Home » Language IDEs » Java Development Tools (JDT) » Java editor fails opening java file.(The jave editor crashes during initialization with a class cast exception. )
Java editor fails opening java file. [message #532258] Fri, 07 May 2010 13:36 Go to next message
The message I get is displayed in the window with a tab named for the file (as if the file were open in the editor).
Could not open the editor: Editor could not be initialized.
I can open the file with the "open with" selecting the text editor.
The files is a normal source file in the build path. The permissions and ownership look normal.
I'm pretty stuck.
The exception details are:
Eclipse IDE for Java Developers 1.2.2.20100216-1730 epp.package.java
Eclipse Platform 3.5.2.M20100211-1343 org.eclipse.platform.ide
EPP Java Package 1.2.2.20100216-1730 org.eclipse.epp.package.java.feature.feature.group
Subversive SVN Connectors 2.2.1.I20091009-1900 org.polarion.eclipse.team.svn.connector.feature.group
Subversive SVN Team Provider (Incubation) 0.7.8.I20091023-1300 org.eclipse.team.svn.feature.group
SVNKit 1.3.0 Implementation (Optional) 2.2.1.I20091009-1900 org.polarion.eclipse.team.svn.connector.svnkit16.feature.gro up
java.lang.ClassCastException: org.eclipse.jdt.internal.core.JarPackageFragmentRoot cannot be cast to org.eclipse.jdt.core.IPackageFragment
at org.eclipse.jdt.internal.core.JavaModelManager.createCompila tionUnitFrom(JavaModelManager.java:937)
at org.eclipse.jdt.internal.core.JavaModelManager.create(JavaMo delManager.java:856)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2476)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.createCompilationUnit(CompilationUnitDocumentProv ider.java:926)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.createFileInfo(CompilationUnitDocumentProvider.ja va:957)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.connect(CompilationUnitDocumentProvider.java:1198 )
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4135)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.internalDo SetInput(JavaEditor.java:2552)
at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.doSetInput (JavaEditor.java:2525)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .doSetInput(CompilationUnitEditor.java:1371)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3116)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3134)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3161)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:286)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2857)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2676)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:374)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:178)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 9)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 8)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:373)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:526)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener. open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:842)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1101)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1205)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:298)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
My Configuration
*** Date: Friday, May 7, 2010 5:09:40 PM GMT+00:00
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\\plugins\org.eclipse .platform_3.3.202.v201002111343\splash.bmp
-launcher
C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\plugins/org.eclipse. equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1 206.dll
-startup
C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\plugins/org.eclipse. equinox.launcher_1.0.201.R35x_v20090715.jar
-product
org.eclipse.epp.package.java.product
-bmsthd
-Xmx1500m
-Xms1500m
-XX:PermSize=512m
-XX:MaxPerrmSize=256m
-vm
C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.home.location=file:/C:/Documents and Settings/eds/eclipse/galileoSR2/eclipse/
eclipse.launcher=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.java
eclipse.product=org.eclipse.epp.package.java.product
eclipse.startTime=1273246523877
eclipse.vm=C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\plugins/org.eclipse. equinox.launcher_1.0.201.R35x_v20090715.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\DOCUME~1\eds\LOCALS~1\Temp\1\
java.library.path=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse;.;C:\WINDOWS\Sun\Jav a\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Program Files\PC Connectivity Solution\;D:\Oracle\product\10.1.0\Client_1\bin;C:\WINDOWS\s ystem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\IDM Computer Solutions\UltraEdit-32;d:\utils;t:\utils;C:\Program Files\Subversion\bin;C:\Program Files\maven-2.0.7\bin;C:\Program Files\Common Files\GTK\2.0\bin;C:\Probram Files\Java\jdk1.6.0_18\bin;C:\WINDOWS\system32\WindowsPowerS hell\v1.0
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_18-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_18
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=16.0-b13
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.equinox.launcher.splash.location=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\\plugins\org.eclipse .platform_3.3.202.v201002111343\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.101.R35x_v2009080 7-1100.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\configuration\org.ec lipse.osgi\bundles
osgi.configuration.area=file:/C:/Documents and Settings/eds/eclipse/galileoSR2/eclipse/configuration/
osgi.framework=file:/c:/Documents and Settings/eds/eclipse/galileoSR2/eclipse/plugins/org.eclipse. osgi_3.5.2.R35x_v20100126.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.5.2.R35x_v20100126
osgi.install.area=file:/C:/Documents and Settings/eds/eclipse/galileoSR2/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/eds/eclipse/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/eds/workspace/
osgi.logfile=C:\Documents and Settings\eds\eclipse\workspace\.metadata\.log
osgi.manifest.cache=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\configuration\org.ec lipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\\plugins\org.eclipse .platform_3.3.202.v201002111343\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Documents and Settings\eds\eclipse\galileoSR2\eclipse\plugins
osgi.tracefile=C:\Documents and Settings\eds\eclipse\workspace\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre6\lib\resources.jar;C:\Program Files\Java\jre6\lib\rt.jar;C:\Program Files\Java\jre6\lib\sunrsasign.jar;C:\Program Files\Java\jre6\lib\jsse.jar;C:\Program Files\Java\jre6\lib\jce.jar;C:\Program Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\classes
sun.boot.library.path=C:\Program Files\Java\jre6\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1255
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\Documents and Settings\eds\eclipse\galileoSR2\eclipse
user.home=C:\Documents and Settings\eds
user.language=en
user.name=eds
user.timezone=GMT
user.variant=
*** Features:
org.eclipse.cvs (1.1.101.R35x_v20100125-7E79FGD9kKF67BPDZ7PKCE1911) "Eclipse CVS Client"
org.eclipse.epp.package.java.feature (1.2.2.20100216-1730) "EPP Java Package"
org.eclipse.help (1.1.2.R35x_v20100119-7e7eFAnFEx2X_fZltJhDjz-D) "Help System Base"
org.eclipse.jdt (3.5.2.r352_v20100108-7r88FEwFI0WTuoBl0iaG0tyhfZH6) "Eclipse Java Development Tools"
org.eclipse.mylyn_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.3.2.v20100222-0100-e3x) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.2.1.v20100222-0100-e3x) "Mylyn"
org.eclipse.platform (3.5.2.R35x_v20100210-0800-9hEiFzmFst-TiEn9hNYgDWg1XN8ulH_Jv CNGB) "Eclipse Platform"
org.eclipse.rcp (3.5.2.R35x_v20100119-9SA0FxwFnoCU5XxWItFdXXb27BA6) "Eclipse RCP"
org.eclipse.team.svn (0.7.8.I20091023-1300) "Subversive SVN Team Provider (Incubation)"
org.eclipse.wst.xml_ui.feature (3.1.1.v200907161031-7H6FMbDxtkMs9OeLGF98LRhdPKeo) "Eclipse XML Editors and Tools"
org.polarion.eclipse.team.svn.connector (2.2.1.I20091009-1900) "Subversive SVN Connectors"
org.polarion.eclipse.team.svn.connector.svnkit16 (2.2.1.I20091009-1900) "Subversive SVN 1.6 SVN Kit Connector"
*** Plug-in Registry:
com.ibm.icu (4.0.1.v20090822) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.xml (1.3.4.v200902170245) "JAXP XML" [Resolved]
org.apache.ant (1.7.1.v20090120-1145) "Apache Ant" [Resolved]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200903231320) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis" [Resolved]
org.apache.xerces (2.9.0.v200909240008) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200902170519) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v200902170519) "Apache XML Commons Serializer" [Resolved]
org.eclipse.ant.core (3.2.101.v20091110_r352) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.4.2.v20091204_r352) "Ant UI" [Starting]
org.eclipse.compare (3.5.2.r35x_20100113-0800) "Compare Support" [Active]
org.eclipse.compare.core (3.5.0.I20090430-0408) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.0.I20090430-0408) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.5.0.I20090525-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.1.R35x_v20090826-0451) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.0.I20090525-2000) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.2.0.M20090902-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.2.0.M20090819-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.101.R35x_v20100209) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.5.0.v20090526-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.1.R35x_v20091203-1235) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.100.v20090429-1800) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.1.r35x_20090812-1200) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080909) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.5.2.R35x_v20091203-1235) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.4.1.R35x_v20100113-0530) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.5.0.v20081020) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.5.0.v20090525) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20090413) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20090413) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20090429-1800) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.200.v20090521) "Core Variables" [Active]
org.eclipse.cvs (1.0.400.v201002111343) "Eclipse CVS Client" [Starting]
org.eclipse.debug.core (3.5.1.v20091103_r352) "Debug Core" [Active]
org.eclipse.debug.ui (3.5.2.v20091028_r352) "Debug UI" [Active]
org.eclipse.draw2d (3.5.2.v20091126-1908) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.ecf (3.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Active]
org.eclipse.ecf.filetransfer (3.0.0.v20090831-1906) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.0.0.v20090831-1906) "ECF Identity API" [Active]
org.eclipse.ecf.provider.filetransfer (3.0.1.v20090831-1906) "ECF Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (3.0.1.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20090831-1906) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20090831-1906) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.0.v20090831-1906) "Eclipse Communication Framework (ECF)" [Resolved]
org.eclipse.emf.common (2.5.0.v200906151043) "EMF Common" [Starting]
org.eclipse.emf.common.ui (2.5.0.v200906151043) "EMF Common UI" [Starting]
org.eclipse.emf.ecore (2.5.0.v200906151043) "EMF Ecore" [Starting]
org.eclipse.emf.ecore.change (2.5.0.v200906151043) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.edit (2.5.0.v200906151043) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.xmi (2.5.0.v200906151043) "EMF XML/XMI Persistence" [Starting]
org.eclipse.emf.edit (2.5.0.v200906151043) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.5.0.v200906151043) "EMF Edit UI" [Starting]
org.eclipse.epp.package.java (1.2.2.20100122-1337) "EPP Java Package" [Resolved]
org.eclipse.epp.usagedata.gathering (1.1.1.R201001291118) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.1.1.R201001291118) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.1.1.R201001291118) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.2.1.R35x_v20091203) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.5.1.R35x_v20090807-1100) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.1.R35x_v20100209) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.1.1.R35x_v20090806) "Declarative Services" [Active]
org.eclipse.equinox.frameworkadmin (1.0.100.v20090520-1905) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.101.R35x_v20091214) "Equinox Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (2.0.0.v20090520-1800) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.0.200.v20090520-1800) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.200.v20090520-1800) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.200.v20090520-1800) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.100.v20090520-1800) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.201.R35x_v20090715) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.200.v20090519) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.0.101.R35x_v20090721) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.100.v20090520-1905) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (1.0.101.R35x_v20090819) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (1.0.101.R35x_v20100112) "Equinox Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.0.101.R35x_v20091106) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.100.v20090525) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.engine (1.0.102.R35x_v20091117) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.exemplarysetup (1.0.100.v20090520-1905) "Equinox Provisioning Exemplary Setup" [Active]
org.eclipse.equinox.p2.extensionlocation (1.0.100.v20090520-1905) "Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.100.v20090520-1905) "Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.0.100.v20090520-1905) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (1.0.101.R35x_v20100112) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.generator (1.0.101.R35x_20100114) "Equinox Provisioning Metadata Generator" [Starting]
org.eclipse.equinox.p2.metadata.repository (1.0.101.R35x_v20090812) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.publisher (1.0.1.R35x_20100105) "Equinox Provisioning Publisher" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.0.100.v20090520-1905) "Dropin Reconciler Plug-in" [Active]
org.eclipse.equinox.p2.repository (1.0.1.R35x_v20100105) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (1.0.2.R35x_20100111) "Equinox p2 repository tools." [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (1.0.101.R35x_20090820-1821) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.101.R35x_v20090806) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.ui (1.0.101.R35x_v20090819) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.sdk (1.0.100.v20090520-1905) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.0.v20090520-1905) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.0.v20090520-1905) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.101.R35x_20100105) "Update site repository adapter bundle (Incubation)" [Starting]
org.eclipse.equinox.preferences (3.2.301.R35x_v20091117) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.4.100.v20090520-1800) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.0.100.v20090520-1800) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.0.100.v20090520-1800) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.100.v20090520-1800) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.101.R35x_v20090807-1100) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (1.0.101.R35x_v20100209) "Simple Configurator Manipulator" [Active]
org.eclipse.equinox.util (1.0.100.v20090520-1800) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.5.1.v20090910-2020) "Graphical Editing Framework GEF" [Starting]
org.eclipse.help (3.4.1.v20090805_35x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20090429_1800) "Help Application Server" [Starting]
org.eclipse.help.base (3.4.0.v201002111343) "Help System Base" [Starting]
org.eclipse.help.ui (3.4.1.v20090819_35x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.4.1.v20091009_35x) "Help System Webapp" [Starting]
org.eclipse.jdt (3.5.2.v201002111343) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.202.R35x_v20091130-2300) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.201.R35x_v20090925-1100) "Java Compiler Apt IDE" [Active]
org.eclipse.jdt.apt.ui (3.3.200.v20090930-2100_R35x) "Java Annotation Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.201.R35x_v20090925-1100) "Java Compiler Apt" [Resolved]
org.eclipse.jdt.compiler.tool (1.0.100.v_981_R35x) "Java Compiler Tool Support" [Resolved]
org.eclipse.jdt.core (3.5.2.v_981_R35x) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.3.0.v20090603) "Java Code Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.5.0.v20090526) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.4.1.v20090811_r351) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.user (3.5.2.r352_v20091015) "Eclipse Java development user guide" [Resolved]
org.eclipse.jdt.junit (3.5.2.r352_v20100113-0800) "Java Development Tools JUnit support" [Active]
org.eclipse.jdt.junit.runtime (3.4.100.v20090513-2000) "Java Development Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.1.0.v20090513-2000) "Java Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.5.1.v20100108_r352) "Java Development Tools Launching Support" [Active]
org.eclipse.jdt.ui (3.5.2.r352_v20100106-0800) "Java Development Tools UI" [Active]
org.eclipse.jem.util (2.0.201.v201001252130) "Java EMF Model Utilities" [Starting]
org.eclipse.jface (3.5.2.M20100120-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.3.1.M20090826-0800) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.5.2.r352_v20091118-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.1.100.I20090430-0408) "JSch Core" [Active]
org.eclipse.jsch.ui (1.1.200.r35x_20100210-1114) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.5.0.v20090513-2000) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.4.101.r352_v20100209) "Refactoring UI" [Active]
org.eclipse.mylyn (3.3.2.v20100222-0100-e3x) "Mylyn" [Resolved]
org.eclipse.mylyn.bugzilla.core (3.3.2.v20100222-0100-e3x) "Mylyn Bugzilla Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (3.3.2.v20100222-0100-e3x) "Mylyn Bugzilla IDE Extensions" [Resolved]
org.eclipse.mylyn.bugzilla.ui (3.3.2.v20100222-0100-e3x) "Mylyn Bugzilla Connector UI" [Active]
org.eclipse.mylyn.commons.core (3.3.2.v20100222-0100-e3x) "Mylyn Commons Core" [Resolved]
org.eclipse.mylyn.commons.net (3.3.0.v20091013-0200-e3x) "Mylyn Commons Net" [Active]
org.eclipse.mylyn.commons.ui (3.3.2.v20100222-0100-e3x) "Mylyn Commons UI" [Active]
org.eclipse.mylyn.compatibility (3.3.2.v20100222-0100-e3x) "Java 5 Compatibility Checker" [Resolved]
org.eclipse.mylyn.context.core (3.3.2.v20100222-0100-e3x) "Mylyn Context Core" [Active]
org.eclipse.mylyn.context.ui (3.3.2.v20100222-0100-e3x) "Mylyn Context UI" [Active]
org.eclipse.mylyn.discovery.core (3.3.2.v20100222-0100-e3x) "Mylyn Connector Discovery Core" [Resolved]
org.eclipse.mylyn.discovery.ui (3.3.2.v20100222-0100-e3x) "Mylyn Connector Discovery UI" [Resolved]
org.eclipse.mylyn.help.ui (3.3.2.v20100222-0100-e3x) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (3.3.2.v20100222-0100-e3x) "Mylyn Ant Bridge" [Starting]
org.eclipse.mylyn.ide.ui (3.3.2.v20100222-0100-e3x) "Mylyn IDE UI" [Starting]
org.eclipse.mylyn.java.tasks (3.3.2.v20100222-0100-e3x) "Mylyn Java Tasks" [Starting]
org.eclipse.mylyn.java.ui (3.3.2.v20100222-0100-e3x) "Mylyn Java Bridge" [Starting]
org.eclipse.mylyn.monitor.core (3.3.2.v20100222-0100-e3x) "Mylyn Monitor Core" [Resolved]
org.eclipse.mylyn.monitor.ui (3.3.2.v20100222-0100-e3x) "Mylyn Monitor UI" [Active]
org.eclipse.mylyn.resources.ui (3.3.2.v20100222-0100-e3x) "Mylyn Resources UI" [Starting]
org.eclipse.mylyn.tasks.bugs (3.3.2.v20100222-0100-e3x) "Mylyn Bug Reporting" [Starting]
org.eclipse.mylyn.tasks.core (3.3.2.v20100222-0100-e3x) "Mylyn Tasks Core" [Resolved]
org.eclipse.mylyn.tasks.ui (3.3.2.v20100222-0100-e3x) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (3.3.2.v20100222-0100-e3x) "Mylyn CVS Extensions" [Resolved]
org.eclipse.mylyn.team.ui (3.3.2.v20100222-0100-e3x) "Mylyn Team UI" [Active]
org.eclipse.mylyn.wikitext.confluence.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Confluence" [Resolved]
org.eclipse.mylyn.wikitext.confluence.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Confluence UI" [Resolved]
org.eclipse.mylyn.wikitext.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText" [Starting]
org.eclipse.mylyn.wikitext.help.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Help UI" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText MediaWiki" [Resolved]
org.eclipse.mylyn.wikitext.mediawiki.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText MediaWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.tasks.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Tasks UI" [Starting]
org.eclipse.mylyn.wikitext.textile.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Textile" [Resolved]
org.eclipse.mylyn.wikitext.textile.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Textile UI" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText TracWiki" [Resolved]
org.eclipse.mylyn.wikitext.tracwiki.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText TracWiki UI" [Resolved]
org.eclipse.mylyn.wikitext.twiki.core (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Twiki" [Resolved]
org.eclipse.mylyn.wikitext.twiki.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText Twiki UI" [Resolved]
org.eclipse.mylyn.wikitext.ui (1.2.1.v20100222-0100-e3x) "Mylyn WikiText UI" [Starting]
org.eclipse.osgi (3.5.2.R35x_v20100126) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.2.0.v20090520-1800) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (3.3.202.v201002111343) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.5.2.r352_v20091111-0800) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (3.5.0.v201002111343) "Eclipse RCP" [Starting]
org.eclipse.search (3.5.1.r351_v20090708-0800) "Search Support" [Starting]
org.eclipse.swt (3.5.2.v3557f) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.5.2.v3557f) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.5.1.r35x_20100113-0800) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.200.I20090430-0408) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.2.100.I20090508-2000) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.200.I20090508-2000) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.202.r35x_20090930-0800) "CVS Team Provider UI" [Active]
org.eclipse.team.svn (0.7.8.I20091023-1300) "Subversive SVN Team Provider (Incubation)" [Resolved]
org.eclipse.team.svn.core (0.7.8.I20091023-1300) "Subversive SVN Team Provider Core Plug-in (Incubation)" [Active]
org.eclipse.team.svn.help (0.7.8.I20091023-1300) "Subversive SVN Team Provider User Guide Plug-in (Incubation)" [Resolved]
org.eclipse.team.svn.ui (0.7.8.I20091023-1300) "Subversive SVN Team Provider UI Plug-in (Incubation)" [Active]
org.eclipse.team.ui (3.5.0.I20090430-0408) "Team Support UI" [Active]
org.eclipse.text (3.5.0.v20090513-2000) "Text" [Resolved]
org.eclipse.ui (3.5.2.M20100120-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.301.v20091215_35x) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.200.v20090526) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.4.0.v20090513) "Console" [Active]
org.eclipse.ui.editors (3.5.0.v20090527-2000) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.2.0.v20090504) "External Tools" [Starting]
org.eclipse.ui.forms (3.4.1.v20090714_35x) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.5.2.M20100113-0800) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.101.M20090826-0800) "Eclipse IDE UI Application" [Resolved]
org.eclipse.ui.intro (3.3.2.v20100111_35x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.300.v20090526) "Universal Welcome" [Starting]
org.eclipse.ui.navigator (3.4.2.M20100120-0800) "Common Navigator View" [Starting]
org.eclipse.ui.navigator.resources (3.4.1.M20090826-0800) "Navigator Workbench Components" [Starting]
org.eclipse.ui.net (1.2.1.r35x_20090812-1200) "Internet Connection Management UI" [Active]
org.eclipse.ui.presentations.r21 (3.2.100.M20091015-0930) "R21 Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.4.1.M20090826-0800) "Views" [Active]
org.eclipse.ui.views.log (1.0.100.v20090731) "Log View" [Active]
org.eclipse.ui.views.properties.tabbed (3.5.0.I20090429-1800) "Tabbed Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.v20090429-1800) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.5.2.M20100113-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20090429-1800) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.5.1.r352_v20100105) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.3.0.v20090312) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.300.v20090525) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.100.v20080107) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.200.v20081127) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.201.R35x_v20090813) "Install/Update UI" [Starting]
org.eclipse.wst.common.core (1.1.201.v200806010600) "WST Common Core Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.301.v200908181930) "EMF Utilities" [Starting]
org.eclipse.wst.common.emfworkbench.integration (1.1.301.v200908101600) "EMF Workbench Edit Plug-in" [Starting]
org.eclipse.wst.common.environment (1.0.301.v200908101600) "Enviornment Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.300.v200904160730) "Common Frameworks" [Starting]
org.eclipse.wst.common.frameworks.ui (1.1.301.v200908101600) "WTP UI Plug-in" [Starting]
org.eclipse.wst.common.infopop (1.0.100.v200805301550) "Common WST infopops" [Starting]
org.eclipse.wst.common.modulecore (1.1.301.v201001252130) "Modulecore Plug-in" [Starting]
org.eclipse.wst.common.project.facet.core (1.4.1.v200911141735) "Eclipse Faceted Project Framework" [Starting]
org.eclipse.wst.common.snippets (1.1.301.v201001280015) "Snippets View" [Starting]
org.eclipse.wst.common.ui (1.1.402.v200901262305) "Eclipse Base UI extensions" [Starting]
org.eclipse.wst.common.uriresolver (1.1.301.v200805140415) "Common URI Resolver Framework" [Starting]
org.eclipse.wst.dtd.core (1.1.300.v200904181727) "Structured Source DTD Core" [Starting]
org.eclipse.wst.dtd.ui (1.0.400.v200904300717) "SSE DTD Source Editor" [Starting]
org.eclipse.wst.dtd.ui.infopop (1.0.300.v200805140200) "DTD Editor infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.500.v200904292308) "DTD Editor documentation" [Resolved]
org.eclipse.wst.internet.cache (1.0.301.v200805140020) "Cache URI Resolver Plug-in" [Starting]
org.eclipse.wst.sse.core (1.1.402.v201001251516) "Structured Text Model" [Active]
org.eclipse.wst.sse.doc.user (1.1.0.v200805211530) "Structured text editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.1.102.v200910200227) "Structured Source Editor" [Starting]
org.eclipse.wst.sse.ui.infopop (1.0.200.v200805301545) "SSE infopops" [Resolved]
org.eclipse.wst.standard.schemas (1.0.200.v200902270215) "Standard Schemas and DTDs" [Resolved]
org.eclipse.wst.validation (1.2.104.v200911120201) "Validation Framework" [Starting]
org.eclipse.wst.validation.infopop (1.0.300.v200806041506) "WST validation infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.2.104.v200904232035) "Validation Framework UI" [Starting]
org.eclipse.wst.xml.core (1.1.402.v201001222130) "Structured Source XML Model" [Starting]
org.eclipse.wst.xml.ui (1.1.2.v201001222130) "Eclipse XML Editors and Tools" [Starting]
org.eclipse.wst.xml.ui.infopop (1.0.300.v200805140200) "XML infopops" [Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.600.v200901231300) "XML editor" [Resolved]
org.eclipse.wst.xsd.core (1.1.401.v200903020335) "XSD Core Plugin" [Starting]
org.eclipse.wst.xsd.ui (1.2.204.v200909021537) "XML Schema Editor" [Starting]
org.eclipse.wst.xsdeditor.doc.user (1.0.700.v200905182240) "XML schema editor" [Resolved]
org.eclipse.xsd (2.5.0.v200906151043) "XSD Model" [Starting]
org.eclipse.xsd.edit (2.5.0.v200906151043) "XSD Edit" [Starting]
org.hamcrest.core (1.1.0.v20090501071000) "Hamcrest Core Library of Matchers" [Starting]
org.junit (3.8.2.v20090203-1005) "JUnit Testing Framework" [Resolved]
org.junit4 (4.5.0.v20090824) "JUnit Testing Framework Version 4" [Resolved]
org.mortbay.jetty.server (6.1.15.v200905151201) "Jetty Server" [Resolved]
org.mortbay.jetty.util (6.1.15.v200905182336) "Jetty Utilities" [Resolved]
org.polarion.eclipse.team.svn.connector (2.2.1.I20091009-1900) "Subversive SVN Connectors" [Resolved]
org.polarion.eclipse.team.svn.connector.svnkit16 (2.2.1.I20091009-1900) "Subversive SVN 1.6 SVN Kit Connector" [Active]
org.sat4j.core (2.1.1.v20090825) "SAT4J Core" [Resolved]
org.sat4j.pb (2.1.1.v20090825) "SAT4J Pseudo" [Resolved]
*** User Preferences:
#Fri May 07 17:09:40 GMT 2010
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.indent_parameter_description=true
@org.eclipse.ui.editors=3.5.0.v20090527-2000
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation_type_declaration=do not insert
@org.eclipse.debug.ui=3.5.2.v20091028_r352
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_enum_constant=next_line
@org.eclipse.core.net=1.2.1.r35x_20090812-1200
/profile/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/auto UpdateInit=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_binary_operator=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_invocation_arguments=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_prefix_operator=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_if=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_type_arguments=insert
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_throws=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_enum_constants=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_annotation_type_decla ration=insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_allocation_exp ression=do not insert
/instance/org.eclipse.ui.views.log/groupBy=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.6
@org.eclipse.mylyn.monitor.ui=3.3.2.v20100222-0100-e3x
/instance/org.eclipse.debug.ui/Console.highWaterMark=88000
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_cases=true
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_synchronized=do not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_statement_on_same_line=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_parenthesized_expressi on=do not insert
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_for_increments=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_parameterized _type_reference=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_multiple_field_declarations=d o not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier New|10.0|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_constructor_declarati on=do not insert
/instance/org.eclipse.team.svn.ui/org.eclipse.team.svn.ui.pa nel.common.SelectRevisionPanel.height=395
/instance/org.eclipse.jdt.ui/formatter_profile=_LIVEPerson
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_conditional_expression=80
/instance/org.eclipse.team.svn.ui/org.eclipse.team.svn.ui.pa nel.local.OverrideResourcesPanel.width=600
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.format_header=true
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_angle_bracket_in_parameterized _type_reference=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_enum_constant=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.insert_new_line_before_root_tags=insert
@org.eclipse.ui=3.5.2.M20100120-0800
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.exception.na me=e
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_compact_if=16
/instance/org.eclipse.team.svn.ui/org.eclipse.team.svn.ui.pa nel.reporting.ErrorCancelPanel.width=640
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJsrBytecode=enabled
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_before_else_in_if_statement=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_bracket_in_array_reference=do not insert
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant_sec_id=1273062141387
/instance/org.eclipse.team.svn.ui/preference.repository.repo sitoryBrowser=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_closing_paren_in_cast=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_explicitconstructorcall_argum ents=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_annotation_type_declaration=next_line
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_constructor_declarati on=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_bracket_in_array_allocation_ex pression=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_for=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.debug.ui/preferredTargets=default\:def ault|
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_parameters_in_constructor_declaration=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_between_type_declarations=1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.mylyn.context.core=3.3.2.v20100222-0100-e3x
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_multiple_field_declarations=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_after_annotation_on_local_variable=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_arguments_in_explicit_constructor_call=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.use_tabs_only_for_leading_indentations=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_braces_in_array_initializer=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_catch=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_enum_declaration=insert
/instance/org.eclipse.team.svn.ui/org.eclipse.team.svn.ui.pa nel.local.OverrideResourcesPanel.height=224
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_switch=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_package=0
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_parameters =do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_member_type=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_assignment_operator=insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.gettersetter .use.is=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_method_body=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.staticFinalFieldSuffixes=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_annotation_type_membe r_declaration=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_empty_array_initializer_on_one_line=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_ellipsis=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.tabulation.char=space
@org.eclipse.jdt.debug.ui=3.4.1.v20090811_r351
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_array_initializer=end_of_line
/instance/org.eclipse.team.svn.ui/history.comment=YnVnaWQ6MD AwMA0KQ1IgYnk6IEVkIFNvbmlhdA0KUmVtb3ZlZCBsZWFkaW5nIHplcm9zIG Zyb20gbWV0YSBtb2RlbCB2ZXJzaW9uIHBhcnQgb2YgbW9kZWwgbmFtZSBmb3 IgUUEgdGVzdGluZw\=\=;YnVnaWQ6MDAwMA0KQ3IgQnk6IEVDUw0KUmVtb3Z lZCBsZWFkaW5nIHplcm9zIGZyb20gbWV0YSBtb2RlbCB2ZXJzaW9uIHBhcnQ gb2YgbW9kZWwgbmFtZS4\=;QnVnaWQ6MDANCkNyIGJ5OkVDUw0KUmVtb3ZlZ CBsZWFkaW5nIHplcm9zIGZyb20gbWV0YSBtb2RlbCB2ZXJzaW9uIHBhcnQgb 2YgbmFtZQ\=\=
/instance/org.eclipse.team.ui/teamContentDescriptors/org.ecl ipse.team.svn.core.svnChangeSetModel/enabled=true
/instance/org.eclipse.team.svn.ui/org.eclipse.team.svn.ui.pa nel.reporting.ErrorCancelPanel.height=431
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.align_type_members_on_columns=false
@org.eclipse.team.svn.ui=0.7.8.I20091023-1300
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and Settings\\eds\\eclipse\\workspace\nD\:\\hcdevsvn\\server\\cu rver\nC\:\\Documents and Settings\\eds\\workspace
/instance/org.eclipse.team.ui/org.eclipse.team.ui.sychronizi ng_default_participant=org.eclipse.team.svn.ui.synchronize.u pdate.SynchronizeModelParticipant
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_postfix_operator=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_method_declaration=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_arguments_in_method_invocation=16
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_colon_in_default=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_block_in_case=next_line
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_block=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_switch=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_closing_brace_in_block=insert
/instance/org.eclipse.ui.workbench/org.eclipse.ui.commands=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<org.eclipse.ui.commands>\r\n<activeKeyConfiguration keyConfigurationId\="org.eclipse.ui.emacsAcceleratorConfiguration "/>\r\n</org.eclipse.ui.commands>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_allocation_expression=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_annotation=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_field=1
/instance/org.eclipse.ui.views.log/orderValue=-1
/instance/org.eclipse.team.ui/teamContentDescriptors/org.ecl ipse.team.cvs.core.changeSetModel/enabled=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_between_empty_parens_in_annotation_type_membe r_declaration=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_imple_if_on_one_line=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_type_paramete rs=do not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_block=next_line
/instance/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=true
/instance/org.eclipse.jdt.ui/formatter_settings_version=11
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.format_javadoc_comments=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_parenthesized_expression_in_throw=inse rt
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.continuation_indentation_for_array_initializer=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_new_line_in_empty_block=insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.nav igator.layout=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
@org.eclipse.team.cvs.ui=3.3.202.r35x_20090930-0800
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.wrap_before_binary_operator=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.6
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.blank_lines_before_imports=1
Re: Java editor fails opening java file. [message #532262 is a reply to message #532258] Fri, 07 May 2010 13:48 Go to previous messageGo to next message
Could you please try with 3.6M7?
If you can reproduce, please open a bug report against JDT/Core with steps to reproduce.
Olivier
Re: Java editor fails opening java file. [message #532267 is a reply to message #532262] Fri, 07 May 2010 14:13 Go to previous messageGo to next message
Problem solved.
This is user error.
Somehow, and I have no idea how, the java source file was in the Referenced Libraries. As such when I tried to open it with the editor it treated it as an archive and it is not a valid archive.
Perhaps it should have been handled better but I see no real bug here.
Thank you for considering my post.
Re: Java editor fails opening java file. [message #532292 is a reply to message #532267] Fri, 07 May 2010 15:27 Go to previous messageGo to next message
Please open a bug report against JDT/Core with your specific settings that led to this error.
Even if this might be an error case, we must handle it better.
Olivier
Re: Java editor fails opening java file. [message #532299 is a reply to message #532292] Fri, 07 May 2010 16:19 Go to previous messageGo to next message
The problem with submitting a bug report is I don't know how to replicate it.
The java file showed up on the "Referenced Libraries". I removed it from there and it fixed the problem.
If I return it to the classpath via Eclipse it doesn't demonstrate the problem.
I don't know how it got into the classpath to cause this problem. I even tried editing the classpath (which I'm fairly certain was not how the problem was caused) but that didn't replicate the problem.
I didn't check the .classpath to see what the entry was before I removed it via eclipse so I don't know what the entry looked like. The problem wasn't in the version is SVN so I don't know how to find what changes were made.
If you sill want a bug report I can enter one but with out any instructions on how to replicate it.
Re: Java editor fails opening java file. [message #549617 is a reply to message #532258] Tue, 27 July 2010 07:35 Go to previous messageGo to next message
I also have this error with:
Eclipse Java EE IDE for Web Developers.
Version: 1.3.0.20100617-0521
Build id: 20100617-1415
It hapens when i use context menu -> Build Path -> Add to Build Path for a java file not in a source folder.
It also crashes the Package Explorer View after first Eclipse restart.
[Updated on: Tue, 27 July 2010 07:36] by Moderator
Re: Java editor fails opening java file. [message #549619 is a reply to message #549617] Tue, 27 July 2010 07:42 Go to previous messageGo to next message
Did you check your referenced libraries for a java file? If so see if you can figure out how it go in there so that you can file a bug report and give the developers a chance to handle this better.
Re: Java editor fails opening java file. [message #549892 is a reply to message #549619] Wed, 28 July 2010 07:38 Go to previous messageGo to next message
Yes, the referenced libraries contain the java file.
It got there by mistake using
for that file instead
context menu -> Build Path -> Use as Source Folder
for the containing folder.
I opened the java file that led to crash from referenced libraries with Open Resource window.
Re: Java editor fails opening java file. [message #550026 is a reply to message #549892] Wed, 28 July 2010 15:28 Go to previous message
Reproduced with latest, I opened bug 321170.
Olivier
Previous Topic:Help with creating new project from source in Eclipse Helios
Next Topic:APT (Java 6) and JDT : What's wrong ?
Current Time: Wed Nov 05 11:33:19 EST 2025
Powered by FUDForum. Page generated in 0.04549 seconds
