063 is a reply to message #532524] |
Hi Syed,
Dimitris
Syed Imran wrote:
> Sure, I do so.
> Syed.
>> Hi Syed,
>> Cheers,
>> Dimitris
>> Syed Imran wrote:
>>> Hi Dimitris,
>>> Imran
>>>> Hi Syed,
>>>> Cheers,
>>>> Dimitris
>>>> Syed Imran wrote:
>>>>> Hi,
>>>>> Regards
>>>>> Syed
Re: [EuGENia] Problem customizing the GMF editor [message #589071 is a reply to message #532529] |
Yes, Dimitris
kind regards,
Syed Imran
> Hi Syed,
> Cheers,
> Dimitris
> Syed Imran wrote:
>> Sure, I do so.
>> Syed.
>>> Hi Syed,
>>> Cheers,
>>> Dimitris
>>> Syed Imran wrote:
>>>> Hi Dimitris,
>>>> Syed Imran
>>>>> Hi Syed,
>>>>> Cheers,
>>>>> Dimitris
>>>>> Syed Imran wrote:
>>>>>> Hi,
>>>>>> Regards
>>>>>> Syed
Current Time: Fri Apr 26 10:03:27 GMT 2024
Powered by FUDForum. Page generated in 0.04520 seconds
