Home » Archived » Java WorkFlow Tooling (JWT) » Run a modified version of JWT
Re: Run a modified version of JWT [message #530467 is a reply to message #529894] |
Thu, 29 April 2010 17:15 |
Marc Dutoo Messages: 71 Registered: July 2009 |
Member |
Hi Tikael
Please confirm that you did
* use a JDK 5+
* use a fresh Eclipse 3.5 (Galileo) install, WITHOUT the JWT plugins
installed from the Galileo update site (since you'll install them from
source+build)
* check out the source code as said (using the CVS perspective), and
import all projects (at least we/jwt-we and the projects it depends on,
like all 3 metamodel/* ; we/jwt-we-conf-* are highly recommended, as
well as transformations/jwt-transformation-*) as Plugin projects in your
workspace. Now they should be displayed in your Projects view in red (in
error)
* install the dependencies (Plugins : EMF, GEF, Zest ; Orbit :
JDom), otherwise the checkouted plugin projects will stay in red in your
Eclipse projects view
* right-click on jwt-we > Run As > Eclipse Application . By default
all plugins of your workspace are used, they can be tweaked in the Run menu.
Following your question, I've improved the "how to build" section on the
http://wiki.eclipse.org/JWT_CVS , have a look at it.
My most important question : does your workspace look like the one I've
just uploaded on the http://wiki.eclipse.org/JWT_CVS page ?
Marc
Mike Swap a écrit :
> For a project I have, I would like to modify the plug-in JWT by deleting
> (or hiding) the buttons, areas and menus that I don't need and adding
> the one I want.
> I followed this tutorial (http://wiki.eclipse.org/JWT_CVS) so I
> downloaded the source code using CVS thus as the depedencies but now,
> when I try to run my application ( I didn't modify the source code of
> the plug-in yet), I can't use the JWT plug-in (and I don't see it
> amongst the installed plug-ins, thus as EMF, GEF and Zest).
> Am I doing something wrong?
> Thanks in advance,
> Michaël.
[Updated on: Fri, 02 July 2010 15:34] Report message to a moderator
Re: Run a modified version of JWT [message #532018 is a reply to message #530467] |
Thu, 06 May 2010 18:46 |
Member |
Hi Tikael
Any news on your side ?
By the way, I've just improved the development environment page at
http://wiki.eclipse.org/JWT_CVS , by adding the missing xalan dependency.
Marc
Marc Dutoo a écrit :
> Hi Tikael
> * use a JDK 5+
> source+build)
> error)
> * install the dependencies (Plugins : EMF, GEF, Zest ; Orbit : JDom),
> menu.
> Regards,
> Marc
> Mike Swap a écrit :
>> Hi,
>> deleting (or hiding) the buttons, areas and menus that I don't need
>> and adding the one I want.
>> Thanks in advance,
>> Michaël.
Current Time: Thu Sep 19 21:05:33 GMT 2024
Powered by FUDForum. Page generated in 0.04123 seconds
