Home » Modeling » M2T (model-to-text transformation) » [Acceleo] AllInstances problem with 3.0M6
[Acceleo] AllInstances problem with 3.0M6 [message #528882] Thu, 22 April 2010 05:39 Go to next message
Hi i try to use Acceleo and i want to do a "for" over a collection of
elements derived from an allInstances instruction
I use a metamodel importing another metamodel where eclasses have the
same name (i know not very clean)
this is my code and allInstances seems to return nothing. I'm working on
Eclipse galileo
[module
generate('http://org.topcased.traceability.model/1.0','http://org.topcased.requirement/1.0')/]
[template public generate(r : requirement::RequirementProject)]
[comment @main /]
[file (r.identifier, false, 'Cp1252')]
[r.identifier /]
[for (r : requirement::Requirement |
requirement::Requirement.allInstances())]
try
[/for]
[for (r : ttm::Requirement | ttm::Requirement.allInstances())]
other try
[/for]
[/file]
[/template]
my output only display the identifier of my project. Did you notice some
problems with allInstances() instruction ?
Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #528888 is a reply to message #528882] Thu, 22 April 2010 06:04 Go to previous messageGo to next message
--------------020902010609090804040609
Content-Type: text/plain; charset=UTF-8; format=flowed
Tristan,
I'll admit I don't use allInstances() that much (I believe I never used
it :p).
The problem might come from the classifiers having identical names, it
could be an issue with the OCL "allInstances" operation, it could be
because of the "allInstances"'s scope, ... I can't say for sure as your
template seems good to me.
What would be the result of replacing allInstances by a typed
"eAllContents" such as in :
r.eAllContents(requirement::Requirement))]
try
[/for]
[for (r : ttm::Requirement | r.eAllContents(ttm::Requirement))]
other try
[/for]
Take not that the scope of my eAllContents' are your "r" variable of
type RequirementProject ... which might not be your model root. You
might need to go up to the root through "ancestors()->last()" or a
couple of "eContainer()" calls.
Laurent Goubet
Obeo
> Eclipse galileo
> [module
> [comment @main /]
> [r.identifier /]
> try
> [/for]
> other try
> [/for]
> [/file]
> [/template]
> Tristan
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020902010609090804040609--
Re: [Acceleo] AllInstances problem with 3.0M6 [message #528892 is a reply to message #528888] Thu, 22 April 2010 06:12 Go to previous messageGo to next message
Hi !
no it doesn't work this is my full template (please note that
requirement project is the root of my model :) )
[module
[comment @main /]
[r.identifier /]
[for (a : requirement::Requirement |
try
[/for]
[for (a : ttm::Requirement | r.eAllContents(ttm::Requirement))]
other try
[/for]
[/file]
[/template]
Tristan
Le 22/04/2010 12:04, Laurent Goubet a écrit :
> Tristan,
> used it :p).
> your template seems good to me.
> try
> [/for]
> other try
> [/for]
> Laurent Goubet
> Obeo
>> on Eclipse galileo
>> [module
>> [comment @main /]
>> [r.identifier /]
>> try
>> [/for]
>> other try
>> [/for]
>> [/file]
>> [/template]
>> some problems with allInstances() instruction ?
>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #528927 is a reply to message #528892] Thu, 22 April 2010 08:08 Go to previous messageGo to next message
--------------070002060601040701060708
Tristan,
I don't know why you don't get any "try" or "other try" in the resulting
file ... You do have Requirements in the model right? :p.
Having nothing with the typed eAllContents() rules out a problem with
allInstances() ... If you remove any mention of the two "Requirement"
classifiers and use the raw name instead such as in :
[for (r.eAllContents()->select(eClass().name == 'Requirement'))]
[self/]
[/for]
Do you get the expected classes printed out in the result file?
Laurent Goubet
Obeo
> Hi !
> [module
> [comment @main /]
> [r.identifier /]
> try
> [/for]
> other try
> [/for]
> [/file]
> [/template]
> Regards
> Tristan
>> Tristan,
>> used it :p).
>> try
>> [/for]
>> other try
>> [/for]
>> Laurent Goubet
>> Obeo
>>> on Eclipse galileo
>>> [module
>>> [comment @main /]
>>> [r.identifier /]
>>> try
>>> [/for]
>>> other try
>>> [/for]
>>> [/file]
>>> [/template]
>>> Tristan
--------------070002060601040701060708--
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529126 is a reply to message #528927] Fri, 23 April 2010 02:33 Go to previous messageGo to next message
Sorry try and other try it's just to create some traces :)
I will "try" your solution
Tristan
Le 22/04/2010 14:08, Laurent Goubet a écrit :
> Tristan,
> resulting file ... You do have Requirements in the model right? :p.
> [self/]
> [/for]
> Laurent Goubet
> Obeo
>> Hi !
>> [module
>> [comment @main /]
>> [r.identifier /]
>> try
>> [/for]
>> other try
>> [/for]
>> [/file]
>> [/template]
>> Regards
>> Tristan
>>> Tristan,
>>> used it :p).
>>> it could be an issue with the OCL "allInstances" operation, it could
>>> be because of the "allInstances"'s scope, ... I can't say for sure
>>> as your template seems good to me.
>>> try
>>> [/for]
>>> other try
>>> [/for]
>>> Laurent Goubet
>>> Obeo
>>>> of elements derived from an allInstances instruction
>>>> the same name (i know not very clean)
>>>> working on Eclipse galileo
>>>> [module
>>>> [comment @main /]
>>>> [r.identifier /]
>>>> try
>>>> [/for]
>>>> other try
>>>> [/for]
>>>> [/file]
>>>> [/template]
>>>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529127 is a reply to message #529126] Fri, 23 April 2010 02:34 Go to previous messageGo to next message
Oops it seems i did'nt understand what you meant :/ of course i have
requirements in my model !
Tristan
> Tristan
>> Tristan,
>> [self/]
>> [/for]
>> Laurent Goubet
>> Obeo
>>> Hi !
>>> [module
>>> [comment @main /]
>>> [r.identifier /]
>>> try
>>> [/for]
>>> other try
>>> [/for]
>>> [/file]
>>> [/template]
>>> Regards
>>> Tristan
>>>> Tristan,
>>>> used it :p).
>>>> could be because of the "allInstances"'s scope, ... I can't say for
>>>> sure as your template seems good to me.
>>>> try
>>>> [/for]
>>>> other try
>>>> [/for]
>>>> of type RequirementProject ... which might not be your model root.
>>>> You might need to go up to the root through "ancestors()->last()"
>>>> or a couple of "eContainer()" calls.
>>>> Laurent Goubet
>>>> Obeo
>>>>> [module
>>>>> [comment @main /]
>>>>> [r.identifier /]
>>>>> try
>>>>> [/for]
>>>>> other try
>>>>> [/for]
>>>>> [/file]
>>>>> [/template]
>>>>> notice some problems with allInstances() instruction ?
>>>>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529128 is a reply to message #529127] Fri, 23 April 2010 02:48 Go to previous messageGo to next message
I have checked your solution no result :(
i've added an output of the eallContents to check what is contained and
my requirements are displyed (to String) !! So strange ... Maybe i have
some problems with my OCL on my environment (galileo). Shoul i try on
Helios ?
[r.identifier /]
[r.eAllContents() /]
[for (r.eAllContents()->select(eClass().name = 'Requirement')) ]
[self /]
[/for]
[/file]
> Tristan
>> Tristan
>>> Tristan,
>>> with allInstances() ... If you remove any mention of the two
>>> "Requirement" classifiers and use the raw name instead such as in :
>>> [self/]
>>> [/for]
>>> Laurent Goubet
>>> Obeo
>>>> Hi !
>>>> [module
>>>> [comment @main /]
>>>> [r.identifier /]
>>>> try
>>>> [/for]
>>>> other try
>>>> [/for]
>>>> [/file]
>>>> [/template]
>>>> Regards
>>>> Tristan
>>>>> Tristan,
>>>>> used it :p).
>>>>> names, it could be an issue with the OCL "allInstances" operation,
>>>>> it could be because of the "allInstances"'s scope, ... I can't say
>>>>> for sure as your template seems good to me.
>>>>> try
>>>>> [/for]
>>>>> other try
>>>>> [/for]
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> collection of elements derived from an allInstances instruction
>>>>>> [module
>>>>>> [comment @main /]
>>>>>> [r.identifier /]
>>>>>> try
>>>>>> [/for]
>>>>>> other try
>>>>>> [/for]
>>>>>> [/file]
>>>>>> [/template]
>>>>>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529138 is a reply to message #529128] Fri, 23 April 2010 03:48 Go to previous messageGo to next message
--------------030009080909030300080908
Hi Tristan,
Humm ... You have "Requirement" instances returned by "eAllContents" but
a static check on "eClass().name = 'Requirement'" doesn't return
anything ???
Can you confirm that the eClass name is indeed "Requirement" (or
whatever you put in the "select" operation)?
Other than that, if "r.eAllContents()" returns a list that indeed
contains the elements you wish to iterate on, you will need to try a
step by step to see where the "select" condition fails.
For example, you could use the following :
[r.identifier /]
[r.eAllContents() /] // Unfiltered contents
[r.eAllContents().eClass()->asSet().name /] // Names of the contents'
eClasses, without duplicates
[r.eAllContents().eClass()->asSet()->collect(ePackage.name.concat('::').concat(name))
/] // Qualified names of these eClasses
[r.eAllContents().eClass()->asSet().name->includes('Requirement') /] //
Is there an eClass named 'Requirement' in this set?
[/file]
To try and determine what goes wrong, and where it does.
Laurent Goubet
Obeo
> Helios ?
> [r.identifier /]
> [self /]
> [/for]
> [/file]
>> Tristan
>>> Tristan
>>>> Tristan,
>>>> [self/]
>>>> [/for]
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi !
>>>>> [module
>>>>> [comment @main /]
>>>>> [r.identifier /]
>>>>> try
>>>>> [/for]
>>>>> other try
>>>>> [/for]
>>>>> [/file]
>>>>> [/template]
>>>>> Regards
>>>>> Tristan
>>>>>> Tristan,
>>>>>> used it :p).
>>>>>> try
>>>>>> [/for]
>>>>>> other try
>>>>>> [/for]
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>>> [module
>>>>>>> [comment @main /]
>>>>>>> [r.identifier /]
>>>>>>> try
>>>>>>> [/for]
>>>>>>> other try
>>>>>>> [/for]
>>>>>>> [/file]
>>>>>>> [/template]
>>>>>>> Tristan
--------------030009080909030300080908--
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529163 is a reply to message #529138] Fri, 23 April 2010 05:04 Go to previous messageGo to next message
I understand anything ...
in all your cases it works I list the eclasses Requirement
in this case :
[for (e : ecore::EObject | r.eAllContents()->select(e |
e.oclAsType(ecore::EObject).eClass().name = 'Requirement')) ]
[e.eClass().ePackage.name.concat('::').concat(e.eClass().nam e) /]
[/for]
it works too. I see the qualified name
but the next case ... no result
[for (e : requirement::Requirement | r.eAllContents()->select(e |
[e.identifier /]
[/for]
but allInstances or previous cases don't work ...
Le 23/04/2010 09:48, Laurent Goubet a écrit :
> Hi Tristan,
> but a static check on "eClass().name = 'Requirement'" doesn't return
> anything ???
> [r.identifier /]
> contents' eClasses, without duplicates
> /] // Is there an eClass named 'Requirement' in this set?
> [/file]
> Laurent Goubet
> Obeo
>> and my requirements are displyed (to String) !! So strange ... Maybe
>> i have some problems with my OCL on my environment (galileo). Shoul i
>> try on Helios ?
>> [r.identifier /]
>> [self /]
>> [/for]
>> [/file]
>>> Tristan
>>>> Tristan
>>>>> Tristan,
>>>>> [self/]
>>>>> [/for]
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Hi !
>>>>>> [module
>>>>>> [comment @main /]
>>>>>> [r.identifier /]
>>>>>> try
>>>>>> [/for]
>>>>>> other try
>>>>>> [/for]
>>>>>> [/file]
>>>>>> [/template]
>>>>>> Regards
>>>>>> Tristan
>>>>>>> Tristan,
>>>>>>> never used it :p).
>>>>>>> operation, it could be because of the "allInstances"'s scope,
>>>>>>> ... I can't say for sure as your template seems good to me.
>>>>>>> try
>>>>>>> [/for]
>>>>>>> other try
>>>>>>> [/for]
>>>>>>> variable of type RequirementProject ... which might not be your
>>>>>>> model root. You might need to go up to the root through
>>>>>>> "ancestors()->last()" or a couple of "eContainer()" calls.
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> have the same name (i know not very clean)
>>>>>>>> [module
>>>>>>>> [comment @main /]
>>>>>>>> [r.identifier /]
>>>>>>>> try
>>>>>>>> [/for]
>>>>>>>> other try
>>>>>>>> [/for]
>>>>>>>> [/file]
>>>>>>>> [/template]
>>>>>>>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529167 is a reply to message #529163] Fri, 23 April 2010 05:16 Go to previous messageGo to next message
--------------030704060802000609050908
Tristan,
Do you get anything in the error log or console when trying to evaluate
the expression that fails (your second case in the previous mail)? And
when you say "no result" : do you get absolutely nothing (empty String)
or "invalid" dynamic EObjects (OCL's invalid result)?
I can only think of a ClassCastException happening under the hood and
pruning your results ... but that would mean you'd get something looged
in the error log.
Laurent Goubet
Obeo
> in this case :
> [/for]
> [e.identifier /]
> [/for]
>> Hi Tristan,
>> anything ???
>> [r.identifier /]
>> [/file]
>> Laurent Goubet
>> Obeo
>>> try on Helios ?
>>> [r.identifier /]
>>> [self /]
>>> [/for]
>>> [/file]
>>>> Tristan
>>>>> Tristan
>>>>>> Tristan,
>>>>>> [self/]
>>>>>> [/for]
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>>> Hi !
>>>>>>> [module
>>>>>>> [comment @main /]
>>>>>>> [r.identifier /]
>>>>>>> try
>>>>>>> [/for]
>>>>>>> other try
>>>>>>> [/for]
>>>>>>> [/file]
>>>>>>> [/template]
>>>>>>> Regards
>>>>>>> Tristan
>>>>>>>> Tristan,
>>>>>>>> never used it :p).
>>>>>>>> try
>>>>>>>> [/for]
>>>>>>>> other try
>>>>>>>> [/for]
>>>>>>>> Laurent Goubet
>>>>>>>> Obeo
>>>>>>>>> [module
>>>>>>>>> [comment @main /]
>>>>>>>>> [r.identifier /]
>>>>>>>>> try
>>>>>>>>> [/for]
>>>>>>>>> other try
>>>>>>>>> [/for]
>>>>>>>>> [/file]
>>>>>>>>> [/template]
>>>>>>>>> Tristan
--------------030704060802000609050908--
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529176 is a reply to message #529167] Fri, 23 April 2010 05:44 Go to previous messageGo to next message
I had a log because I have two type of requirements
ttm::Requirement
requirement::Requirement and my iterator had some cast problems
but in this loop :
e.oclIsTypeOf(requirement::Requirement))) ]
[e.identifier /]
[/for]
no log, no entry in my result file :(
anyway this case works . It is a workaround for me but I think there is
a problem in Acceleo
[for (e : ttm::Requirement | r.eAllContents()->select(e |
e.oclAsType(ecore::EObject).eClass().name = 'Requirement' and
e.oclAsType(ecore::EObject).eClass().ePackage.name = 'ttm')) ]
[e.ident /]
[/for]
Le 23/04/2010 11:16, Laurent Goubet a écrit :
> Tristan,
> evaluate the expression that fails (your second case in the previous
> mail)? And when you say "no result" : do you get absolutely nothing
> (empty String) or "invalid" dynamic EObjects (OCL's invalid result)?
> looged in the error log.
> Laurent Goubet
> Obeo
>> in this case :
>> [/for]
>> [e.identifier /]
>> [/for]
>>> Hi Tristan,
>>> anything ???
>>> [r.identifier /]
>>> [/file]
>>> Laurent Goubet
>>> Obeo
>>>> Maybe i have some problems with my OCL on my environment (galileo).
>>>> Shoul i try on Helios ?
>>>> [r.identifier /]
>>>> 'Requirement')) ]
>>>> [self /]
>>>> [/for]
>>>> [/file]
>>>>> have requirements in my model !
>>>>> Tristan
>>>>>> Tristan
>>>>>>> Tristan,
>>>>>>> [self/]
>>>>>>> [/for]
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>>> Hi !
>>>>>>>> [module
>>>>>>>> [comment @main /]
>>>>>>>> [r.identifier /]
>>>>>>>> try
>>>>>>>> [/for]
>>>>>>>> other try
>>>>>>>> [/for]
>>>>>>>> [/file]
>>>>>>>> [/template]
>>>>>>>> Regards
>>>>>>>> Tristan
>>>>>>>>> Tristan,
>>>>>>>>> never used it :p).
>>>>>>>>> try
>>>>>>>>> [/for]
>>>>>>>>> other try
>>>>>>>>> [/for]
>>>>>>>>> your model root. You might need to go up to the root through
>>>>>>>>> Laurent Goubet
>>>>>>>>> Obeo
>>>>>>>>>> [module
>>>>>>>>>> [comment @main /]
>>>>>>>>>> [r.identifier /]
>>>>>>>>>> try
>>>>>>>>>> [/for]
>>>>>>>>>> other try
>>>>>>>>>> [/for]
>>>>>>>>>> [/file]
>>>>>>>>>> [/template]
>>>>>>>>>> Tristan
Re: [Acceleo] AllInstances problem with 3.0M6 [message #529191 is a reply to message #529176] Fri, 23 April 2010 07:09 Go to previous message
--------------030507090206050209040203
Tristan,
Looking at this last example, I'd say OCL or Acceleo confuses the two
classifiers, even though you use a qualified name. I'll try and check
some more on this.
Laurent Goubet
Obeo
> ttm::Requirement
> but in this loop :
> [e.identifier /]
> [/for]
> [e.ident /]
> [/for]
>> Tristan,
>> Laurent Goubet
>> Obeo
>>> in this case :
>>> [/for]
>>> [e.identifier /]
>>> [/for]
>>>> Hi Tristan,
>>>> anything ???
>>>> [r.identifier /]
>>>> [/file]
>>>> Laurent Goubet
>>>> Obeo
>>>>> [r.identifier /]
>>>>> 'Requirement')) ]
>>>>> [self /]
>>>>> [/for]
>>>>> [/file]
>>>>>> Tristan
>>>>>>> Tristan
>>>>>>>> Tristan,
>>>>>>>> [self/]
>>>>>>>> [/for]
>>>>>>>> Laurent Goubet
>>>>>>>> Obeo
>>>>>>>>> Hi !
>>>>>>>>> [module
>>>>>>>>> [comment @main /]
>>>>>>>>> [r.identifier /]
>>>>>>>>> try
>>>>>>>>> [/for]
>>>>>>>>> other try
>>>>>>>>> [/for]
>>>>>>>>> [/file]
>>>>>>>>> [/template]
>>>>>>>>> Regards
>>>>>>>>> Tristan
>>>>>>>>>> Tristan,
>>>>>>>>>> never used it :p).
>>>>>>>>>> try
>>>>>>>>>> [/for]
>>>>>>>>>> other try
>>>>>>>>>> [/for]
>>>>>>>>>> Laurent Goubet
>>>>>>>>>> Obeo
>>>>>>>>>>> [module
>>>>>>>>>>> [comment @main /]
>>>>>>>>>>> [r.identifier /]
>>>>>>>>>>> try
>>>>>>>>>>> [/for]
>>>>>>>>>>> other try
>>>>>>>>>>> [/for]
>>>>>>>>>>> [/file]
>>>>>>>>>>> [/template]
>>>>>>>>>>> Tristan
--------------030507090206050209040203--
Previous Topic:[xpand] how to get input model from xmi
Next Topic:[Xpand] Write an example conforming to model ?
Current Time: Tue Oct 28 03:32:56 EDT 2025
Powered by FUDForum. Page generated in 0.10530 seconds
