Home » Eclipse Projects » EclipseLink » How to handle "null primary key encountered" exception?
How to handle "null primary key encountered" exception? [message #531645] |
Wed, 05 May 2010 12:41  |
Hi. I'm catching
... Null primary key encountered in unit of work clone ...
exception in eclipselink(2.0.2 with 2.0 jpa) literally meaning that id in my entity is <=0 (for primitive types). Though debug here states that everything's fine and I have nothing to worry about. My AS is glassfish v3. Can any one point out what may cause such behavior?
You may also find original description here.
Thanks in advance.
Re: How to handle "null primary key encountered" exception? [message #532828 is a reply to message #532277] |
Tue, 11 May 2010 06:40   |
I think this will be enough code.
@Table(name = "regions", catalog = "catalog_name")
@Entity
public class RegionsEntity {
private Long id;
@Column(name = "id", nullable = false, insertable = true, updatable = true, length = 20, precision = 0)
@Id
public Long getId() {
return id;
public void setId(Long id) {
this.id = id;
private String nameRu;
@Column(name = "name_ru", nullable = false, insertable = true, updatable = true, length = 256, precision = 0)
@Basic
public String getNameRu() {
return nameRu;
public void setNameRu(String nameRu) {
this.nameRu = nameRu;
private String nameUk;
@Column(name = "name_uk", nullable = false, insertable = true, updatable = true, length = 256, precision = 0)
@Basic
public String getNameUk() {
return nameUk;
public void setNameUk(String nameUk) {
this.nameUk = nameUk;
public boolean equals(Object o) {
if (this == o) return true;
if (o == null || getClass() != o.getClass()) return false;
RegionsEntity that = (RegionsEntity) o;
if (id != that.id) return false;
if (nameRu != null ? !nameRu.equals(that.nameRu) : that.nameRu != null) return false;
if (nameUk != null ? !nameUk.equals(that.nameUk) : that.nameUk != null) return false;
return true;
public int hashCode() {
int result = (int) (id ^ (id >>> 32));
result = 31 * result + (nameRu != null ? nameRu.hashCode() : 0);
result = 31 * result + (nameUk != null ? nameUk.hashCode() : 0);
return result;
private Collection<RegPurchaserEntity> regPurchasersById;
@OneToMany(mappedBy = "regionsByRegionid")
public Collection<RegPurchaserEntity> getRegPurchasersById() {
return regPurchasersById;
public void setRegPurchasersById(Collection<RegPurchaserEntity> regPurchasersById) {
this.regPurchasersById = regPurchasersById;
private Collection<RegPurchaserTempEntity> regPurchaserTempsById;
public Collection<RegPurchaserTempEntity> getRegPurchaserTempsById() {
return regPurchaserTempsById;
public void setRegPurchaserTempsById(Collection<RegPurchaserTempEntity> regPurchaserTempsById) {
this.regPurchaserTempsById = regPurchaserTempsById;
No, I'm trying to delete another entity - RegPurchaserTempEntity - that is mapped to this entity.
Are there any events registered for the removed entity or processes that might change or affect primary keys? - well, I'm not 100% sure about that, but most likely the answer is no
Re: How to handle "null primary key encountered" exception? [message #538876 is a reply to message #531645] |
Tue, 08 June 2010 16:53   |
That's the log:
NetBeans: Executing '/home/gilberto/bin/maven/bin/mvn -Dtest=VehicleTest -Dnetbeans.execution=true -Ph2,eclipselink test-compile surefire:test'
NetBeans: JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun
Scanning for projects...
Searching repository for plugin with prefix: 'surefire'.
Building Parking Control - Core
task-segment: [test-compile, surefire:test]
[resources:resources]
Using 'UTF-8' encoding to copy filtered resources.
Copying 2 resources
[compiler:compile]
Compiling 13 source files to /home/gilberto/dev/netbeans-config/park-jpa/core/target/classes
[resources:testResources]
Copying 15 resources
[compiler:testCompile]
Compiling 9 source files to /home/gilberto/dev/netbeans-config/park-jpa/core/target/test-classes
[surefire:test]
Surefire report directory: /home/gilberto/dev/netbeans-config/park-jpa/core/target/surefire-reports
T E S T S
Running park.model.VehicleTest
[EL Finest]: 2010-06-08 17:48:37.95--ServerSession(10519800)--Thread(Thread[main,5,main])--Begin predeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Initial; factoryCount 0
[EL Finest]: 2010-06-08 17:48:37.983--ServerSession(10519800)--Thread(Thread[main,5,main])--property=eclipselink.orm.throw.exceptions; default value=true
[EL Finer]: 2010-06-08 17:48:38.03--ServerSession(10519800)--Thread(Thread[main,5,main])--Searching for default mapping file in file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/
[EL Finer]: 2010-06-08 17:48:38.046--ServerSession(10519800)--Thread(Thread[main,5,main])--Found a default mapping file at file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml for root URL file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/
[EL Finer]: 2010-06-08 17:48:39.446--ServerSession(10519800)--Thread(Thread[main,5,main])--Searching for default mapping file in file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/
[EL Config]: 2010-06-08 17:48:39.549--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Parking] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.579--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.PriceTable] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.581--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Stay] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.583--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field employeeEntrance] is being defaulted to: class park.model.Employee.
[EL Config]: 2010-06-08 17:48:39.584--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field employeeOutgoing] is being defaulted to: class park.model.Employee.
[EL Config]: 2010-06-08 17:48:39.585--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field vehicle] is being defaulted to: class park.model.Vehicle.
[EL Config]: 2010-06-08 17:48:39.586--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field parking] is being defaulted to: class park.model.Parking.
[EL Config]: 2010-06-08 17:48:39.594--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Employee] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.596--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field parking] is being defaulted to: class park.model.Parking.
[EL Config]: 2010-06-08 17:48:39.597--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Person] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.598--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.LegalEntity] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.6--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.VehicleType] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.601--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Vehicle] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.603--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field customer] is being defaulted to: class park.model.Customer.
[EL Config]: 2010-06-08 17:48:39.604--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field priceTable] is being defaulted to: class park.model.PriceTable.
[EL Config]: 2010-06-08 17:48:39.605--ServerSession(10519800)--Thread(Thread[main,5,main])--The target entity (reference) class for the many to one mapping element [field vType] is being defaulted to: class park.model.VehicleType.
[EL Config]: 2010-06-08 17:48:39.614--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.NaturalPerson] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.615--ServerSession(10519800)--Thread(Thread[main,5,main])--The access type for the persistent class [class park.model.Customer] is set to [FIELD].
[EL Config]: 2010-06-08 17:48:39.616--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Parking] is being defaulted to: Parking.
[EL Config]: 2010-06-08 17:48:39.618--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.648--ServerSession(10519800)--Thread(Thread[main,5,main])--The column name for element [field address] is being defaulted to: ADDRESS.
[EL Config]: 2010-06-08 17:48:39.651--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.PriceTable] is being defaulted to: PriceTable.
[EL Config]: 2010-06-08 17:48:39.652--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.653--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Stay] is being defaulted to: Stay.
[EL Config]: 2010-06-08 17:48:39.654--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.666--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Employee] is being defaulted to: Employee.
[EL Config]: 2010-06-08 17:48:39.667--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.669--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.LegalEntity] is being defaulted to: LegalEntity.
[EL Config]: 2010-06-08 17:48:39.675--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Person] is being defaulted to: Person.
[EL Config]: 2010-06-08 17:48:39.677--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.69--ServerSession(10519800)--Thread(Thread[main,5,main])--The column name for element [field address] is being defaulted to: ADDRESS.
[EL Config]: 2010-06-08 17:48:39.691--ServerSession(10519800)--Thread(Thread[main,5,main])--The column name for element [field name] is being defaulted to: NAME.
[EL Config]: 2010-06-08 17:48:39.692--ServerSession(10519800)--Thread(Thread[main,5,main])--The column name for element [field version] is being defaulted to: VERSION.
[EL Config]: 2010-06-08 17:48:39.697--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.699--ServerSession(10519800)--Thread(Thread[main,5,main])--The primary key column name for the inheritance class [class park.model.LegalEntity] is being defaulted to: id.
[EL Config]: 2010-06-08 17:48:39.7--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.VehicleType] is being defaulted to: VehicleType.
[EL Config]: 2010-06-08 17:48:39.701--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.703--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Vehicle] is being defaulted to: Vehicle.
[EL Config]: 2010-06-08 17:48:39.705--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.706--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.NaturalPerson] is being defaulted to: NaturalPerson.
[EL Config]: 2010-06-08 17:48:39.707--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Config]: 2010-06-08 17:48:39.708--ServerSession(10519800)--Thread(Thread[main,5,main])--The primary key column name for the inheritance class [class park.model.NaturalPerson] is being defaulted to: id.
[EL Config]: 2010-06-08 17:48:39.71--ServerSession(10519800)--Thread(Thread[main,5,main])--The alias name for the entity class [class park.model.Customer] is being defaulted to: Customer.
[EL Config]: 2010-06-08 17:48:39.711--ServerSession(10519800)--Thread(Thread[main,5,main])--The table schema for entity [file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/META-INF/orm.xml] is being defaulted to: park.
[EL Finest]: 2010-06-08 17:48:39.791--ServerSession(10519800)--Thread(Thread[main,5,main])--End predeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Predeployed; factoryCount 0
[EL Finer]: 2010-06-08 17:48:39.793--Thread(Thread[main,5,main])--JavaSECMPInitializer - transformer is null.
[EL Finest]: 2010-06-08 17:48:39.793--ServerSession(10519800)--Thread(Thread[main,5,main])--Begin predeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Predeployed; factoryCount 0
[EL Finest]: 2010-06-08 17:48:39.794--ServerSession(10519800)--Thread(Thread[main,5,main])--End predeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Predeployed; factoryCount 1
[EL Finest]: 2010-06-08 17:48:39.804--ServerSession(10519800)--Thread(Thread[main,5,main])--Begin deploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Predeployed; factoryCount 1
[EL Finer]: 2010-06-08 17:48:39.844--ServerSession(10519800)--Thread(Thread[main,5,main])--Could not initialize Validation Factory. Encountered following exception: java.lang.NoClassDefFoundError: javax/validation/Validation
[EL Finest]: 2010-06-08 17:48:39.858--ServerSession(10519800)--Thread(Thread[main,5,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[EL Finest]: 2010-06-08 17:48:39.86--ServerSession(10519800)--Thread(Thread[main,5,main])--property=eclipselink.logging.level; value=FINEST; translated value=FINEST
[EL Finest]: 2010-06-08 17:48:39.861--ServerSession(10519800)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.user; value=park
[EL Finest]: 2010-06-08 17:48:39.862--ServerSession(10519800)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.password; value=xxxxxx
[EL Finest]: 2010-06-08 17:48:40.844--ServerSession(10519800)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.driver; value=org.h2.Driver
[EL Finest]: 2010-06-08 17:48:40.846--ServerSession(10519800)--Thread(Thread[main,5,main])--property=javax.persistence.jdbc.url; value=jdbc:h2:../parkDB;create=true;MODE=PostgreSQL;DB_CLOSE_DELAY=-1
[EL Finest]: 2010-06-08 17:48:40.847--ServerSession(10519800)--Thread(Thread[main,5,main])--property=eclipselink.jdbc.read-connections.min; value=1
[EL Finest]: 2010-06-08 17:48:40.848--ServerSession(10519800)--Thread(Thread[main,5,main])--property=eclipselink.jdbc.read-connections.max; value=2
[EL Info]: 2010-06-08 17:48:40.849--ServerSession(10519800)--Thread(Thread[main,5,main])--EclipseLink, version: Eclipse Persistence Services - 2.0.2.v20100323-r6872
[EL Finest]: 2010-06-08 17:48:41.702--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.HSQLPlatform, RegularExpression: (?i)hsql.*.
[EL Finest]: 2010-06-08 17:48:41.705--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.InformixPlatform, RegularExpression: (?i)informix.*.
[EL Finest]: 2010-06-08 17:48:41.706--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.PointBasePlatform, RegularExpression: (?i)pointbase.*.
[EL Finest]: 2010-06-08 17:48:41.707--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.DB2Platform, RegularExpression: (?i).*db2.*.
[EL Finest]: 2010-06-08 17:48:41.707--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.SQLServerPlatform, RegularExpression: (?i)microsoft.*.
[EL Finest]: 2010-06-08 17:48:41.708--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.PostgreSQLPlatform, RegularExpression: (?i)postgresql.*.
[EL Finest]: 2010-06-08 17:48:41.71--Thread(Thread[main,5,main])--DBPlatform: org.eclipse.persistence.platform.database.H2Platform, RegularExpression: (?i)h2.*.
[EL Fine]: 2010-06-08 17:48:41.727--Thread(Thread[main,5,main])--Detected Vendor platform: org.eclipse.persistence.platform.database.H2Platform
[EL Config]: 2010-06-08 17:48:41.77--ServerSession(10519800)--Connection(16658781)--Thread(Thread[main,5,main])--connecting(DatabaseLogin(
platform=>H2Platform
user name=> "park"
datasource URL=> "jdbc:h2:../parkDB;create=true;MODE=PostgreSQL;DB_CLOSE_DELAY=-1"
[EL Config]: 2010-06-08 17:48:41.779--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--Connected: jdbc:h2:../parkDB
User: PARK
Database: H2 Version: 1.2.131 (2010-03-05)
Driver: H2 JDBC Driver Version: 1.2.131 (2010-03-05)
[EL Config]: 2010-06-08 17:48:41.789--ServerSession(10519800)--Connection(2622421)--Thread(Thread[main,5,main])--connecting(DatabaseLogin(
user name=> "park"
[EL Config]: 2010-06-08 17:48:41.794--ServerSession(10519800)--Connection(18061339)--Thread(Thread[main,5,main])--Connected: jdbc:h2:../parkDB
User: PARK
[EL Finest]: 2010-06-08 17:48:41.844--ServerSession(10519800)--Thread(Thread[main,5,main])--sequencing connected, state is Preallocation_Transaction_NoAccessor_State
[EL Finest]: 2010-06-08 17:48:41.849--ServerSession(10519800)--Thread(Thread[main,5,main])--sequence DEFAULT: preallocation size 1
[EL Info]: 2010-06-08 17:48:42.901--ServerSession(10519800)--Thread(Thread[main,5,main])--file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU login successful
[EL Finer]: 2010-06-08 17:48:42.976--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Parking_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:42.977--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Person_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:42.979--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Vehicle_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:42.98--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.VehicleType_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.002--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Stay_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.003--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Customer_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.005--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.Employee_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.006--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.NaturalPerson_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.008--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.PriceTable_] not found during initialization.
[EL Finer]: 2010-06-08 17:48:43.009--ServerSession(10519800)--Thread(Thread[main,5,main])--Canonical Metamodel class [park.model.LegalEntity_] not found during initialization.
[EL Finest]: 2010-06-08 17:48:43.01--ServerSession(10519800)--Thread(Thread[main,5,main])--End deploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Deployed; factoryCount 1
2010-06-08 17:48:43,988 [main] DEBUG park.model.VehicleTest -
Getting an Vehicle by ID.
[EL Finer]: 2010-06-08 17:48:43.992--ServerSession(10519800)--Thread(Thread[main,5,main])--client acquired
[EL Finest]: 2010-06-08 17:48:44.046--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=Vehicle sql="SELECT license_plate, color, v_type, customer_id, price_table_id FROM park.vehicle WHERE (license_plate = ?)")
[EL Fine]: 2010-06-08 17:48:44.051--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT license_plate, color, v_type, customer_id, price_table_id FROM park.vehicle WHERE (license_plate = ?)
bind => [LC100]
[EL Finest]: 2010-06-08 17:48:44.094--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="vType" referenceClass=VehicleType )
[EL Fine]: 2010-06-08 17:48:44.096--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT v_type, manufacturer, model FROM park.vehicle_type WHERE (v_type = ?)
bind => [CAR]
[EL Finest]: 2010-06-08 17:48:44.099--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="customer" referenceClass=Customer )
[EL Fine]: 2010-06-08 17:48:44.11--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT payment_day, person_id FROM park.customer WHERE (person_id = ?)
bind => [1000]
[EL Finest]: 2010-06-08 17:48:44.112--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="person" referenceClass=Person )
[EL Fine]: 2010-06-08 17:48:44.114--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT DISTINCT p_type FROM park.person WHERE (id = ?)
bind => [1000]
[EL Fine]: 2010-06-08 17:48:44.119--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT t0.id, t0.p_type, t0.ADDRESS, t0.NAME, t0.VERSION, t1.person_id, t1.legal_document, t1.dt_birth FROM park.person t0, park.natural_person t1 WHERE ((t0.id = ?) AND ((t1.person_id = t0.id) AND (t0.p_type = ?)))
bind => [1000, NP]
[EL Finest]: 2010-06-08 17:48:44.143--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="priceTable" referenceClass=PriceTable )
[EL Fine]: 2010-06-08 17:48:44.144--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT id, item, price FROM park.price_table WHERE (id = ?)
bind => [100]
[EL Finest]: 2010-06-08 17:48:44.147--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Vehicle[licensePlate=LC100]
[EL Finest]: 2010-06-08 17:48:44.156--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.VehicleType[V_TYPE=CAR]
[EL Finest]: 2010-06-08 17:48:44.16--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Customer[id=1000]
[EL Finest]: 2010-06-08 17:48:44.168--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.PriceTable[id=100]
2010-06-08 17:48:44,171 [main] DEBUG park.model.VehicleTest - Object loaded:
[EL Finest]: 2010-06-08 17:48:44.215--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Execute query ReadAllQuery(name="Vehicle.findAll" referenceClass=Vehicle sql="SELECT license_plate, color, v_type, customer_id, price_table_id FROM park.vehicle")
[EL Fine]: 2010-06-08 17:48:44.216--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT license_plate, color, v_type, customer_id, price_table_id FROM park.vehicle
[EL Finest]: 2010-06-08 17:48:44.218--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Vehicle[licensePlate=LC100]
[EL Finest]: 2010-06-08 17:48:44.299--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="vType" referenceClass=VehicleType )
[EL Fine]: 2010-06-08 17:48:44.3--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT v_type, manufacturer, model FROM park.vehicle_type WHERE (v_type = ?)
bind => [VAN]
[EL Finest]: 2010-06-08 17:48:44.302--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="customer" referenceClass=Customer )
[EL Fine]: 2010-06-08 17:48:44.303--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT payment_day, person_id FROM park.customer WHERE (person_id = ?)
bind => [1001]
[EL Finest]: 2010-06-08 17:48:44.304--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="person" referenceClass=Person )
[EL Fine]: 2010-06-08 17:48:44.307--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT DISTINCT p_type FROM park.person WHERE (id = ?)
bind => [1001]
[EL Fine]: 2010-06-08 17:48:44.309--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT t0.id, t0.p_type, t0.ADDRESS, t0.NAME, t0.VERSION, t1.person_id, t1.legal_document, t1.dt_birth FROM park.person t0, park.natural_person t1 WHERE ((t0.id = ?) AND ((t1.person_id = t0.id) AND (t0.p_type = ?)))
bind => [1001, NP]
[EL Finest]: 2010-06-08 17:48:44.314--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="priceTable" referenceClass=PriceTable )
[EL Fine]: 2010-06-08 17:48:44.315--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--SELECT id, item, price FROM park.price_table WHERE (id = ?)
bind => [101]
[EL Finest]: 2010-06-08 17:48:44.344--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Vehicle[licensePlate=LC101]
[EL Finest]: 2010-06-08 17:48:44.345--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.VehicleType[V_TYPE=VAN]
[EL Finest]: 2010-06-08 17:48:44.346--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Customer[id=1001]
[EL Finest]: 2010-06-08 17:48:44.347--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.PriceTable[id=101]
[EL Finest]: 2010-06-08 17:48:44.348--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="vType" referenceClass=VehicleType )
[EL Finest]: 2010-06-08 17:48:44.349--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="customer" referenceClass=Customer )
[EL Finest]: 2010-06-08 17:48:44.35--ServerSession(10519800)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(name="priceTable" referenceClass=PriceTable )
[EL Finest]: 2010-06-08 17:48:44.351--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Vehicle[licensePlate=LC102]
[EL Finest]: 2010-06-08 17:48:44.353--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.VehicleType[V_TYPE=CAR]
[EL Finest]: 2010-06-08 17:48:44.353--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Customer[id=1000]
[EL Finest]: 2010-06-08 17:48:44.354--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.PriceTable[id=100]
[EL Finest]: 2010-06-08 17:48:44.355--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=PriceTable sql="SELECT id, item, price FROM park.price_table WHERE (id = ?)")
[EL Finest]: 2010-06-08 17:48:44.356--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=VehicleType sql="SELECT v_type, manufacturer, model FROM park.vehicle_type WHERE (v_type = ?)")
[EL Finest]: 2010-06-08 17:48:44.357--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Execute query ReadObjectQuery(referenceClass=Customer sql="SELECT payment_day, person_id FROM park.customer WHERE (person_id = ?)")
[EL Finest]: 2010-06-08 17:48:44.359--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Register the existing object park.model.Customer[id=1000]
2010-06-08 17:48:44,360 [main] DEBUG park.model.VehicleTest - Customer Object loaded:
2010-06-08 17:48:44,360 [main] DEBUG park.model.VehicleTest - Customer's Person Object loaded:
null
[EL Finest]: 2010-06-08 17:48:44.361--UnitOfWork(2409492)--Thread(Thread[main,5,main])--PERSIST operation called on: park.model.Vehicle[licensePlate=LC103].
[EL Finer]: 2010-06-08 17:48:44.362--UnitOfWork(2409492)--Thread(Thread[main,5,main])--begin unit of work commit
[EL Warning]: 2010-06-08 17:48:44.444--UnitOfWork(2409492)--Thread(Thread[main,5,main])--Local Exception Stack:
Exception [EclipseLink-7197] (Eclipse Persistence Services - 2.0.2.v20100323-r6872): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Null primary key encountered in unit of work clone [park.model.Customer[id=1000]].
at org.eclipse.persistence.exceptions.ValidationException.nullPrimaryKeyInUnitOfWorkClone(ValidationException.java:1403)
at org.eclipse.persistence.descriptors.changetracking.DeferredChangeDetectionPolicy.calculateChanges(DeferredChangeDetectionPolicy.java:106)
at org.eclipse.persistence.descriptors.changetracking.DeferredChangeDetectionPolicy.calculateChangesForExistingObject(DeferredChangeDetectionPolicy.java:54)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.calculateChanges(UnitOfWorkImpl.java:632)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1503)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:200)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1139)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:63)
at park.model.VehicleTest.findAll(VehicleTest.java:123)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:73)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:46)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:180)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:41)
at org.junit.runners.ParentRunner$1.evaluate(ParentRunner.java:173)
at org.junit.runners.ParentRunner.run(ParentRunner.java:220)
at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet.java:62)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:140)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:127)
at org.apache.maven.surefire.Surefire.run(Surefire.java:177)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
[EL Finer]: 2010-06-08 17:48:44.452--UnitOfWork(2409492)--Thread(Thread[main,5,main])--release unit of work
[EL Finer]: 2010-06-08 17:48:44.453--ClientSession(14365489)--Thread(Thread[main,5,main])--client released
[EL Finest]: 2010-06-08 17:48:44.474--ServerSession(10519800)--Thread(Thread[main,5,main])--Begin undeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Deployed; factoryCount 1
[EL Finest]: 2010-06-08 17:48:44.474--ServerSession(10519800)--Thread(Thread[main,5,main])--sequencing disconnected
[EL Config]: 2010-06-08 17:48:44.475--ServerSession(10519800)--Connection(20054554)--Thread(Thread[main,5,main])--disconnect
[EL Finer]: 2010-06-08 17:48:44.476--ServerSession(10519800)--Thread(Thread[main,5,main])--initialize identitymaps
[EL Info]: 2010-06-08 17:48:44.477--ServerSession(10519800)--Thread(Thread[main,5,main])--file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU logout successful
[EL Config]: 2010-06-08 17:48:44.49--ServerSession(10519800)--Connection(16658781)--Thread(Thread[main,5,main])--disconnect
[EL Config]: 2010-06-08 17:48:44.491--ServerSession(10519800)--Connection(18061339)--Thread(Thread[main,5,main])--disconnect
[EL Finest]: 2010-06-08 17:48:44.491--ServerSession(10519800)--Thread(Thread[main,5,main])--End undeploying Persistence Unit parkPU; session file:/home/gilberto/dev/netbeans-config/park-jpa/core/target/classes/_parkPU; state Undeployed; factoryCount 0
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.332 sec <<< FAILURE!
Results :
Tests in error:
findAll(park.model.VehicleTest)
[ERROR]BUILD FAILURE
There are test failures.
Please refer to /home/gilberto/dev/netbeans-config/park-jpa/core/target/surefire-reports for the individual test results.
For more information, run Maven with the -e switch
Total time: 18 seconds
Finished at: Tue Jun 08 17:48:45 GMT-03:00 2010
Final Memory: 11M/78M
And the call for relationship:
VehicleType vT = em.find(VehicleType.class, "CAR");
Customer c = em.find(Customer.class, 1000L);
log.debug("Customer Object loaded: \n" + c);
log.debug("Customer's Person Object loaded: \n" + c.getPerson());
//set relationships
v.setCustomer(c);
Other thing, would mind to take a look at this discussion and see why I'm not getting that exception with eclipselink?
Gilberto
[Updated on: Wed, 09 June 2010 15:12] by Moderator
Re: How to handle "null primary key encountered" exception? [message #539171 is a reply to message #538876] |
Wed, 09 June 2010 16:16   |
It looks like it is querying the Person table successfully and finding a row with a type of NP indicating they are NatualPerson entities. Looking at the vehicle-dataset though, I don't see entries for a natural_person table - it looks like the vehicle-dataset is incomplete and is why the relationship is null: the query
"SELECT t0.id, t0.p_type, t0.ADDRESS, t0.NAME, t0.VERSION, t1.person_id, t1.legal_document, t1.dt_birth FROM park.person t0, park.natural_person t1 WHERE ((t0.id = ?) AND ((t1.person_id = t0.id) AND (t0.p_type = ?)))"
returns null.
Best Regards,
Chris
Current Time: Mon Sep 22 01:51:41 EDT 2025
Powered by FUDForum. Page generated in 0.05989 seconds
