Problem running example [message #530598] |
Fri, 30 April 2010 09:49 |
No real name Messages: 4 Registered: April 2010 |
The project i'm working of is a project that allows to transform an Uml project in a file RTF.
This is the output:
org.eclipse.m2m.atl.engine.emfvm.VMException: Could not find model element Association from UML
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM. java:232)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:176)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:162)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.launch (EMFVMLauncher.java:135)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(Laun cherService.java:135)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDel egate.launch(AtlLaunchConfigurationDelegate.java:222)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: org.eclipse.m2m.atl.engine.emfvm.ASM$SignatureParsingExcepti on: Could not find model element Association from UML
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseTypeInternal(ASM.j ava:408)
at org.eclipse.m2m.atl.engine.emfvm.ASM.parseType(ASM.java:368)
at org.eclipse.m2m.atl.engine.emfvm.ASM.registerOperations(ASM. java:229)
... 10 more
[Updated on: Fri, 30 April 2010 09:50] Report message to a moderator
FUDForum. Page generated in 0.03709 seconds
