Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMF Compare NPE
EMF Compare NPE [message #531909] |
Thu, 06 May 2010 13:50 |
Tristan Faure Messages: 460 Registered: July 2009 |
Hi everyone,
I am using TOPCASED 3.3 (EMF Compare 1.0.0v200906220949) and some NPE
are raised depending on the way I call model comparison :
View : Project explorer => Action : Right click on UML file, Compare
with, Base from working copy => Comparison result : OK
with, Latest from repository => Comparison result : OK
with, Revision or URL => Comparison result : OK (Head and Revision)
with, Local History => Comparison result : KO (NPE)
View : Project explorer => Action : Select 2 UML file, right click,
Compare with, Each other => Comparison result : OK
View : Team synchronizing SVN => Action : Double click on modified model
View : Team synchronizing SVN => Action : Right click, open in compare
editor => Comparison result : KO (NPE)
View : History => Action : Right click on UML file, Team, Show history,
Select 2 revision, right click, compare each other => Comparison result : OK
Right click on a revision, Compare current with XX rev => Comparison
result : OK
Right click on a revision, Compare current with Previous state =>
View : History => Action : Right click on UML file, Team, Show local
history, Select 2 revision, right click, compare each other =>
Martin Neidert in his post ([message #136360]) has pointed out this NPE.
I don't find answer to his question.
Do you have any idea about the source of this issue ?
Stacktrace :
!ENTRY org.eclipse.jface 4 2 2010-05-05 14:43:57.609
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
at
org.eclipse.uml2.common.util.UML2Util.getResourceBundle(UML2 Util.java:442)
at
org.eclipse.uml2.common.util.UML2Util.getResourceBundle(UML2 Util.java:472)
at org.eclipse.uml2.common.util.UML2Util.getString(UML2Util.jav a:498)
at
org.eclipse.uml2.uml.internal.operations.NamedElementOperati ons.getLabel(NamedElementOperations.java:246)
at
org.eclipse.uml2.uml.internal.impl.NamedElementImpl.getLabel (NamedElementImpl.java:557)
at
org.eclipse.uml2.uml.edit.providers.LiteralBooleanItemProvid er.getText(LiteralBooleanItemProvider.java:119)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:380)
at
org.eclipse.jface.viewers.WrappedViewerLabelProvider.getText (WrappedViewerLabelProvider.java:108)
at
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:164)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:932)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:102)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:1012)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:481)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2111)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:827)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:802)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:776)
at
org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:639)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1709)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalExpandT oLevel(AbstractTreeViewer.java:1719)
at
at
at
at
at
at
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1054)
at
org.eclipse.jface.viewers.AbstractTreeViewer.expandToLevel(A bstractTreeViewer.java:1035)
at
org.eclipse.jface.viewers.AbstractTreeViewer.expandAll(Abstr actTreeViewer.java:1024)
at
org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.inputChanged(ModelContentMergeDiffTab.java: 369)
at
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
at
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1634)
at
org.eclipse.emf.compare.ui.viewer.content.part.diff.ModelCon tentMergeDiffTab.setReflectiveInput(ModelContentMergeDiffTab .java:284)
at
org.eclipse.emf.compare.ui.viewer.content.part.ModelContentM ergeTabFolder.setInput(ModelContentMergeTabFolder.java:309)
at
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.updateContent(ModelContentMergeViewer.java:755)
at
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in ternalRefresh(ContentMergeViewer.java:783)
at
org.eclipse.compare.contentmergeviewer.ContentMergeViewer.in putChanged(ContentMergeViewer.java:683)
at
at
org.eclipse.emf.compare.ui.viewer.content.ModelContentMergeV iewer.setInput(ModelContentMergeViewer.java:301)
at
org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:270)
at
org.eclipse.compare.internal.CompareContentViewerSwitchingPa ne.setInput(CompareContentViewerSwitchingPane.java:132)
at
org.eclipse.compare.CompareEditorInput.internalSetContentPan eInput(CompareEditorInput.java:817)
at
org.eclipse.compare.CompareEditorInput.access$8(CompareEdito rInput.java:815)
at
org.eclipse.compare.CompareEditorInput$11.run(CompareEditorI nput.java:755)
at
org.eclipse.compare.CompareEditorInput.feed1(CompareEditorIn put.java:749)
at
org.eclipse.compare.CompareEditorInput.feedInput(CompareEdit orInput.java:727)
at
org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:543)
at
org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:449)
at
org.eclipse.compare.internal.CompareEditor.access$6(CompareE ditor.java:416)
at
org.eclipse.compare.internal.CompareEditor$3.run(CompareEdit or.java:372)
at
org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:155)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer. java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3506)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Re: EMF Compare NPE [message #532801 is a reply to message #531909] |
Tue, 11 May 2010 09:28 |
--------------030309040604060804090803
Hi Tristan,
It seems like I missed Martin's question back when he pointed this issue
Thanks for the detailed use cases, this will help nailing out the issue
when we fix this.
However, there are two things here :
first, the failure comes from far out in the UML2 plugin. Please raise a
bug against MDT/UML2 in case they can give us more insight as to why we
get an NPE on this.
second, there are a number of ways label providers could fail when EMF
Compare asks for the display String of a given EObject ... could you
raise a bug against EMF/Compare so that we at least catch the NPEs and
display a "default" String in these cases? (Please attach the stack
trace and use cases so that we can track down the sources and catch a
fair number of potential failures.)
Laurent Goubet
Obeo
Tristan FAURE wrote:
> Hi everyone,
> : OK
> result : OK
> Stacktrace :
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030309040604060804090803--
Re: EMF Compare NPE [message #533851 is a reply to message #532801] |
Mon, 17 May 2010 09:40 |
Thank you for your answer !
I have already posted this question on UML2 forum
( http://www.eclipse.org/forums/index.php?t=msg&th=167713& amp;start=0&)
I have reported this bug on EMF Bugzilla :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313091
Kind regards
Tristan FAURE
Le 11/05/2010 11:28, Laurent Goubet a écrit :
> Hi Tristan,
> issue :'(.
> issue when we fix this.
> a bug against MDT/UML2 in case they can give us more insight as to why
> we get an NPE on this.
> Laurent Goubet
> Obeo
>> Hi everyone,
>> model => Comparison result : KO (NPE)
>> compare editor => Comparison result : KO (NPE)
>> history, Right click on a revision, Compare current with XX rev =>
>> history, Right click on a revision, Compare current with Previous
>> state => Comparison result : OK
>> NPE. I don't find answer to his question.
>> Stacktrace :
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: EMF Compare NPE [message #537663 is a reply to message #537654] |
Thu, 03 June 2010 09:56 |
--------------050501080607050606050503
Hi Raphael,
This hasn't been fixed and will not be for Helios, it is somewhat of an
important change and we need to double and triple check this before
committing in on the CVS.
Laurent Goubet
Obeo
Raphael Faudou wrote:
> Hi all,
> any news about a future fix on this bug?
> thanks
> raphaël
--------------050501080607050606050503--
Re: EMF Compare NPE [message #537700 is a reply to message #537663] |
Thu, 03 June 2010 12:11 |
OK, thanks for this clarification.
Note that this is an item (model comparison) which is now considered as "mandatory" for a company when choosing a modeling tool (from my experience, this is the third time in 6 months that I have such a request from "large" companies).
As it might "stop" the adoption of MDT papyrus, we might consider working on a fix in the next weeks (that will obviously be submitted as a patch).
regards
Raphaël & Papyrus team
Re: EMF Compare NPE [message #537710 is a reply to message #537700] |
Thu, 03 June 2010 12:48 |
--------------050602080309020605080501
No problem on our side, we always welcome patches and contributions :).
As we could point you to the classes and methods that need be fixed, do
not hesitate to ask when working on EMF Compare patches.
Laurent Goubet
Obeo
> a patch).
> regards
--------------050602080309020605080501--
Re: EMF Compare NPE [message #622873 is a reply to message #531909] |
Hi Tristan,
when we fix this.
get an NPE on this.
Laurent Goubet
Obeo
> Hi everyone,
> : OK
> result : OK
> Stacktrace :
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: EMF Compare NPE [message #622897 is a reply to message #532801] |
Kind regards
Tristan FAURE
> Hi Tristan,
> issue :'(.
> Laurent Goubet
> Obeo
>> Hi everyone,
>> Stacktrace :
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: EMF Compare NPE [message #622979 is a reply to message #537654] |
Hi Raphael,
Laurent Goubet
Obeo
> Hi all,
> thanks
> raphaël
Re: EMF Compare NPE [message #622981 is a reply to message #537663] |
regards
Re: EMF Compare NPE [message #622982 is a reply to message #537700] |
Laurent Goubet
Obeo
> a patch).
> regards
Current Time: Fri Apr 26 08:13:04 GMT 2024
Powered by FUDForum. Page generated in 0.04662 seconds
