Home » Eclipse Projects » Rich Client Platform (RCP) » Zombie EditorInputs
Zombie EditorInputs [message #531167] Mon, 03 May 2010 21:35 Go to next message
While investigating a memory use issue in an RCP application, I noticed that the EditorInputs of closed editors were not being garbage-collected, thanks to a reference from an instance of org.eclipse.ui.internal.EditorHistory. How do I disable this "feature"?
Re: Zombie EditorInputs [message #531282 is a reply to message #531167] Tue, 04 May 2010 08:29 Go to previous messageGo to next message
You cannot (at least there's no API to do it, you'd have to go digging
through the internals).
IEditorInputs should be lightweight objects. From the javadoc: "
<code>IEditorInput</code> is a light weight descriptor of editor input,
like a file name but more abstract. It is not a model. It is a
description of the model source for an <code>IEditorPart</code>."
There's another note in there as well, but basically think java.io.File
(it's little more than a string path). If you put your model in there,
it will be held for all time and that's contra-indicated by the javadoc
for IEditorInput.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Zombie EditorInputs [message #531283 is a reply to message #531167] Tue, 04 May 2010 08:31 Go to previous messageGo to next message
Just as an aside, if your IEditorInput returns
org.eclipse.ui.IEditorInput.getPersistable() null it will not be added
to the history, and when your session restarts those editors will not be
re-materialized.
The framework still requires no model held in the IEditorInput.
PW
Paul Webster
Re: Zombie EditorInputs [message #531408 is a reply to message #531283] Tue, 04 May 2010 14:50 Go to previous messageGo to next message
Paul Webster wrote on Tue, 04 May 2010 08:31
Just as an aside, if your IEditorInput returns org.eclipse.ui.IEditorInput.getPersistable() null it will not be added to the history, and when your session restarts those editors will not be re-materialized.
The IEditorInput appears to be referenced from the EditorHistory despite returning null for getPersistable().
Thanks for pointing this out!
Re: Zombie EditorInputs [message #531413 is a reply to message #531408] Tue, 04 May 2010 15:05 Go to previous messageGo to next message
>> be re-materialized.
maybe exists() should return false as well ... that might remove it from
the editor history on a refresh.
PW
Paul Webster
Re: Zombie EditorInputs [message #531437 is a reply to message #531413] Tue, 04 May 2010 17:16 Go to previous message
Paul Webster wrote on Tue, 04 May 2010 15:05
Doesn't seem to help: Looks like refresh() is only called from getItems(), which in turn is only called from ReopenEditorMenu, but this contribution is not part of the RCP application...
Previous Topic:Java Webstart on Mac OSX
Next Topic:How to retrieve Windows Cursor Style using SWT
Current Time: Mon Sep 22 21:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.04667 seconds
