Home » Archived » BIRT » Chart Engine API - how to implement zoom
Chart Engine API - how to implement zoom [message #532094] |
Fri, 07 May 2010 07:40 |
i'am currently developing an Eclipse RCP application and use the BIRT Chart Engine API to visualize some data.
I need to possibility to zoom in and out my charts. Can someone give me an example how to implement this.
Or to help me, developing an own implementation:
- how can I get the bounds of the client area (chart.getPlot.getClientArea())
- how can I scale my chart. (e.g. x-axis from 15 to 25, instead of 0 to 100)
- is it possible to write an mouse move/ mouse down/ mouse up event handler in Java and get the coords of the cursor.
Thanks in advance!
-- Martin
Re: Chart Engine API - how to implement zoom [message #532273 is a reply to message #532094] |
Fri, 07 May 2010 18:16 |
Martin,
Will the SVG Zoom capability not work for you?
I do not have an example of this in the chart engine api, but you should
be able to implement something using a callback.
There is an example of implementing a callback for swt charts in the
source. Its called SwtInteractivityViewer.java. If you setup callback
on the axis, you should be able to do something with a zoom. The
callback is passed the event which has the coordinates and then you can
just rescale the axis and repaint the chart. I am attaching the
SwtInteractivyViewer.java class and the chart model that sets up a
callback on the series (click on a bar).
Chart model
protected static final Chart createCBChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Click \"Items\" to Call Back" ); //$NON-NLS-1$
cwaBar.setUnitSpacing( 20 );
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.getOutline( ).setVisible( false );
lg.setAnchor( Anchor.NORTH_LITERAL );
lg.setItemType( LegendItemType.CATEGORIES_LITERAL );
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getTitle( ).setVisible( true );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 90 );
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create( new String[]{
"Item 1", "Item 2", "Item 3"} ); //$NON-NLS-1$ //$NON-NLS-2$
//$NON-NLS-3$
NumberDataSet orthoValues = NumberDataSetImpl.create( new double[]{
25, 35, 15
// X-Series
Series seCategory = SeriesImpl.create( );
seCategory.setDataSet( categoryValues );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
sdX.getSeriesPalette( ).shift( 0 );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
BarSeries bs = (BarSeries) BarSeriesImpl.create( );
bs.setDataSet( orthoValues );
bs.setRiserOutline( null );
bs.setSeriesIdentifier( "Callback" ); //$NON-NLS-1$
bs.getLabel( ).setVisible( true );
bs.setLabelPosition( Position.INSIDE_LITERAL );
bs.getTriggers( )
.add( TriggerImpl.create( TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create( ActionType.CALL_BACK_LITERAL,
CallBackValueImpl.create( String.valueOf(
bs.getSeriesIdentifier( ) ) ) ) ) );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( bs );
return cwaBar;
Swt interactive chart example
* Copyright (c) 2004 Actuate Corporation.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Actuate Corporation - initial API and implementation
package org.eclipse.birt.chart.examples.api.interactivity;
import org.eclipse.birt.chart.device.ICallBackNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.CallBackValue;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
* The selector of charts in SWT.
public final class SwtInteractivityViewer extends Composite implements
PaintListener,
ICallBackNotifier,
SelectionListener
private IDeviceRenderer idr = null;
private Chart cm = null;
private static Combo cbType = null;
private static Button btn = null;
private GeneratedChartState gcs = null;
private boolean bNeedsGeneration = true;
* main() method for constructing the layout.
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
SwtInteractivityViewer siv = new SwtInteractivityViewer( shell,
SWT.NO_BACKGROUND );
siv.setLayoutData( new GridData( GridData.FILL_BOTH ) );
siv.addPaintListener( siv );
Composite cBottom = new Composite( shell, SWT.NONE );
cBottom.setLayoutData( new GridData( GridData.FILL_HORIZONTAL ) );
cBottom.setLayout( new RowLayout( ) );
Label la = new Label( cBottom, SWT.NONE );
la.setText( "Choose: " );//$NON-NLS-1$
cbType = new Combo( cBottom, SWT.DROP_DOWN | SWT.READ_ONLY );
cbType.add( "Highlight Series" );//$NON-NLS-1$
cbType.add( "Show Tooltip" );//$NON-NLS-1$
cbType.add( "Toggle Visibility" );//$NON-NLS-1$
cbType.add( "URL Redirect" );//$NON-NLS-1$
cbType.add( "Multiple URLs Redirect" );//$NON-NLS-1$
cbType.add( "Call Back" );//$NON-NLS-1$
cbType.add( "Right Mouse Click" );//$NON-NLS-1$
cbType.add( "Mouse Cursor");//$NON-NLS-1$
cbType.select( 0 );
btn = new Button( cBottom, SWT.NONE );
btn.setText( "Update" );//$NON-NLS-1$
btn.addSelectionListener( siv );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Get the connection with SWT device to render the graphics.
SwtInteractivityViewer( Composite parent, int style )
super( parent, style );
PlatformConfig config = new PlatformConfig( );
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$ //$NON-NLS-2$
final PluginSettings ps = PluginSettings.instance( config );
try
idr = ps.getDevice( "dv.SWT" );//$NON-NLS-1$
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
catch ( ChartException ex )
ex.printStackTrace( );
cm = InteractivityCharts.createHSChart( );
* (non-Javadoc)
* @see
org.eclipse.swt.events.PaintListener#paintControl(org.eclips e.swt.events.PaintEvent)
public void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
gcs = gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null );
catch ( ChartException ce )
ce.printStackTrace( );
try
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
* (non-Javadoc)
* @see
org.eclipse.swt.events.SelectionListener#widgetSelected(org. eclipse.swt.events.SelectionEvent)
public void widgetSelected( SelectionEvent e )
if ( e.widget.equals( btn ) )
int iSelection = cbType.getSelectionIndex( );
switch ( iSelection )
case 0 :
break;
case 1 :
cm = InteractivityCharts.createSTChart( );
break;
case 2 :
cm = InteractivityCharts.createTVChart( );
break;
case 3 :
cm = InteractivityCharts.createURChart( );
break;
case 4 :
cm = InteractivityCharts.createMultiURChart( );
break;
case 5 :
cm = InteractivityCharts.createCBChart( );
break;
case 6 :
cm = InteractivityCharts.createRCChart( );
break;
case 7 :
cm = InteractivityCharts.createBarChartWithCursorExample( );
break;
this.redraw( );
* (non-Javadoc)
* @see
org.eclipse.swt.events.SelectionListener#widgetDefaultSelect ed(org.eclipse.swt.events.SelectionEvent)
public void widgetDefaultSelected( SelectionEvent e )
// TODO Auto-generated method stub
* (non-Javadoc)
* @see
org.eclipse.birt.chart.device.swing.IUpdateNotifier#getDesig nTimeModel()
public Chart getDesignTimeModel( )
return cm;
* (non-Javadoc)
* @see
org.eclipse.birt.chart.device.swing.IUpdateNotifier#getRunTi meModel()
public Chart getRunTimeModel( )
return gcs.getChartModel( );
public Object peerInstance( )
return this;
public void regenerateChart( )
redraw( );
public void repaintChart( )
redraw( );
public void callback( Object event, Object source, CallBackValue value )
MessageBox mb = new MessageBox ( this.getShell( ) );
mb.setMessage( value.getIdentifier( ) );
mb.open( );
On 5/7/2010 3:40 AM, Martin wrote:
> Or to help me, developing an own implementation: - how can I get the
> bounds of the client area (chart.getPlot.getClientArea()) - how can I
> Thanks in advance!
> -- Martin
Re: Chart Engine API - how to implement zoom [message #532435 is a reply to message #532273] |
Mon, 10 May 2010 00:17 |
Jason,
the SVG Zoom capability isn't enough for me. It is just like an image zoom, if I zoom in, I can't see the axes anymore.
I've seen the SwtInteractiveViewer example. If I set a callback on a series, it fires only if I click on the series itself and not if I click somewhere in the grid.
I think I need something like a recalculation from the x, y of the composite and the coordinates in the grid.
Any ideas out there?
-- Martin
Re: Chart Engine API - how to implement zoom [message #532659 is a reply to message #532435] |
Mon, 10 May 2010 16:59 |
Martin,
Can you try and put the event on the chart area instead of the series?
Jason
On 5/9/2010 8:17 PM, Martin wrote:
> Jason,
> -- Martin
Re: Chart Engine API - how to implement zoom [message #537445 is a reply to message #537392] |
Wed, 02 June 2010 13:26 |
You should be able to use something like
cwaBar.getPlot().getTriggers....
BTW I attached is an example (work in progress!!!!) report that uses to
client side script to re-run a report zoomed when you click on two
points on the y-axis.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<property name="units">in</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<parameters>
<scalar-parameter name="minScale" id="106">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">70</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="maxScale" id="107">
<value type="constant">110</value>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="detail" id="57">
<property name="backgroundColor">#BACAE2</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="headerfooter" id="58">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="59">
<property name="backgroundColor">#0080FF</property>
</style>
<style name="myrb" id="67">
<property name="backgroundAttachment">fixed</property>
<property name="backgroundColor">#FF8080</property>
<property name="borderBottomStyle">dashed</property>
<property name="borderLeftStyle">dashed</property>
<property name="borderRightStyle">dashed</property>
<property name="borderTopStyle">dashed</property>
<property name="whiteSpace">pre</property>
<property name="display">inline</property>
</style>
<style name="NewStyle" id="77">
</style>
<style name="NewStyle1" id="93">
<property name="canShrink">true</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">1in</property>
<property name="leftMargin">1.25in</property>
<property name="bottomMargin">1in</property>
<property name="rightMargin">1.25in</property>
</simple-master-page>
</page-setup>
<body>
<extended-item extensionName="Chart" name="NewChart" id="8">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithAxes
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:data="http://www.birt.eclipse.org/ChartModelData"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Bar Chart</Type>
<SubType>Side-by-side</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value>Bar Chart Title</Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Triggers>
<Condition>onmouseover</Condition>
<Action>
<Type>Show_Tooltip</Type>
<Value xsi:type="attribute:TooltipValue">
<Text>mouseover</Text>
<Delay>200</Delay>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>onclick</Condition>
<Action>
<Type>Highlight</Type>
<Value xsi:type="attribute:SeriesValue">
<Name></Name>
</Value>
</Action>
</Triggers>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value>dfsdf</Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
<ShowValue>true</ShowValue>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>442.49999999759996</Width>
<Height>246.7499999976</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Triggers>
<Action>
<Type>Invoke_Script</Type>
<Value xsi:type="attribute:ScriptValue">
<Script>startRubber(evt);</Script>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>onmousemove</Condition>
<Action>
<Script></Script>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>onmousedown</Condition>
<Action>
</Script>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>onmouseup</Condition>
<Action>
<Script>stopRubber(evt);
</Script>
</Value>
</Action>
</Triggers>
<Triggers>
<Condition>ondblclick</Condition>
<Action>
<Script></Script>
</Value>
</Action>
</Triggers>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Script>var topy=0;
var bottomy=0;
var scalemax=0;
var scalemin=9999999;
function beforeGeneration(chart, icsc)
importPackage( Packages.org.eclipse.birt.chart.model.data.impl );
xAxis = chart.getBaseAxes()[0];
yAxis = chart.getOrthogonalAxes( xAxis, true)[0]
yscale = yAxis.getScale();
yscale.setMin(
NumberDataElementImpl.create(icsc.getExternalContext().getSc riptable().getParameterValue("minScale"))
yscale.setMax(
NumberDataElementImpl.create(icsc.getExternalContext().getSc riptable().getParameterValue("maxScale"))
yAxis.setScale(yscale);
function beforeDrawAxisLabel( axis, label, icsc )
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
importPackage( Packages.java.lang );
if (axis.getType() == AxisType.LINEAR_LITERAL){
var curr = parseFloat(label.getCaption().getValue());
if( curr > scalemax){
scalemax=curr;
if( curr < scalemin){
scalemin=curr;
function beforeDrawBlock( block, icsc )
if( block.isPlot() ){
topy = block.getBounds().getTop()+50;
bottomy =
block.getBounds().getHeight()+block.getBounds().getTop()+30;
function afterRendering( gcs, icsc )
var slp = (scalemax-scalemin)/(bottomy-topy);
icsc.getExternalContext().getScriptable().setGlobalVariable( "scaleSlope",slp);
icsc.getExternalContext().getScriptable().setGlobalVariable( "scaleMin",scalemin);
icsc.getExternalContext().getScriptable().setGlobalVariable( "scaleMinY",bottomy);
</Script>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C'</DataSetRepresentation>
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>5.0,4.0,12.0</DataSetRepresentation >
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
<AncillarySampleData>
<DataSetRepresentation>Series 1</DataSetRepresentation>
</AncillarySampleData>
</SampleData>
<Interactivity>
<LegendBehavior>HighlightSerie</LegendBehavior>
</Interactivity>
<EmptyMessage>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</EmptyMessage>
<Axes>
<Type>Text</Type>
<Title>
<Caption>
<Value>X-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>0.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Below</TitlePosition>
<AssociatedAxes>
<Type>Linear</Type>
<Title>
<Caption>
<Value>Y-Axis Title</Value>
<Font>
<Size>14.0</Size>
<Bold>true</Bold>
<Alignment>
</Alignment>
<Rotation>90.0</Rotation>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Left</TitlePosition>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<Series xsi:type="type:BarSeries">
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<DataDefinition>
<Definition>row["QUANTITYORDERED"]</Definition >
</DataDefinition>
<SeriesIdentifier></SeriesIdentifier>
<DataPoint>
<Components>
<Type>Orthogonal_Value</Type>
</Components>
<Separator>, </Separator>
</DataPoint>
<LabelPosition>Outside</LabelPosition>
<Stacked>false</Stacked>
<Triggers>
<Action>
<Text>row["PRODUCTCODE"] + ", "
+row["QUANTITYORDERED"]</Text>
<Delay>200</Delay>
</Value>
</Action>
</Triggers>
<Riser>Rectangle</Riser>
</Series>
<Grouping>
<Enabled>false</Enabled>
<GroupingInterval>2.0</GroupingInterval>
<GroupType>Text</GroupType>
<AggregateExpression>Sum</AggregateExpression>
</Grouping>
<Sorting>Ascending</Sorting>
</SeriesDefinitions>
<LineAttributes>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</LineAttributes>
<Label>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Label>
<FormatSpecifier xsi:type="attribute:NumberFormatSpecifier">
<Prefix></Prefix>
<Suffix></Suffix>
<FractionDigits>2</FractionDigits>
</FormatSpecifier>
<LabelPosition>Left</LabelPosition>
<MajorGrid>
<LineAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</LineAttributes>
<TickStyle>Across</TickStyle>
<TickAttributes>
<Color>
<Red>196</Red>
<Green>196</Green>
<Blue>196</Blue>
</Color>
</TickAttributes>
</MajorGrid>
<MinorGrid>
<LineAttributes>
<Thickness&
Re: Chart Engine API - how to implement zoom [message #551474 is a reply to message #551461] |
Fri, 06 August 2010 14:29 |
I believe if you change the scale the chart has to do a rebuild. Have
you tried running build again?
On 8/6/2010 10:23 AM, asadanandan@axiomainc.com wrote:
> Sure . And I am also reposting my previous question here . Would you
> know why the zoom refresh does not work ?-
> I also have a problem when using the callback implementation to zoom (by
> rescaling and redrawing). After I do setStep() inside the callback, my
> charts are not refreshed to the newly zoomed scale.
> I tried explicitly calling gr.refresh(state), but the charts are not
> zooming. I am attaching my snippet here:
> @Override
> public void callback(Object event, Object source, CallBackValue value) {
> Axis xAxis = (
> (ChartWithAxes)((ChartCanvas)((MouseEvent)event).getSource()
> ).getChart()).getPrimaryBaseAxes()[0];
> System.out.println("Factor " + xAxis.getScale().getFactor() );
> xAxis.getScale().setStep(0.01);
> Axis yAxis = (
> ).getChart()).getPrimaryOrthogonalAxis(xAxis);
> yAxis.getScale().setStep(0.01);
> System.out.println("Step " + xAxis.getScale().getStep() + " " +
> yAxis.getScale().getStep());
> try {
> Generator gr = Generator.instance();
> gr.render(render, state);
> } catch(ChartException e) {
> e.printStackTrace();
Current Time: Fri Apr 26 07:06:52 GMT 2024
Powered by FUDForum. Page generated in 0.04119 seconds
