Home » Eclipse Projects » Plugin Development Environment (PDE) » integrate jni library(UnsatisfiedLinkError on jni method call)
integrate jni library [message #529583] Mon, 26 April 2010 09:37 Go to next message
Hi, I defined external jar with jni library as separate plugin A, as described in the following links:
http://www.vogella.de/articles/EclipseJarToPlugin/article.ht ml
http://www.eclipsezone.com/eclipse/forums/t49342.html
I have a plugin B, dependent on plugin A. In invocation of the cdm.buildRtlModel method it calls to jni method and fails with UnsatisfiedLinkError exception.
public class RTL {
    static {
        try {
            System.loadLibrary("cdmjava");
            System.out.println("-I- Success to load native cdmjava library");
        } catch (Exception e) {
            e.printStackTrace();
public static void buildDesign() {
		String rtl = new String("/home/somedir");
		cdmOccTop occTop = cdm.buildRtlModel("somename", rtl);
The observations are:
  1. It has the jni library in java.library.path, I printed it with System.getProperty("java.library.path")
  2. It succeeded to load the library and print the next statement -I- Success to load native cmdjava library
  3. It fails on the method cdm.buildRtlModel on call to jni method.
  4. This method is defined in the jni library
What is wrong?
Any clue will be appreciated.
Re: integrate jni library [message #531384 is a reply to message #529583] Tue, 04 May 2010 13:01 Go to previous message
I reduce the problem: the jni method is invocated when I run main as java application and fails when I run it within plugin.
External plugin has one native and one regular method. Regular method always succeed. Native library is also succeed to load - I get "-I- Success to load". The interface of native library is ok - I checked with javah.
package bbb;
public class aaa {
  public final static native long someMethod(String jarg1);
  public static void otherMethod() {
        System.out.println("Jar containing bbb.aaa.otherMethod() is loaded ok");
The class calling them:
public class RTL {
   static {
            System.loadLibrary("kuku");
            System.out.println("-I- Success to load native library");
     aaa.otherMethod(); // call regular method - ok
     aaa.someMethod(); // call native method - fails
public static void main(String argv[]) {
     aaa.someMethod(); // call native method - ok!!!
Any ideas will be appreciated!
Previous Topic:Re: Unsatisfied Version Constraint Error
Next Topic:integrate jni library
Current Time: Fri Nov 07 01:36:28 EST 2025
Powered by FUDForum. Page generated in 0.02914 seconds
