Re: Property "description" generated with attribute "multiline" to "yes&quo [message #532155 is a reply to message #532148] |
Fri, 07 May 2010 11:04 |
Ed Merks Messages: 33142 Registered: July 2009 |
Carlos,
I suppose a cell editor that can't edit would still be useful be we
don't have such a thing. You'd need to follow the EMF recipe for a
custom cell editor to suit this purpose.
Carlos wrote:
> Hi.
> I have an element in my metamodel which contains a property
> description, generated like a multiline property.
> In order to edit the property value, you can click on the property
> value and fill in with the text.
> However, if the model is read only, obviusly, you can't edit the value
> and you won't see the complete text. (The tool tip also appears cut...).
> Is there any way for being able to see the entire description when the
> model is read only? Have you got any suggestion?
> Thanks in advance.
> Best regards, Carlos.
Ed Merks
FUDForum. Page generated in 2.79411 seconds
