Home » Modeling » OCL » EMF Plugin(OCL setting extend map)
EMF Plugin [message #531622] |
Wed, 05 May 2010 15:43 |
Esin Karabacakoglu Messages: 11 Registered: May 2010 Location: Turkey |
Hi there,
I am beginner at OCL on EMF. I am trying to test my OCL constraints. I have a trouble with the code below. I used "allInstances()" function in OCL constraint. I succeeded to run it by creating an extent map. But in the code below, I am using two "allInstances()" functions in my OCL code. For this reason, i think, i need to add two mapping to my ocl environment. But, it doesn't work when I put two entries into the ocl extend map.
Do you have any idea?
Here is my code:
org.eclipse.ocl.expressions.OCLExpression query = helper
.createQuery("RefinementNode.allInstances()->exists(rn|rn.refinementGoals->includes(self)) or Role.allInstances()->exists(ro|ro.goals->includes(self))");
// sets the perform goal as a role goal...
role.getGoals().add(performGoal);
// create an extent map
Map extents = new HashMap();
Set environmentSet = new HashSet();
environmentSet.add(role);
extents.put(role.eClass(), environmentSet);
environmentSet.add(refinementNode);
extents.put(refinementNode.eClass(), environmentSet);
ocl.setExtentMap(extents);
// use the query expression parsed before to create a Query
eval = ocl.createQuery(query);
result = eval.check(performGoal);
// Assert the constraint...
assertTrue(result);
[Updated on: Wed, 05 May 2010 15:44] Report message to a moderator
Re: EMF Plugin [message #531654 is a reply to message #531622] |
Wed, 05 May 2010 17:22 |
Originally posted by: philipp.berger.student.hpi.uni-potsdam.de
I assume that you have to that the context for the OCL to bind it to the
Role class.
Phil
Am 05.05.2010 17:44, schrieb esin:
> Hi there, I am beginner at OCL on EMF. I am trying to test my OCL
> Here is my code:
> .createQuery("RefinementNode.allInstances()->exists(rn|rn.refinementGoals- >includes(self))
> assertTrue(result);
> Any help will be appreciated.
Re: EMF Plugin [message #531838 is a reply to message #531812] |
Thu, 06 May 2010 10:51 |
Hi everybody,
Thanks for your replies. After asking my previous question, I realized that, my problem is about the "adding mappings into the ocl's extent map containing the environment( through setExtentMap() function)". For that reason, the evaluator gives an unexpected result. I expect the "eval.check(performGoal)" function's result as TRUE, however it gives as a result FALSE. Fortunatelly, i noticed that, if I use OR (which is the subclass of the RefinementNode) instead of using RefinementNode ( which is abstract class) in the OCL constraint, the check function's result comes TRUE.
Now my new question is how can I map these whole environment items in an easiest way?
Here is my working code:
public void danglingPerformGoalConstraintTest() throws Exception {
// Creates an organization diagram that contains dangling perform
// goal...
// creates Perform Goal instance...
PerformGoal performGoal = OrganizationFactory.eINSTANCE
.createPerformGoal();
// creates an Organization diagram instance...
Organization organization = OrganizationFactory.eINSTANCE
.createOrganization();
// creates a Role instance...
Role role = OrganizationFactory.eINSTANCE.createRole();
// crates a Refinement node instance...
OR refinementNode = OrganizationFactory.eINSTANCE.createOR();
// add elements..
organization.getRoles().add(role);
organization.getGoals().add(performGoal);
organization.getRefinementNodes().add(refinementNode);
refinementNode.getRefinementGoals().add(performGoal);
// mapping...
Set environmentSet2 = new HashSet();
environmentSet2.add(refinementNode);
extents.put(refinementNode.eClass(), environmentSet2);
// create an OCL instance for Ecore
OCL ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
// create an OCL helper object
OCLHelper helper = ocl.createOCLHelper();
// set the OCL context classifier
helper.setContext(OrganizationPackage.eINSTANCE.getPerformGoal());
.createQuery("(OR.allInstances()->exists(rn|rn.refinementGoals->includes(self))) or (Role.allInstances()->exists(ro|ro.goals->includes(self)))");
org.eclipse.ocl.Query eval = ocl.createQuery(query);
boolean result = eval.check(performGoal);
assertTrue(result);
And my new question's part is below, mapping it in an easier way:
// mapping...
Re: EMF Plugin [message #532012 is a reply to message #531838] |
Thu, 06 May 2010 18:23 |
Ed Willink Messages: 7670 Registered: July 2009 |
Hi esin
It is far from clear what needs to be made easier.
Your hard code is only 7 line including one-off initialisation and
one-line per addition.
A helper function for the initialisation will just trade lines.
A helper function for the addition will be mode that one line.
At a complete guess, you might choose to an Extents class that
encapsulates your interactions.
Ed Willink
On 06/05/2010 11:51, esin wrote:
> Hi everybody,
> comes TRUE.
> easiest way?
> // goal...
> // add elements..
> // mapping...
> OCL ocl;
> helper.setContext(OrganizationPackage.eINSTANCE.getPerformGo al());
> .createQuery("(OR.allInstances()->exists(rn|rn.refinementGoals- >includes(self)))
> or (Role.allInstances()->exists(ro|ro.goals->includes(self))) ");
> assertTrue(result);
> // mapping...
Current Time: Thu Sep 26 02:54:37 GMT 2024
Powered by FUDForum. Page generated in 0.04145 seconds
