| Unable to Load Java and KDM Models [message #528796] |
Wed, 21 April 2010 15:31  |
Hi, I am new to this modelling technniques. EMF, and MoDisco.
I am developing SOftware visualization tool using models generated by MODisco[JavaModel and KDM]
My app takes these models as input.
When I try to load these model using EMF persistant library, it throws a exception that unable to find the Meta data of JavaModel and KDm model.
"www.eclipse.org/MoDisco/J2SE5"
How to fix this issue.
Java Model and KDm models are in EMF registry, but still gives the exception.
Please anyone can give me a tip to do this correctly.
| Re: Unable to Load Java and KDM Models [message #528866 is a reply to message #528796] |
Thu, 22 April 2010 04:45  |
Dear sir,
first of all, just to be sure, your java model file has a ".j2se5"
extension ?
MoDisco 0.7 release, for Eclipse 3.5 Galileo, includes a "J2SE5"
metamodel, and related xmi files have an extension ".j2se5"
MoDisco 0.8, for Eclipse 3.6 Helios to come, which is available for
Helios Milestones, promotes a "Java" model for which file extensions are
".javaxmi".
Since "Java" metamodel, and associated discoverers, have many
improvements compared to the "J2SE5", i suggest you, if possible, to
build your software upon Helios (Helios will be released in june, and
pre-release Milestone M6 for modeling is available from Eclipse download
site).
Then, about the problem you encounter, i will need additional
information. Could you please send us a stack trace ?
FUDForum. Page generated in 0.07196 seconds
