Re: Problems with Swordfish Headless Build [message #533899 is a reply to message #533192] |
Mon, 17 May 2010 12:40 |
Jari Messages: 22 Registered: May 2010 |
Junior Member |
Hello
I tried to run the Headless Build with -Dlocal=true but come up with errors like:
[java] [eclipse.buildScript] Some inter-plug-in dependencies have not beensatisfied.
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.apt.pluggable.core:
[java] [eclipse.buildScript] Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.jdt.internal.compiler.tool_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.jdt.internal.compiler.apt.dispatch_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.jdt.internal.compiler.apt.model_0.0.0.
[java] [eclipse.buildScript] Unsatisfied import package org.eclipse.jdt.internal.compiler.apt.util_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.compiler.apt:
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.compiler.tool:
[java] [eclipse.buildScript] Bundle org.tigris.subversion.subclipse.core:
[java] [eclipse.buildScript] Another singleton version selected: org.tigris.subversion.subclipse.core_1.6.10
[java] [eclipse.buildScript] Bundle org.tigris.subversion.subclipse.ui:
[java] [eclipse.buildScript] Another singleton version selected: org.tigris.subversion.subclipse.ui_1.6.10
[java]
[java] BUILD FAILED
[java] C:\Documents and Settings\user\workspace_soa\org.eclipse.swordf
ish.build\tmp\eclipse\plugins\org.eclipse.pde.build_3.5.2.R3 5x_20100114\scripts\
build.xml:35: The following error occurred while executing this line:
build.xml:91: The following error occurred while executing this line:
ish.build\tmp\eclipse\plugins\org.eclipse.pde.build_3.5.2.R3 5x_20100114\template
s\headless-build\customTargets.xml:12: The following error occurred while execut
ing this line:
s\headless-build\allElements.xml:16: The following error occurred while executin
g this line:
genericTargets.xml:106: Unable to find feature: org.eclipse.swordfish.build.feat
ure.
[java]
[java] Total time: 4 seconds
BUILD FAILED
C:\Documents and Settings\user\workspace_soa\org.eclipse.swordfish.build\bu
ild.xml:275: The following error occurred while executing this line:
ild.xml:230: Java returned: 13
Total time: 3 minutes 16 seconds
Everything went well with the third parties build. Is there something wrong with my java version or is it something else?
I'm using:
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) Client VM (build 16.3-b01, mixed mode, sharing)
Thanks and regards
Jari
[Updated on: Mon, 17 May 2010 12:42] Report message to a moderator
FUDForum. Page generated in 0.07357 seconds
