The project: xxxxx which is referenced by the classpath, does not exist [message #531324] |
Tue, 04 May 2010 10:36  |
Several java apps that run fine in Release Release 3.5.0 and earlier will not run with Release Release 3.5.2. The error message I get in the log file is:
!MESSAGE The project: xxxxxx which is referenced by the classpath, does not exist.
I have tried creating new projects from scratch with the same result. I am running in Windows Vista.
Any suggestions?
Re: The project: xxxxx which is referenced by the classpath, does not exist [message #1068244 is a reply to message #1032849] |
Fri, 12 July 2013 15:35   |
Hi Terry,
the second part of your postQuote:I cannot name my projects with the same name as the windows workspace folder solved my problem:
'Run launch configuration', and then get 'The project: xxxxx which is referenced by the classpath, does not exist.' using 'Eclipse SDK, Version: 3.7.1, Build id: M20110909-1335'.
Closed Eclipse, renamed workspace folder, reopened Eclipse, and then 'Run launch configuration' succeeded.
Thank you for your post.
kind regards Franz-Josef
FUDForum. Page generated in 0.06895 seconds
